Home » Eclipse Projects » Eclipse Platform » Command / handler issue - Ctrl+S won't work
Command / handler issue - Ctrl+S won't work [message #335781] |
Wed, 29 April 2009 14:16 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mark_melvin.amis.com
I'm struggling to figure out the root cause of a bug in my multi-page
editor, and after a couple days of debugging - I give up. I need help. ;)
Here is the scenario:
I have a multipage editor (a subclass of FormEditor) that starts out with
a place-holder as one of its pages. This place-holder page has a button
that allows you to generate a file in your project. When you click this
button, the file is generated, and the place-holder page is replaced with
a simple text editor containing the contents of the new file. It all
works fine, but if you edit the file in the newly-shown text editor (the
dirty state is correct) and try to save it with Ctrl+S, nothing happens.
But here are the weird bits about the behaviour I am seeing:
- The File > Save menu item is enabled, but the keybinding does nothing
- Clicking between pages in my multi-page editor and coming back to the
text editor page has no effect and the keybinding still fails to work
- If I click outside the editor (say on the Outline View), then back in
the editor, the keybinding starts to work
Alternatively, even before I change focus to fix the keybinding issue:
- If I click the Save button on the toolbar, it will always save the file
even though the keybinding doesn't work
- If I click File > Save, it will save the file even though the keybinding
doesn't work
I have pulled my hair out trying to fix this, and I finally turned on
tracing to see what the heck was going on with commands. Here is a marked
up version of my trace log (my annotations look like <[ MM: comment ]>):
<[ MM: Starting runtime workbench ]>
BINDINGS >>> Cache miss
BINDINGS >>> There are 1 deletion markers
<[ MM: Clicked the button to generate the file and new text editor appears
HANDLERS >>> Command('org.eclipse.ui.file.save') has changed to
'LegacyHandlerWrapper(ActionHandler(action=org.eclipse.ui.internal.SaveAction@16d7e89))'
as its handler
org.eclipse.ui/listeners/IWorkbenchPartReference Build Settings Editor -
com.signaklara.skt.build.ui.buildPrefsEditor, property dirty
<[ MM: Click in the editor and press 'Enter' ]>
KEYS >>> Listener.handleEvent(type = Traverse, stateMask = 0x0, keyCode =
0xd, time = 3430656, character = 0xd)
KEYS >>> WorkbenchKeyboard.press(potentialKeyStrokes = [CR])
KEYS >>> Listener.handleEvent(type = KeyDown, stateMask = 0x0, keyCode =
<[ MM: Pressed 'Ctrl + S', and nothing happens ]>
0x40000, time = 3432359, character = 0x0)
KEYS >>> Listener.handleEvent(type = KeyDown, stateMask = 0x40000, keyCode
= 0x73, time = 3432656, character = 0x13)
KEYS >>> WorkbenchKeyboard.press(potentialKeyStrokes = [CTRL+S])
KEYS >>> WorkbenchKeyboard.executeCommand(commandId =
'org.eclipse.ui.file.save', parameters = {})
KEYS >>> not enabled
COMMANDS >>> execute >>> starting: id=org.eclipse.ui.file.save;
event=ExecutionEvent(Command(org.eclipse.ui.file.save,Save,
Save the current contents,
Category(org.eclipse.ui.category.file,File,null,true),
LegacyHandlerWrapper(ActionHandler(action=org.eclipse.ui.internal.SaveAction@16d7e89)),
,,true),{},Event {type=1 StyledText {} time=3432656 data=null x=0 y=0
width=0 height=0
detail=0},org.eclipse.core.expressions.EvaluationContext@17f92da)
COMMANDS >>> execute >>> not enabled: id=org.eclipse.ui.file.save;
exception=org.eclipse.core.commands.NotEnabledException: Trying to execute
the disabled command org.eclipse.ui.file.save
<[ MM: OK, nothing happened - now I click outside the editor on the
Outline View ]>
org.eclipse.ui/listeners/IWorkbenchPage.IPartListener 387,
partDeactivated(Build Settings Editor -
com.signaklara.skt.build.ui.buildPrefsEditor)
org.eclipse.ui/listeners/IWorkbenchPage.IPartListener2 387,
partDectivated(Build Settings Editor -
org.eclipse.ui/listeners/IWorkbenchWindow.IPartListener 627,
'ActionHandler(org.eclipse.ui.internal.SaveAction@7835ec)' as its handler
HANDLERS >>> 96 command ids changed in 0ms
BINDINGS >>> Cache hit
org.eclipse.ui/listeners/IWorkbenchWindow.IPartListener2 627,
partActivated(Outline - org.eclipse.ui.views.ContentOutline)
partDeactivated(Outline - org.eclipse.ui.views.ContentOutline)
partDectivated(Outline - org.eclipse.ui.views.ContentOutline)
<[ MM: Clicked back in the editor ]>
as its handler
partActivated(Build Settings Editor -
<[ MM: Pressed 'Ctrl + S', and the files saves just fine ]>
0x40000, time = 3496406, character = 0x0)
= 0x73, time = 3496687, character = 0x13)
,,true),{},Event {type=1 StyledText {} time=3496687 data=null x=0 y=0
width=0 height=0
detail=0},org.eclipse.core.expressions.EvaluationContext@d4ba66)
COMMANDS >>> execute >>> success: id=org.eclipse.ui.file.save;
returnValue=null
So, do any command gurus have any pointers as to what the heck I should do
next? This is a minor bug but since I have spent so much time on it I
*really* want to fix it at this point. I am using Eclipse 3.4.1 on
Windows XP. In case you are interested, the code I use to replace the
editor with a text editor when the button is clicked is as follows:
// When the multipage editor is created, I create a text editor in the
// variable 'xmlEditor' but just don't stick it anywhere visible
// Then, in my button clicked handler
// (Note: 'customBuildPageIndex' is the index of the placeholder page)
addPage(customBuildPageIndex + 1, xmlEditor, new
FileEditorInput(destFile));
setPageText(customBuildPageIndex + 1,
IXMLConstants.FILENAME_CUSTOM_BUILD_XML);
// Make the new page the active page
setActivePage(customBuildPageIndex + 1);
// Remove the existing custom build generator page.
removePage(customBuildPageIndex);
Thanks in advance,
Mark.
Re: Command / handler issue - Ctrl+S won't work [message #335794 is a reply to message #335781] |
Thu, 30 April 2009 00:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ben Vitale![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=bvitale3002%40yahoo.com) Messages: 247 Registered: July 2009 |
I guess just basic sanity checks:
When you manipulate the editor widgets, you're firing a property change
event for IEditorPart.PROP_DIRTY?
You're also answering correctly when asked isDirty()?
You could also set some breakpoints at various points SaveAction or its
superclass to see where things are going awry.
Beyond that I don't have any good suggestions.
Ben
> ;) Here is the scenario:
> with a place-holder as one of its pages. This place-holder page has a
> button that allows you to generate a file in your project. When you
> click this button, the file is generated, and the place-holder page is
> replaced with a simple text editor containing the contents of the new
> file. It all works fine, but if you edit the file in the newly-shown
> text editor (the dirty state is correct) and try to save it with Ctrl+S,
> nothing happens. But here are the weird bits about the behaviour I am
> seeing:
> file even though the keybinding doesn't work
> marked up version of my trace log (my annotations look like <[ MM:
> comment ]>):
> appears ]>
> as its handler
> = 0xd, time = 3430656, character = 0xd)
> keyCode = 0x73, time = 3432656, character = 0x13)
> x=0 y=0 width=0 height=0
> execute the disabled command org.eclipse.ui.file.save
> Outline View ]>
> as its handler
> keyCode = 0x73, time = 3496687, character = 0x13)
> returnValue=null
> do next? This is a minor bug but since I have spent so much time on it
> I *really* want to fix it at this point. I am using Eclipse 3.4.1 on
> Thanks in advance,
> Mark.
Re: Command / handler issue - Ctrl+S won't work [message #335798 is a reply to message #335794] |
Thu, 30 April 2009 13:26 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hey Ben,
Thanks for listening...
Yes, I am firing the appropriate changes, and my editor is in fact
reporting itself as dirty (you can see the "property dirty" event in the
trace right after I press enter in the editor).
I have tried to debug the SaveAction, but it seems that the command
framework just never gets that far as nothing is ever called in the object
when Ctrl+S doesn't work. I guess I should look closer at
EvaluationContext.
Another weird thing is that there seems to be a proliferation of
"SaveAction" instances. I recall seeing a growing list (like 5 or 6
instances) of them in a listener list while debugging. I'm pretty deep in
the internals of Eclipse though, and sort of lost at this point. The
command framework always makes my head spin a little. ;)
Mark.
> Ben
>> seeing:
>> comment ]>):
>> appears ]>
>> as its handler
>> Outline View ]>
>> as its handler
>> returnValue=null
>> Thanks in advance,
>> Mark.
Re: Command / handler issue - Ctrl+S won't work [message #335845 is a reply to message #335798] |
Mon, 04 May 2009 21:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
No Eclipse Commands experts on this one? Does it look like it may
possibly be a bug (I'll file one if so)? I'm just not sure if it is
something I am missing with my Form Editor.
Mark.
Mark Melvin wrote:
> Hey Ben,
> EvaluationContext.
> Mark.
>> Regards,
>> Ben
>>> seeing:
>>> comment ]>):
>>> appears ]>
>>> as its handler
>>> Outline View ]>
>>> as its handler
>>> returnValue=null
>>> Thanks in advance,
>>> Mark.
Re: Command / handler issue - Ctrl+S won't work [message #335854 is a reply to message #335850] |
Tue, 05 May 2009 13:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> MultiPageEditorPart is always good for a laugh. It doesn't play nicely
> with the framework (although there was an inner editor bug recently
> fixed in 3.5 M7 that would prevent handlers from working if there were
> more than one text editor, for example).
> The standard save action contributed by the workbench simply walks the
> list of dirty editors and tries to save them. When you generate the new
> file and use addPage(*) to add the editor, do you update the
> FormEditor's dirty state? If your inner editor is already dirty before
> being added, I'm not sure that it will fire the PROP_DIRTY
> If you subclassed FormEditor, what does your implementation of doSave(*)
> look like?
Thanks, Paul. It looks like it is firing the PROP_DIRTY property change
(I can see the event in the console), and the editor is shown as dirty
with an asterisk as well. The problem seems to be listener-related.
My doSave(*) looks/works fine; I can post it if you think it will help,
but I don't think it is an issue. The issue is I never actually get
there. If I put a breakpoint in it, it is never reached. Again, here is
the sequence of events:
1) Open my multipage editor
2) Switch to second pane
3) Click the button that creates a new file, and replaces the nested page
with the button on it to one that contains a TextEditor (the file is new,
and not dirty at this point so the editor state is not dirty)
4) Type something into the new editor (the property change is fired in the
console, and the editor is marked as dirty)
5) Press Ctrl+S and nothing happens
Here is the console trace for those exact events:
com.signaklara.skt.build.ui.buildPrefsEditor, property title
org.eclipse.ui/listeners/IWorkbenchPage.IPartListener 386,
partOpened(Build Settings Editor -
org.eclipse.ui/listeners/IWorkbenchPage.IPartListener2 386,
org.eclipse.ui/listeners/IWorkbenchWindow.IPartListener 177,
org.eclipse.ui/listeners/IWorkbenchWindow.IPartListener2 177,
partVisible(Build Settings Editor -
partBroughtToTop(Build Settings Editor -
partDeactivated(Navigator - org.eclipse.ui.views.ResourceNavigator)
partDectivated(Navigator - org.eclipse.ui.views.ResourceNavigator)
HANDLERS >>> 20 command ids changed in 0ms
'LegacyHandlerWrapper(ActionHandler(action=org.eclipse.ui.internal.SaveAction@10d1090))'
as its handler
0xd, time = 3355437, character = 0xd)
0x40000, time = 3356265, character = 0x0)
= 0x73, time = 3356828, character = 0x13)
LegacyHandlerWrapper(ActionHandler(action=org.eclipse.ui.internal.SaveAction@10d1090)),
,,true),{},Event {type=1 StyledText {} time=3356828 data=null x=0 y=0
width=0 height=0
detail=0},org.eclipse.core.expressions.EvaluationContext@1d6c962)
I wonder if it has something to do with the fact that I create the
TextEditor when I create the multipage editor, and just "hook it up" if
the user presses the "generate file" button?
Mark.
Current Time: Sat Aug 17 06:56:02 GMT 2024
Powered by FUDForum. Page generated in 0.06233 seconds
