Home » Eclipse Projects » Eclipse Platform » Export plugin
Export plugin [message #335800] Thu, 30 April 2009 10:25
I'm an eclipse plugin developer. Recently I was wrote an export wizard
plugin. So trigger the export dialog from the menu and select my export
item listed there and click next. The problem is that if I click previous
to go back to the export dialog it shows a blank dialog. neither the
filter text box nor the tree view of the export methods are shown. I tried
everything to find the problem but so far was unsuccessfull. Here is the
simpler version of the plugin I've tried out.
plugin.xml
<plugin>
<extension
point="org.eclipse.ui.exportWizards">
<wizard id="test_project" name="test"
class="TestExportWizard">
</wizard>
</extension>
</plugin>
TestExportWizard.java
public class TestExportWizard extends Wizard implements IExportWizard{
public void addPages() {
addPage(new TestExportWizardPage("my page"));
public boolean performFinish() {
return false;
public void init(IWorkbench arg0, IStructuredSelection arg1) {
TestExportWizardPage.java
Previous Topic:Menu labels , mnemonic and key assist view
Next Topic:Export plugin
Current Time: Thu Sep 18 18:49:34 EDT 2025
Powered by FUDForum. Page generated in 0.03266 seconds
