Home » Eclipse Projects » Eclipse Platform » Files copied from src to bin on compile - config?
Files copied from src to bin on compile - config? [message #335575] Wed, 15 April 2009 10:32 Go to next message
I noticed a strange behavior with Eclipse's normal build mechanism:
Context:
- Using Ganymede
- The project type is Java Project
- The project is use to produce a libary jar.
- The project is referenced by other projects during their build/deploy.
- The project contains a .properties and a .cfg.xml files under /src.
Issue noticed:
- During a build, the .properties file is copied to /bin, the .xml file is
not.
- During an export to JAR, both files properly show at the root of the jar
- which puts them properly in the classpath.
- When referenced by another project, the .xml files is not found in the
classpath - probably because it was not copied to /bin.
Questions:
1) Is there an Eclipse configuration item to tell it what file types to
copy from /src to /bin during compile? If so, where?
2) If not, what is the proper location to place project config files so
that Eclipse will correctly place them in the classpath when the project
is referenced by another project or included in the deployment of a
referencing project to an app server (i.e.: web app using the library)?
3) If Eclipse isn't capable of doing either (1) or (2), is the only
alternative abandoning Eclipse build/deploys and switch to either Ant or
Maven builds?
Re: Files copied from src to bin on compile - config? [message #335577 is a reply to message #335575] Wed, 15 April 2009 10:37 Go to previous messageGo to next message
Preferences->Java->Compiler->Building->Filtered Resources
- Prakash
http://blog.eclipse-tips.com
Re: Files copied from src to bin on compile - config? [message #335579 is a reply to message #335575] Wed, 15 April 2009 10:51 Go to previous messageGo to next message
I forgot to mention: As a dirty hack, using the same (/src) directory for
both source and compiled code (instead of using /bin for compiled code)
bypasses the problem. But it is clearly a dirty solution.
I almost have to wonder... is this an Eclipse bug?
Re: Files copied from src to bin on compile - config? [message #335581 is a reply to message #335577] Wed, 15 April 2009 10:57 Go to previous messageGo to next message
Thank you Prakash. That worked perfectly!
Re: Files copied from src to bin on compile - config? [message #335583 is a reply to message #335579] Wed, 15 April 2009 11:19 Go to previous message
bruno.melloni@chickasaw.net (Bruno Melloni) writes:
If you have the TPTP plugin installed you may be suffering from
https://bugs.eclipse.org/bugs/show_bug.cgi?id=230050
It is worth checking the version if you have TPTP as I believe it is
supposed to be fixed.
Owen Rees; speaking personally, and not on behalf of HP.
Hewlett-Packard Limited. Registered No: 690597 England
Registered Office: Cain Road, Bracknell, Berks RG12 1HN
Previous Topic:Responce time
Next Topic:Text Editor line breaks
Current Time: Fri Nov 07 05:53:43 EST 2025
Powered by FUDForum. Page generated in 0.04834 seconds
