| nsIWebBrowser webBrowser = (nsIWebBrowser)browser.getWebBrowser() NULL on 3.5M6 [message #335423] |
Tue, 07 April 2009 13:28  |
Originally posted by: chlache.talita.org
I am working on an Mozilla Html Editor.
On Eclipse 3.4.1 (nsIWebBrowser)browser.getWebBrowser() works with no problems.
After moving to 3.5M6 (nsIWebBrowser)browser.getWebBrowser() always returns null, even though
the Mozilla Browser has completely loaded.
The Error seems to occcur when SWT.Browser calls ClassForName("org.mozilla.xpcom"), which returns null.
When I run the same Code as a Snippet in 3.5M6 (as in Snippet267) the call works fine though.
Is this a Bug? Thanks for any help.
Andreas
| Re: nsIWebBrowser webBrowser = (nsIWebBrowser)browser.getWebBrowser() NULL on 3.5M6 [message #335436 is a reply to message #335424] |
Wed, 08 April 2009 08:00   |
org.eclipse.swt.browser.Mozilla can't load org.mozilla.xpcom.Mozilla
because "DynamicImport-Package: org.mozilla.xpcom" is missing in the
MANIFEST.MF file.
There isn't a problem when using SWT out of OSGi (Snippet267, for instance).
The problem is fixed in the Eclipse trunk.
Snjeza
>> problems.
>> Andreas
> As a test i put some of the SWT.Mozilla initialization code in my plugin:
> try {
> Class clazz = Class.forName ("org.mozilla.xpcom.Mozilla");
> //$NON-NLS-1$
> Method method = clazz.getMethod ("getInstance", new
> Class[0]); //$NON-NLS-1$
> Object mozilla = method.invoke (null, new Object[0]);
> method = clazz.getMethod ("getComponentManager", new
> try {
> method.invoke (mozilla, new Object[0]);
> } catch (InvocationTargetException e) {
> } catch (ClassNotFoundException e) {
> /* JavaXPCOM is not on the classpath */
> } catch (NoSuchMethodException e) {
> /* the JavaXPCOM on the classpath does not implement
> initialize() */
> } catch (IllegalArgumentException e) {
> } catch (IllegalAccessException e) {
> and it works perfectly, only to immediately fail when calling
> browser = new Browser(parent, SWT.MOZILLA | SWT.BORDER);
> in the SWT plugin. Class.forName returning NULL.
> How is that possible?
| Re: nsIWebBrowser webBrowser = (nsIWebBrowser)browser.getWebBrowser() NULL on 3.5M6 [message #335437 is a reply to message #335436] |
Wed, 08 April 2009 08:20  |
> MANIFEST.MF file.
> instance).
> Snjeza
Thanks a lot for this information. I owe you one.
I will update and I hope that it will work.
Andreas
FUDForum. Page generated in 0.03660 seconds
