Home » Eclipse Projects » Eclipse Platform » Eclipse 3.5M6 Update behind proxy not working anymore
Re: Eclipse 3.5M6 Update behind proxy not working anymore [message #335626 is a reply to message #335526] |
Thu, 16 April 2009 20:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Henning Riedel![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=kesselhaus%40gmx.net) Messages: 310 Registered: July 2009 |
Well, I use the Eclipse SDK 3.5M6 zip file and unpacked locally.
I set up the 'Manual' HTTP/HTTPS proxy (host/port) under
Window->Preferences->'Network Connections'.
Then I go to Help->'Install New Software...', add an update site, it
starts searching, but stops with an error dialog popping up, which
states 'No repository found at <name_an_updatesite_here>'.
In the <workspace_loc>/.metadata/.log I have several entries like:
!ENTRY org.eclipse.core.net 1 0 2009-04-16 18:12:18.427
!MESSAGE System property socksProxyHost is not set but should be
<proxy_name>.
!MESSAGE System property socksProxyPort is not set but should be
<proxy_port>.
where <proxy_name> and <proxy_port> are the settings I made in the
preferences (as stated above).
Am 13/04/2009 15:30, schrieb Ben Vitale:
> Do you have any errors in your Error Log view?
> Are you using Equinox p2 ("Software Updates") or the classic update
> manager?
> Can you be more specific about what isn't working?
> -Ben
> kesselhaus wrote:
>> Starting with 3.5M6, the update/install does not work anymore.
>> I'm behind a proxy.
>> a) I have no clue where the proxy is.
>> b) I don't what kind of proxy that is,
>> c) I have no access to configure the proxy and also don't know, who is
>> configuring it.
>> So I would appreciate, if there is anything done between 3.5M5 and
>> 3.5M6 on the update stuff in Eclipse, reverse that change.
>> Regards,
>> kesselhaus
Re: Eclipse 3.5M6 Update behind proxy not working anymore [message #335647 is a reply to message #335626] |
Sat, 18 April 2009 01:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ben Vitale![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=bvitale3002%40yahoo.com) Messages: 247 Registered: July 2009 |
Sorry, I can't offer any suggestions. I've never configured a proxy
myself. After digging a little bit, it looks like the logic for logging
those "System property" messages has been in Eclipse since at least 3.4,
if not earlier.
If your configuration was the same in previous versions, and it stopped
working in M6, it's possible a bug was introduced. It looks like there
has been a good amount of proxy-related work in 3.5:
http://tinyurl.com/dzcsmg
If you are so inclined, file a new bug against the Platform product,
Team component. Prefix the summary with [Net].
https://bugs.eclipse.org/bugs/enter_bug_wizard.cgi
Ben
> <proxy_name>.
> <proxy_port>.
>> manager?
>> -Ben
>> kesselhaus wrote:
>>> Hi,
>>> I'm behind a proxy.
>>> configuring it.
>>> Regards,
>>> kesselhaus
Re: Eclipse 3.5M6 Update behind proxy not working anymore [message #336361 is a reply to message #335647] |
Tue, 09 June 2009 15:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Paul McDonnell![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=mcd%40pmcdee.co.uk) Messages: 1 Registered: July 2009 |
Junior Member |
It sounds like my problems are related.
I've been using Eclipse/RAP for several months usually installing RAP from
the update site. To connect to the site I would manually configure the
proxy server, simply specifying the IP address and port. When I connected
I was asked to authenticate with user name and password and everything
then progressed with no problems.
A few months ago I downloaded 3.5M5 and found the proxy configuration
screen has changed significantly and I couldn't get it to work. As I had
other work on with a higher priority I didn't pursue the problem. Today I
went back to it, thinking the problem might now be resolved in the latest
builds. So, I tried again with 3.5RC4. Still the same problem.
In Windows-Preferences-General-Network Connections, for Active Provider
set to either "Direct" or "Native", using the Test Connection option under
Install/Update-Available Software Sites, results in an "Unknown Host"
message. (As I think I would have expected.)
When the Active Provider is set to "Manual", which I believe is the
equivalent of the manual configuration prior to 3.5MS, there is no error
message on testing the connection, but the download never starts. A
"Progress Information" dialogue tells me that it is contacting the update
site, but thats as far as it gets.
If anyone has any ideas they'd be appreciated.
Paul McD
Re: Eclipse 3.5M6 Update behind proxy not working anymore [message #336662 is a reply to message #335647] |
Fri, 26 June 2009 14:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Marco Noto![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=marcomario.noto%40gmail.com) Messages: 2 Registered: July 2009 |
Junior Member |
> if not earlier.
> Ben
>> <proxy_name>.
>> <proxy_port>.
>>> manager?
>>> -Ben
>>> kesselhaus wrote:
>>>> Hi,
>>>> I'm behind a proxy.
>>>> configuring it.
>>>> Regards,
>>>> kesselhaus
I've the same problem...if i set native proxy setting, i'm asked for
Authentication (???)...if i set manual proxy, i've the same problem of the
author of the post...
My eclipse Build id: 20090621-0832
Current Time: Thu Jul 25 18:31:37 GMT 2024
Powered by FUDForum. Page generated in 0.03543 seconds
