| continous full build, resource tree is lost [message #335430] |
Wed, 08 April 2009 03:51  |
Before I file a bug against plattform I want to discuss my problem here.
I'm working with CDT under Eclipse Version: 3.4.0. When I run a project
build sometimes it happens that the buildState (resource tree) isn't
cached correctly after the build finished. To explore the problem I added
console message to the org.eclipse.core.resources package.
The build consist of three builders in following order:
1. External Tool Builder
2. CDT Builder
3. Own contributed builder
The External Tool Builder deletes some files in the projects and calls a
project refresh at the end.
And here is what I found:
1. When the build starts the BuildManager requests the build commands with
the method
IProjectDescription#getBuildSpec()
2. Before the CDT Builder starts
IProjectDescription#setBuildSpec(ICommand[])
is called. Maybe triggered by the refresh of the External Tool Builder. In
this method the builders of the old commands are copied to new commands.
Since the CDT Builder isn't started at this point, the builder for the CDT
Builder Command is null.
3. CDT Builder is started. The Builder in the CDT Builder Command is set
to the instantiated builder (s. BuildManager#getBuilder()). Unfortunately,
at this time the CDT Builder Command isn't the command in the buildSpec of
the ProjectDescription. Thus the resource tree, safed in the builder isn't
referenced from the buildSpec.
4. After this a project build is always running a full build because the
resource tree is lost.
Possible Fixes:
A. Prevent a call of IProjectDescription#setBuildSpec(ICommand[]) when a
build is running.
B. Keep track of the new build command in the the old command to forward
the builder, that is set in the old command by BuildCommand#setBuilder().
A could be difficult. I prefer B. B could be done in
IProjectDescription#setBuildSpec(ICommand[]) and BuildCommand#setBuilder().
Your comments?
Harald
| Re: continous full build, resource tree is lost [message #335432 is a reply to message #335430] |
Wed, 08 April 2009 06:16   |
Harald,
Who calls setBuildSpec in step two? Who causes there to be a need for a
refresh of the External Tool Builder? If the problem is specific to
CDT, you might want to ask about it on the CDT newsgroup. If you open a
bugzilla, it will need to have enough detail so that someone can
definitely reproduce it locally.
Harald Kästel-Baumgartner wrote:
> project build sometimes it happens that the buildState (resource tree)
> isn't cached correctly after the build finished. To explore the
> problem I added console message to the org.eclipse.core.resources
> package.
> 2. CDT Builder
> a project refresh at the end.
> with the method IProjectDescription#getBuildSpec()
> Builder. In this method the builders of the old commands are copied to
> new commands. Since the CDT Builder isn't started at this point, the
> builder for the CDT Builder Command is null.
> set to the instantiated builder (s. BuildManager#getBuilder()).
> Unfortunately, at this time the CDT Builder Command isn't the command
> in the buildSpec of the ProjectDescription. Thus the resource tree,
> safed in the builder isn't referenced from the buildSpec.
> the resource tree is lost.
> Possible Fixes:
> a build is running.
> forward the builder, that is set in the old command by
> Your comments?
> Harald
| Re: continous full build, resource tree is lost [message #335439 is a reply to message #335432] |
Wed, 08 April 2009 09:09   |
That's what i didn't know yet.
> Who causes there to be a need for a refresh of the External Tool Builder?
It's a feature of org.eclipse.ui.externaltools.ExternalToolBuilder. For
example in CDT a external tool builder can be used to call a batch to
modify/add include files before the internal CDT builder starts.
I'll post the bug there. Maybe setBuildSpec is called from CDT. But, does
it matter? You never can be sure that setBuildSpec isn't called during
build process. In CDT these can be long running (several minutes).
> If you open a
Just imagine a simple contributed builder that calls
IProjectDescription#setBuildSpec(.)
before the build is finished. Could be a way the reproduce this.
I made a patch for
With this in a first shoot, the build works fine. After a few days and a
lot of people working fine with this, I'll post it in the bug.
FYI in IProjectDescription#setBuildSpec(.) I've added the line
((BuildCommand) buildSpec[j]).setCommand((BuildCommand) result[i]);
in BuildCommand#setBuilder(.) the lines
// Forward the buidler to a new command if the reference is set
if (commandReference != null)
commandReference.setBuilder(builder);
and a new method BuildCommand#setCommand(.)
public void setCommand(BuildCommand buildCommand) {
this.commandReference = buildCommand;
Have a nice day.
Harald
>> package.
>> 2. CDT Builder
>> Possible Fixes:
>> a build is running.
>> Your comments?
>> Harald
| Re: continous full build, resource tree is lost [message #335445 is a reply to message #335439] |
Wed, 08 April 2009 12:25   |
Harald,
Comments below.
It might be your fault. :-P
>> Builder?
> For example in CDT a external tool builder can be used to call a batch
> to modify/add include files before the internal CDT builder starts.
>> If the problem is specific to CDT, you might want to ask about it on
>> the CDT newsgroup.
> does it matter? You never can be sure that setBuildSpec isn't called
> during build process. In CDT these can be long running (several minutes).
I suspect there are definitely things you ought not to do during a
build, like change how the builds are supposed to be done...
>> If you open a bugzilla, it will need to have enough detail so that
>> someone can definitely reproduce it locally.
That sounds like the perfect type of thing. That way it's easy to
reproduce and although someone might say you shouldn't do that, you
could then redirect the problem to whomever is doing that...
> I made a patch for org.eclipse.core.resources
> a lot of people working fine with this, I'll post it in the bug.
> in BuildCommand#setBuilder(.) the lines // Forward the buidler to a
Patches/fixes are cool. Committers love those. :-)
> Have a nice day.
You too. :-)
> Harald
>>> Hi,
>>> here.
>>> tree) isn't cached correctly after the build finished. To explore
>>> the problem I added console message to the
>>> 2. CDT Builder
>>> calls a project refresh at the end.
>>> commands with the method IProjectDescription#getBuildSpec()
>>> to new commands. Since the CDT Builder isn't started at this point,
>>> the builder for the CDT Builder Command is null.
>>> command in the buildSpec of the ProjectDescription. Thus the
>>> resource tree, safed in the builder isn't referenced from the
>>> buildSpec.
>>> Possible Fixes:
>>> when a build is running.
>>> Your comments?
>>> Harald
| Re: continous full build, resource tree is lost [message #335453 is a reply to message #335445] |
Thu, 09 April 2009 02:52  |
Comments below.
I agree. But in CDT a build can be a long running process. And you'll
never know what other plugins or the user is doing ;) Changing this could
lead in a robuster design?!
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=271623
Happy Eastern
Harald
FUDForum. Page generated in 0.20664 seconds
