Home » Eclipse Projects » Eclipse Platform » Setting GlobalActionHandler for command
Setting GlobalActionHandler for command [message #335482] Fri, 10 April 2009 06:08 Go to next message
I'm using ver. 3.3 and I'm trying to retarget the global delete action
using the commands framework. I've written my own DeleteHandler which
extends AbstractHandler.
<handler
class="mypackage.handlers.DeleteHandler"
commandId="org.eclipse.ui.edit.delete">
<activeWhen>
<with
variable="activePartId">
<equals
value="mypackage.views.myview">
</equals>
</with>
</activeWhen>
</handler>
If I add the "org.eclipse.ui.edit.delete" command as a popup menu in my
view it works fine - my handler is called and the delete key works.
However, I need to get it working from the "Edit" menu in the main RCP
menu.
I know, in my view, I need to call:
getViewSite().getActionBars().setGlobalActionHandler("org.eclipse.ui.edit.delete ",
someIAction);
My problem is, this method takes an IAction parameter. All I have is an
AbstractHandler? I thought the abstraction of commands meant we didn't
have to instantiate actions ourselves? Any idea what I should pass to this
method?
Thanks!
Re: Setting GlobalActionHandler for command [message #335530 is a reply to message #335482] Mon, 13 April 2009 10:10 Go to previous message
> menu.
In 3.3 the Edit menu still used the retarget actions, which aren't
linked to commands. This was upgraded to be commands only in 3.4
PW
Paul Webster
Previous Topic:eclipse 3.4.2 on Solaris 9
Next Topic:help with form Text
Current Time: Thu Oct 30 00:07:52 EDT 2025
Powered by FUDForum. Page generated in 0.09922 seconds
