set run configuration programmtical, launch programmatical [message #335724] |
Thu, 23 April 2009 11:25  |
I want to programmatically set the arguments for running a python script
and I want to run it programmatically.
My goal is to do programmatically what you would normally do by hand with
right mousekey>run as...>run configuration
and setting the arguments.
Unfortunately, my search did not help me on this (or I was lacking the
right keywords).
Please help me find out wether it is possible at all and if so, how to
accomplish it.
Thanks for your consideration.
Re: set run configuration programmtical, launch programmatical [message #335758 is a reply to message #335731] |
Tue, 28 April 2009 05:43  |
Thank you, Prakash, your hint was very helpful.
To sum it up for others with the same problem:
Read the article, substitute
ILaunchConfigurationType type =
manager.getLaunchConfigurationType(ID_JAVA_APPLICATION);
for
manager.getLaunchConfigurationType(org.python.pydev.debug.co re.Constants.ID_PYTHON_REGULAR_LAUNCH_CONFIGURATION_TYPE);
and if eclipse complains about unset attributes, create a configuration
manually and search all attributes of the workingCopy programmatical,
where you should get the String constants for the desired attributes.
Bewa
FUDForum. Page generated in 0.03271 seconds
