Re: Time format in local history [message #335455 is a reply to message #335454] |
Thu, 09 April 2009 10:03 |
Originally posted by: none.domain.invalid
Daniel Megert a écrit :
> Thomas Wiedmann wrote:
>>> Which view/dialog exactly?
>> Its the local history view (Team/History) - as described.
>>> The ones I know use the OS time format (and that's where you can
>>> change it).
>> Definitely no - I use a German Windows XP and there the time formats
>> are different, i. e. without am and pm.
> Don't say "definitely no". If you know how it works why do you need to
> ask here? ;-)
> The time in the History view is correct (same as in OS) on my machine.
> Maybe you pass a different language/local/timezone when starting Eclipse
> or you use -nl <something>.
> Anyway, if your machine is correctly setup and you don't change the
> command line arguments then the time should be like in your OS. If not,
> please file a bug report.
there is already one:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=139599
Re: Time format in local history [message #335456 is a reply to message #335455] |
Thu, 09 April 2009 10:18 |
>>>> change it).
>> ask here? ;-)
>> Eclipse or you use -nl <something>.
>> not, please file a bug report.
also
https://bugs.eclipse.org/bugs/show_bug.cgi?id=127452
https://bugs.eclipse.org/bugs/show_bug.cgi?id=134475
FUDForum. Page generated in 0.04447 seconds
