Home » Language IDEs » PHP Development Tools (PDT) » Problems with auto formatting and HEREDOC
Problems with auto formatting and HEREDOC [message #1804601] Fri, 29 March 2019 08:49
Bernd Schuhmacher is currently offline Bernd SchuhmacherFriend
I have a problem when auto formatting (CTRL-SHIFT-F) a php file with some strings defined with the HEREDOC syntax.
If the definition of the string is in an area which is already indented the end marker for the HEREDOC- string need to be on the start of a new line. If not there will be a "PHP Parse error" after that line.
Example:
<?php
function foo(){
    echo <<<EOT
Ha, you found foo ...
so we can do some funny things here.
EOT;
foo();
This code is working as expected. After doing automatic formatting with CTRL-SHIFT-F the code looks like this:
<?php
function foo()
    echo <<<EOT
    EOT;
foo();
Besides that it is not parsable anymore the formatting within the string is "destroyed" as the spaces inserted are printed to if I make the code usable again by deleting the spaces before "EOT;".
Is there a way to configure this to work properly or is this a bug with PDT?
Bernd
Previous Topic:Problems in XDEBUG with path mapper
Next Topic:Install Eclipse without any Features
Current Time: Thu May 02 01:47:19 GMT 2024
Powered by FUDForum. Page generated in 0.02666 seconds
