Re: Best practice: Working on Eclipse CVS stuff [message #335677 is a reply to message #335659] |
Tue, 21 April 2009 04:39 |
Walter Harley Messages: 847 Registered: July 2009 |
"Kai Schlamp" <schlamp@gmx.de> wrote in message
news:gshn93$dlt$1@build.eclipse.org...
> Hello.
> As I just started hacking a bit on the Eclipse stuff, I often encounter
> the following problem.
> I fetched a plug-in I want to work on from the Eclipse CVS. Now I make
> some changes, but want to test the original version again.
> One way would be to create a patch, revert all changes, test the original
> code, apply the patch again (quite unhandy).
As you discovered, local history is one way around this.
But actually, I prefer to do exactly what you described. The reason is that
then I have the patch, so others can review it and I can post it in the bug
report. It only takes a few seconds to revert or re-apply a patch, in most
cases; I don't find it un-handy at all.
Re: Best practice: Working on Eclipse CVS stuff [message #335684 is a reply to message #335659] |
Tue, 21 April 2009 15:51 |
Kai Schlamp wrote:
> Hello.
> original code, apply the patch again (quite unhandy).
> I know, a good solution would be a DVCS, but we are not there yet ;-)
> How do you jump between your own version and the original one from the
> CVS? Or do checkin the code in your own VCS. But then there is the
> problem again to synchronize with the Eclipse CVS.
In addition to Local History and Patches (which I, personally, use most
often), you could try modifying the name of a project that you edit so
it is different than the original. Then you can have the original also
checked out in your workspace and open/close it as needed.
Hope this helps,
Eric
FUDForum. Page generated in 0.03337 seconds
