Home » Eclipse Projects » Eclipse Platform » Set focus in properties view
Set focus in properties view [message #335829] Sat, 02 May 2009 18:06 Go to next message
I display the Properties View with
PlatformUI.getWorkbench().getActiveWorkbenchWindow().
getActivePage().showView("org.eclipse.ui.views.PropertySheet ");
How can I achieve that the focus (cursor) is on a special attribute, e.g.
the name attribute?
Michaek
Re: Set focus in properties view [message #335830 is a reply to message #335829] Sat, 02 May 2009 21:02 Go to previous messageGo to next message
I'm not sure there is API to achieve this. I poked around on
PropertySheetPage and didn't see anything. Ditto on the underlying
PropertySheetViewer. Feel free to have a look yourself though.
You may want to check out the tabbed properties view, which is more
flexible.
http://www.eclipse.org/articles/Article-Tabbed-Properties/ta bbed_properties_view.html
Cheers
Ben
Michael wrote:
> e.g. the name attribute?
> Michaek
Re: Set focus in properties view [message #335831 is a reply to message #335830] Sun, 03 May 2009 08:01 Go to previous messageGo to next message
Hi Ben,
thanks for your answer. It's already a tabbed property view since it's
about the properties of a GMF diagram.
Re: Set focus in properties view [message #335834 is a reply to message #335831] Sun, 03 May 2009 17:41 Go to previous message
Probably the place you'll have sufficient information to find that field
is in the ISection implementation. You can extend refresh() to set focus
where you want it.
I guess it depends on when you want that field to gain focus. Only the
first time the view is opened? In that scenario you'd probably have to
make your logic a little smarter..
Hope that helps.
-Ben
Michael wrote:
> Hi Ben,
Previous Topic:debugging menu contributions
Next Topic:Creating IFile outside Eclipse
Current Time: Thu Oct 30 12:18:44 EDT 2025
Powered by FUDForum. Page generated in 0.33849 seconds
