Assign ".a.b" extention to my editor? [message #335538] |
Tue, 14 April 2009 08:20 |
--------------080902000204070301020906
Content-Type: text/plain; charset=UTF-8; format=flowed
For some reason, my client wants to make the *.ui.xml files to open with
a custom editor. But I found that it's no use to config it in the
org.eclipse.ui.editors extention.
I noticed the bug22905's status is still "new". Is there some other way
to achieve what I want?
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=22905>
*/Dollyn/*
Content-Type: text/html; charset=UTF-8
<html>
<head>
</head>
with a custom editor. But I found that it's no use to config it in the
org.eclipse.ui.editors extention.<br>
<br>
to achieve what I want?<a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=22905"></a>
<div class="moz-signature">-- <br>
<meta http-equiv="Content-Language" content="zh-cn">
<meta http-equiv="Content-Type" content="text/html; ">
<title>Dollyn</title>
<p><b><i><font color="#0000ff" face="Courier New">Dollyn</font></i></b></p>
</div>
</body>
</html>
--------------080902000204070301020906--
Dollyn
Re: Assign ".a.b" extention to my editor? [message #335561 is a reply to message #335542] |
Wed, 15 April 2009 01:35 |
--------------000401090705040009020407
Content-Type: text/plain; charset=gb18030; format=flowed
But how? A content type can only define file-extensions and file-names,
but it seems no use to give it "double-extension"(like filenames xx.a.b).
>> the org.eclipse.ui.editors extention.
>> way to achieve what I want?
> You could define a new content type and hook up your editor to it.
> Dani
>> */Dollyn/*
*/Dollyn/*
Content-Type: text/html; charset=gb18030
<html>
<head>
<meta content="text/html;charset=gb18030" http-equiv="Content-Type">
<title></title>
</head>
xx.a.b). <br>
<br>
<blockquote cite="mid:gs1lvc$r7v$1@build.eclipse.org" type="cite">Dollyn
wrote:
<br>
<blockquote type="cite">For some reason, my client wants to make the
*.ui.xml files to open with a custom editor. But I found that it's no
use to config it in the org.eclipse.ui.editors extention.
<br>
<br>
<br>
</blockquote>
<br>
<br>
Dani
<br>
<blockquote type="cite">--
Dollyn
Re: Assign ".a.b" extention to my editor? [message #335615 is a reply to message #335562] |
Thu, 16 April 2009 13:10 |
The describer can only get the inputstream, but my files are the same
with normal xml-files, except the file-name.
Daniel Megert 写道:
>> file-names, but it seems no use to give it "double-extension"(like
>> filenames xx.a.b).
> Read the extension point doc again with focus on content describer.
> Dani
>>> Dani
>>>> */Dollyn/*
>> */Dollyn/*
Dollyn
Re: Assign ".a.b" extention to my editor? [message #335634 is a reply to message #335632] |
Fri, 17 April 2009 05:53 |
--------------030700010009020609020407
Well, this seems not what I want...
Our XML's have nothing in common, no common root's, no common schema...
But thank you all the same. Maybe we can persuade our clients to create
a common schema
for the XML...
Prakash G.R. wrote:
>> What I want is: all and only the files that have the name like *.a.b will
>> be opened with my editor. Is that possible?
> AFAIK, that is not possible. However, as Dani said, you can use the
> contentTypes extension point. Since your files are XML, you can set the
> content type with the root element of your XML:
> <extension
> point="org.eclipse.core.contenttype.contentTypes">
> <content-type
> id="yourXmlTypeId"
> name="Some Name"
> priority="normal">
> <describer
> class=" org.eclipse.core.runtime.content.XMLRootElementContentDescri ber ">
> <parameter
> name="element"
> value="your_root_element">
> </parameter>
> </describer>
> </content-type>
> </extension>
> Now you can associate this content type with your editor. HTH
> - Prakash
*/Dollyn/*
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
<title></title>
</head>
Well, this seems not what I want...<br>
<br>
Our XML's have nothing in common, no common root's, no common schema...<br>
<br>
a common schema<br>
for the XML...<br>
<br>
Prakash G.R. wrote:
<blockquote cite="mid:gs93fi$es6$1@build.eclipse.org" type="cite">
<pre wrap="">What I want is: all and only the files that have the name like *.a.b will
</pre>
</blockquote>
<pre wrap=""><!---->
<extension
<content-type
id="yourXmlTypeId"
name="Some Name"
priority="normal">
<describer
<parameter
name="element"
</parameter>
</describer>
</content-type>
</extension>
- Prakash
</pre>
</blockquote>
<br>
</div>
</body>
</html>
--------------030700010009020609020407--
Dollyn
FUDForum. Page generated in 0.04230 seconds
