Home » Eclipse Projects » Eclipse Platform » update Site Problem
update Site Problem [message #335680] Tue, 21 April 2009 07:50
Originally posted by: thomas.schober.helbling.de
i am trying to build a local update site for our Developer Team, so that it
is more easy for us, to make sure everyone has the same version of all
plugins. I try to bundle also plugins from other update sites
(emf,gmf,cdt...).
To achieve this, i did the following:
1. Create feature project for each plugin set
2. Create update site and added all plugins
3. hit the Build Button in the update site "site.xml" viewer
Now i have the problem that i get the following Error, when building the
update site:
Problems during export
D:\Projekte\AutosarToolkitDLE\WorkspaceUpdateSite\.metadata\ .plugins\org.eclipse.pde.core\temp\org.eclipse.pde.container .feature\assemble.org.eclipse.pde.container.feature.win32.wi n32.x86.xml:92:
The following error occurred while executing this line:
D:\Projekte\AutosarToolkitDLE\WorkspaceUpdateSite\.metadata\ .plugins\org.eclipse.pde.core\temp\org.eclipse.pde.container .feature\assemble.org.eclipse.pde.container.feature.win32.wi n32.x86.xml:114:
p2.generator doesn't support the "site" attribute
What is the meaning of doesn't support the "site" attribute ? Is it not
possible to build a update site from these Plugins ?
Thank You
Thomas Schober
Previous Topic:Bug in saving file with same name as other open modified files
Next Topic:Extract methods across classes?
Current Time: Fri Apr 25 00:13:02 EDT 2025
Powered by FUDForum. Page generated in 0.03785 seconds
