Home » Eclipse Projects » Eclipse Platform » Lost in eclipse dowloads space
Lost in eclipse dowloads space [message #335459] Thu, 09 April 2009 12:39 Go to next message
No real name is currently offline No real nameFriend
Hey,
I am a bit lost in eclipse downloads : I was wondering which package is
the right choice for me now between RCP package and JavaEE
(http://www.eclipse.org/downloads/)
RCP package is slightly bigger than JavaEE (176MB vs 163MB)
but...
looking at the "More..." links there are two lists of inculded packages
and there are lots more for JavaEE (the small one !)
http://www.eclipse.org/downloads/packages/eclipse-rcpplug-de velopers/ganymedesr2
and
http://www.eclipse.org/downloads/packages/eclipse-ide-java-e e-developers/ganymedesr2
Apparently all plugins included aren't diplayed in those lists (it
explains the weight difference) but I don't understand why ?
(I finally choose JavaEE :) )
Guillaume.
Re: Lost in eclipse dowloads space [message #335460 is a reply to message #335459] Thu, 09 April 2009 12:43 Go to previous messageGo to next message
Guillaume,
You should choose based on what type of development you'll be doing,
i.e, based on required function, not on size.
Guillaume Bourel wrote:
> Hey,
> is the right choice for me now between RCP package and JavaEE
> but...
> packages and there are lots more for JavaEE (the small one !)
> and
> Cheers,
> Guillaume.
Ed Merks
Re: Lost in eclipse dowloads space [message #335462 is a reply to message #335459] Thu, 09 April 2009 13:06 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
The RCP build includes a lot of native fragments (i.e. SWT forlinux,
win32, macosx, etc, filesystem for linux, win32, etc) to allow RCP apps
to be generated easily for multiple platforms ... the JavaEE download
will be tools for doing java EE development for one platform (like win32)
PW
Paul Webster
Re: Lost in eclipse dowloads space [message #335470 is a reply to message #335459] Thu, 09 April 2009 19:57 Go to previous message
On 4/9/2009 8:39 AM, Guillaume Bourel wrote:
> Hey,
> but...
> and
RCP probably includes the sources and multi-platform support, making it
bigger. If you are going to develop Eclipse plug-ins or RCP
applications, you'll definitely want to start with that package. You can
easily add the WTP stuff later using Help > Software Updates.
If, on the other hand, you're only going to do JEE development (not
Eclipse plug-ins or RCP), then that is the best package to get.
n either case, adding more features later is always an option.
Hope this helps,
Eric
Previous Topic:Invoke/Load/Launch a particular version of the plugin programatically/dynamicall
Next Topic:Does JProbe 7.0.0 works with Eclipse 3.4?
Current Time: Fri Nov 08 22:58:46 GMT 2024
Powered by FUDForum. Page generated in 0.04327 seconds
