Plug-in: Bad version number in .class file [message #335364] |
Fri, 03 April 2009 21:06 |
Originally posted by: karl.weber99.gmx.net
I am pretty frustrated by now, since I have no idea about what could be
wrong here:
Eclipse 3.4.2
Default JRE 1.6.0
Target Platform in PDE settings: JRE 1.6.0
I build a tiny plug-in with one action for the toolbar and one corresponding
class. All runs nice in the runtime workbench.
However, when I create a feature with this plug-in and install it, I get the
following error:
Plug-in Hello was unable to load class
aaa.eclipse.contribution.hello.HelloAction.
java.lang.UnsupportedClassVersionError: Bad version number in .class file
at java.lang.ClassLoader.defineClass1(Native Method)
eclipse.buildId=M20090211-1700
java.version=1.5.0_16
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
Command-line arguments: -os linux -ws gtk -arch x86 -clean
Why? Where does this java.version 1.5.0_16 come from? My settings are all
1.6.0???
Furthermore, the plug-in seems to work, i.e. the button in the toolbar shows
and when I click it, the correct Action is executed. I get this error
message only, when the plug-in is first loaded.
I make this fuss, because I have I larger plug-in, that has the same problem
and that does not work....
Thanks in advance,
-Karl
Re: Plug-in: Bad version number in .class file [message #335365 is a reply to message #335364] |
Fri, 03 April 2009 21:18 |
> wrong here:
> Eclipse 3.4.2
> Default JRE 1.6.0
> corresponding class. All runs nice in the runtime workbench.
> the following error:
> 1.6.0???
> shows and when I click it, the correct Action is executed. I get this
I have to correct myself: the plug-in is _not_ working....
> error message only, when the plug-in is first loaded.
> problem and that does not work....
> Thanks in advance,
> -Karl
Re: Plug-in: Bad version number in .class file [message #335369 is a reply to message #335365] |
Fri, 03 April 2009 22:36 |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
--------------060408050602020909020701
Content-Type: text/plain; charset=UTF-8; format=flowed
Are you running the plugin in an Eclipse started as a debug/run Eclipse
application from an Eclipse IDE or are you running it separately as an
installed Eclipse?
If starting it from within an Eclipse IDE, then look at the launch
configuration and make sure the JRE page is pointing to a 1.6 JRE. See
the attached jpg.
If starting it as an installed Eclipse, make sure that there the
eclipse.ini file (in same directory as eclipse.exe) doesn't have a -vm
argument in it specifying a specific JRE.
Rich Kulp
Content-Type: image/jpeg;
name="2009-04-03_183534.jpg"
Content-Disposition: inline;
filename="2009-04-03_183534.jpg"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAMCAgMCAgMDAwMEAwMEBQgFBQQE BQoHBwYIDAoM
DAsKCwsNDhIQDQ4RDgsLEBYQERMUFRUVDA8XGBYUGBIUFRT/2wBDAQMEBAUE BQkFBQkUDQsN
FBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQU FBQUFBT/wAAR
CAKAA3QDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDi/jT+05rXx/8AGWo6hdXV xL4VW6J0nRJc
pBBCpcRO8IZkM5V23PljlmCsE2qOYsdas4FB/sXTWPq1qprkfgl4X/4SzWtE 0hpfJju5FSSU
DlUAyxGe+AcV+k3gL4WaPb6Co0TR45YrCXZc6cUVfPVSDzLjdvZTnJJ6446j +psyzbCcMUaW
Ep0r6aJaJLa7dnq7f5s/A6+HrZhipvnd7+b/AA8uy+SPhV/F1qi4/sbSuOc/ ZFqs/jWzB50T
Syf+vRK9P/aa8EafY6zdaxpmjroMEsu5LSNw6FCcdRxkEj8/pWR4a+AOg6to /wAK59V8YX2l
6j8RJ72206GDRFuLe2kt7hYAJpftKMA7yRAFY2wWOcAbq9XD51gamDhjKicV J8trOTuk5Ne6
n0TdzzcNgauKqTpUXdx31t1SvrbuvPU4X/hNrP8A6Ael/wDgItH/AAm1n/0A 9L/8BFqrq/wx
8SaTrGoWCaRd6iLPW5fDhu7C2kmt5tQjcobeNwuGkJUkJ94jBxTtM+E3jfWz eDTvBniC/Nlc
SWl19l0ueTyJo8eZE+1DtdcjKnBGRnrXuKvhHBT542fW4PCVVLltK/zLH/Cb Wf8A0A9L/wDA
RaP+E2s/+gHpf/gItchcW0trPJBPE8M0bFHjkUqyMDggg9CD2qPHtXWqcHqk Yez82dn/AMJt
Z/8AQD0v/wABFo/4Taz/AOgHpf8A4CLXGY9qMe1Hs49hez83952f/CbWf/QD 0v8A8BFo/wCE
2s/+gHpf/gItcZj2ox7Uezj2D2fm/vOz/wCE2s/+gHpf/gItH/CbWf8A0A9L /wDARa4zHtRj
2o9nHsHs/N/edn/wm1n/ANAPS/8AwEWj/hNrP/oB6X/4CLXGY9qMe1Hs49g9 n5v7zs/+E2s/
+gHpf/gItH/CbWf/AEA9L/8AARa4zHtRj2o9nHsHs/N/edn/AMJtZ/8AQD0v /wABFo/4Taz/
AOgHpf8A4CLXGY9qMe1Hs49g9n5v7zs/+E2s/wDoB6X/AOAi0f8ACbWf/QD0 v/wEWuMx7UY9
qPZx7B7Pzf3nZ/8ACbWf/QD0v/wEWj/hNrP/AKAel/8AgItcZj2ox7Uezj2D 2fm/vOz/AOE2
s/8AoB6X/wCAi0f8JtZ/9APS/wDwEWuMx7UY9qPZx7B7Pzf3nZ/8JtZ/9APS /wDwEWj/AITa
z/6Ael/+Ai1xmPajHtR7OPYPZ+b+87P/AITaz/6Ael/+Ai0f8JtZ/wDQD0v/ AMBFrjMe1GPa
j2cewez83952f/CbWf8A0A9L/wDARaP+E2s/+gHpf/gItcZj2ox7Uezj2D2f m/vOz/4Taz/6
Ael/+Ai0f8JtZ/8AQD0v/wABFrjMe1GPaj2cewez83952f8Awm1n/wBAPS// AAEWj/hNrP8A
6Ael/wDgItcZj2ox7Uezj2D2fm/vOz/4Taz/AOgHpf8A4CLR/wAJtZj/AJgm l/8AgIlcZj2o
2+1Hs49h+zXd/edn/wAJxZ/9ATSv/ARKP+E4s/8AoCaV/wCAiVxm32o2+1Hs o9g9n5v7zs/+
E4s/+gJpX/gIlH/CcWf/AEBNK/8AARK4zb7Ubfaj2Uewez83952f/CcWf/QE 0r/wESj/AITi
z/6Amlf+AiVxm32o2+1Hso9g9n5v7zs/+E4s/wDoCaV/4CJR/wAJxZ/9ATSv /ARK4zb7Ubfa
j2Uewez83952f/CcWf8A0BNK/wDARKP+E4s/+gJpX/gIlcZt9qNvtR7KPYPZ +b+87P8A4Tiz
/wCgJpX/AICJR/wnFn/0BNK/8BErjNvtRt9qPZR7B7Pzf3nZ/wDCcWf/AEBN K/8AARKP+E4s
/wDoCaV/4CJXGbfajb7Ueyj2D2fm/vOz/wCE4s/+gJpX/gIlH/CcWf8A0BNK /wDARK4zb7Ub
faj2Uewez83952f/AAnFn/0BNK/8BEo/4Tiz/wCgJpX/AICJXGbfajb7Ueyj 2D2fm/vOz/4T
iz/6Amlf+AiUf8JxZ/8AQE0r/wABErjNvtRt9qPZR7B7Pzf3nZ/8JxZ/9ATS v/ARKP8AhOLP
/oCaV/4CJXGbfajb7Ueyj2D2fm/vOz/4Tiz/AOgJpX/gIlH/AAnFn/0BNK/8 BErjNvtRt9qP
ZR7B7Pzf3nZ/8JxZ/wDQE0r/AMBEo/4Tiz/6Amlf+AiVxm32o2+1Hso9g9n5 v7zs/wDhOLP/
AKAmlf8AgIlH/CcWf/QE0r/wESuM2+1G32o9lHsHs/N/edn/AMJxZ/8AQE0r /wABEo/4Tiz/
AOgJpX/gIlcZt9qNvtR7KPYPZ+b+87P/AITiz/6Amlf+AiUf8JxZ/wDQE0r/ AMBErjNvtRt9
qPZR7B7Pzf3nZ/8ACcWf/QE0r/wESg+OLPH/ACBNK/8AARK4zb7Ubfaj2Uew ez83952P/Cb2
n/QG0n/wEWj/AITe0/6A2k/+Ai1xuz/Z/WjZ/s/rR7KPYfs13Z2X/Cb2n/QG 0n/wEWj/AITe
0/6A2k/+Ai1xuz/Z/WjZ/s/rR7KPYPZruzsv+E3tP+gNpP8A4CLR/wAJvaf9 AbSf/ARa43Z/
s/rRs/2f1o9lHsHs13Z2X/Cb2n/QG0n/AMBFo/4Te0/6A2k/+Ai1xuz/AGf1 o2f7P60eyj2D
2a7s7L/hN7T/AKA2k/8AgItH/Cb2n/QG0n/wEWuN2f7P60bP9n9aPZR7B7Nd 2dl/wm9p/wBA
bSf/AAEWj/hN7T/oDaT/AOAi1xuz/Z/WjZ/s/rR7KPYPZruzsv8AhN7T/oDa T/4CLR/wm9p/
0BtJ/wDARa43Z/s/rRs/2f1o9lHsHs13Z2X/AAm9p/0BtJ/8BFo/4Te0/wCg NpP/AICLXG7P
9n9aNn+z+tHso9g9mu7Oy/4Te0/6A2k/+Ai0f8Jvaf8AQG0n/wABFrjdn+z+ tGz/AGf1o9lH
sHs13Z2X/Cb2n/QG0n/wEWj/AITe0/6A2k/+Ai1xuz/Z/WjZ/s/rR7KPYPZr uzsv+E3tP+gN
pP8A4CLR/wAJvaf9AbSf/ARa43Z/s/rRs/2f1o9lHsHs13Z2X/Cb2n/QG0n/ AMBFo/4Te0/6
A2k/+Ai1xuz/AGf1o2f7P60eyj2D2a7s7L/hN7T/AKA2k/8AgItH/Cb2n/QG 0n/wEWuN2f7P
60bP9n9aPZR7B7Nd2dl/wm9p/wBAbSf/AAEWj/hN7T/oDaT/AOAi1xuz/Z/W jZ/s/rR7KPYP
Zruzsv8AhN7T/oDaT/4CLR/wm9p/0BtJ/wDARa43Z/s/rRs/2f1o9lHsHs13 Z2X/AAm9p/0B
tJ/8BFo/4Te0/wCgNpP/AICLXG7P9n9aNn+z+tHso9g9mu7Oy/4Te0/6A2k/ +Ai0f8Jvaf8A
QG0n/wABFrjdn+z+tGz/AGf1o9lHsHs13Z2P/Cc2YB/4kmln/tzSu70j4ZeN PEehWer2nhDw
/DYXiebbSand2Fk0sfQOqTzIxU4OGxg9q8NmBTt1r778I63pS2HhHT9euJ7b SDoeii4ntkDS
RqdLteQCDwCQTwTjOATgH8z474kxHCuEo18LTjKVSXL717LRvo1+Z+icF8L0 OJMXVo15yUYQ
5vd3eqXVPv2Pneb4Q+NiuG8N+Ch7/wBvaOP/AG5rmPF/hfxj8PNMXxJPoOk2 lrYXER/tPw/q
VpcyWU27MTl7WZ2hO4fKx2/MBg5xX2PcfBLUbHxHe3Gv6ra2HgCxgS+m8SxY aO5tn/1awAZz
K/Tb82CQRv3RiT5q8dTWl34O+K72LTPYHQo/INyoWQx/21puwuFJAbb1wSMk 4NflWT+KGcY7
NsLl+Kw9NRrTUHZSTs3a6vJ6fKzP1TMPDTJsNlmJx+ExNScqUebdct97NpKz t0vdaXR6F8C/
+CqOg+BfAUOhfE+18Ra9rtlM0VtqOmQQTNNaBV8vz3lnQvMG3qWx8yqhYs5Y kr8zfE6ldS5B
B2d/qaK+9x/DOVzxVSTptNt7Oy+S6HyWGxVZUYLmvp11Z9EfBvXZ/Cep6Lrd rjzrKVJUOAfr
wePzr7a079qG+ltNR1KPUB/a+ozbndI1Eca7FUEp3xg8YyfUZzXx/wDAn4K/ EH4uaLM3gnw6
NbSwjha5P223t9nmbwn+tdc5McnTONvPUV69B+x98eIlAPw/J/7jNh/8er6z iTDZJj8Qo4rF
Qp1YKzu43tvZptPzPyueEzVylUwkZcrb2TtpdX06rVfeV/j3qum3eu3OnaJ4 gl8U2AWILqUs
JiLAKCV2nphsjjHc98123w5/aG0D4faf8DNJkhg1FNFg1xNdd9J33Om/abqM 28tvdPHlX2mR
isT/ADAYcZCY5U/sh/HY9fh83/g5sP8A49UbfsffHdjkfD8j/uM2H/x+uZUe G54Gnga2Ng4x
bk3zwTbcXB37aS0t1SNMDh84y+tOtQwzTl5SaWqel7vpbVvT7zqvAniz4beH /D+k6JeePp/I
8PfFOPxdBqNzpOoXMup2yQeXlsQ7hIzMS7OAMhiCwIJg0b46eHLIWItNbvrM Xfxyu/Fk4Szu
ot+iMZj50n7sYViY/wB03znj5OK5r/hjz47/APQgH/wc2H/x+j/hjz47/wDQ gH/wc2H/AMfr
CWD4cnUc55hF3tpz07dL9OtvTt2PaWKzqMFBYR6X1tLz/K55d49vrfxf8RPG WuWLSS6dqWv6
ld2ckkTQs9u93K0LbHCsuYypwwB9RWH/AGWf7v617b/wx58d/wDoQD/4ObD/ AOP0f8MefHf/
AKEA/wDg5sP/AI/X2OHzvJMPRhRWMptRSV3ON9FbufN18tzWvVnV+ryXM27W el3c8S/ss/3f
1o/ss/3f1r23/hjz47/9CAf/AAc2H/x+j/hjz47/APQgH/wc2H/x+uj/AFhy X/oLp/8Agcf8
zD+yM1/58S+5niX9ln+7+tH9ln+7+te2/wDDHnx3/wChAP8A4ObD/wCP0f8A DHnx3/6EA/8A
g5sP/j9H+sOS/wDQXT/8Dj/mH9kZr/z4l9zPEv7LP939aP7LP939a9t/4Y8+ O/8A0IB/8HNh
/wDH6P8Ahjz47/8AQgH/AMHNh/8AH6P9Ycl/6C6f/gcf8w/sjNf+fEvuZ4l/ ZZ/u/rR/ZZ/u
/rXtv/DHnx3/AOhAP/g5sP8A4/R/wx58d/8AoQD/AODmw/8Aj9H+sOS/9BdP /wADj/mH9kZr
/wA+JfczxL+yz/d/Wj+yz/d/Wvbf+GPPjv8A9CAf/BzYf/H6P+GPPjv/ANCA f/BzYf8Ax+j/
AFhyX/oLp/8Agcf8w/sjNf8AnxL7meJf2Wf7v60f2Wf7v617b/wx58d/+hAP /g5sP/j9H/DH
nx3/AOhAP/g5sP8A4/R/rDkv/QXT/wDA4/5h/ZGa/wDPiX3M8S/ss/3f1o/s s/3f1r23/hjz
47/9CAf/AAc2H/x+j/hjz47/APQgH/wc2H/x+j/WHJf+gun/AOBx/wAw/sjN f+fEvuZ4l/ZZ
/u/rR/ZZ/u/rXtv/AAx58d/+hAP/AIObD/4/R/wx58d/+hAP/g5sP/j9H+sO S/8AQXT/APA4
/wCYf2Rmv/PiX3M8S/ss/wB39aP7LP8Ad/Wvbf8Ahjz47/8AQgH/AMHNh/8A H6P+GPPjv/0I
B/8ABzYf/H6P9Ycl/wCgun/4HH/MP7IzX/nxL7meJf2Wf7v60f2Wf7v617b/ AMMefHf/AKEA
/wDg5sP/AI/R/wAMefHf/oQD/wCDmw/+P0f6w5L/ANBdP/wOP+Yf2Rmv/PiX 3M8S/ss/3f1o
/ss/3f1r23/hjz47/wDQgH/wc2H/AMfo/wCGPPjv/wBCAf8Awc2H/wAfo/1h yX/oLp/+Bx/z
D+yM1/58S+5niX9ln+7+tH9ln+7+te2/8MefHf8A6EA/+Dmw/wDj9H/DHnx3 /wChAP8A4ObD
/wCP0f6w5L/0F0//AAOP+Yf2Rmv/AD4l9zPEv7LP939aP7LP939a9t/4Y8+O /wD0IB/8HNh/
8fo/4Y8+O/8A0IB/8HNh/wDH6P8AWHJf+gun/wCBx/zD+yM1/wCfEvuZ4l/Z Z/u/rR/ZZ/u/
rXtv/DHnx3/6EA/+Dmw/+P0f8MefHf8A6EA/+Dmw/wDj9H+sOS/9BdP/AMDj /mH9kZr/AM+J
fczxL+yz/d/Wg6WcdP1r23/hjz47/wDQgH/wc2H/AMfoP7Hnx3I/5J+f/BzY f/H6P9Ycl/6C
6f8A4HH/ADD+yM1/58S+5niH9lN6Cj+ym9BXtv8Awx18d/8Aon5/8HFh/wDH 6P8Ahjr47/8A
RPz/AODiw/8Aj9P/AFhyX/oMp/8Agcf8w/snNf8AnxL7meJf2U3oKP7Kb0Fe 2/8ADHXx3/6J
+f8AwcWH/wAfo/4Y6+O//RPz/wCDiw/+P0f6w5L/ANBlP/wOP+Yf2Tmv/PiX 3M8S/spvQUf2
U3oK9t/4Y6+O/wD0T8/+Diw/+P0f8MdfHf8A6J+f/BxYf/H6P9Ycl/6DKf8A 4HH/ADD+yc1/
58S+5niX9lN6Cj+ym9BXtv8Awx18d/8Aon5/8HFh/wDH6P8Ahjr47/8ARPz/ AODiw/8Aj9H+
sOS/9BlP/wADj/mH9k5r/wA+JfczxL+ym9BR/ZTegr23/hjr47/9E/P/AIOL D/4/R/wx18d/
+ifn/wAHFh/8fo/1hyX/AKDKf/gcf8w/snNf+fEvuZ4l/ZTego/spvQV7b/w x18d/wDon5/8
HFh/8fo/4Y6+O/8A0T8/+Diw/wDj9H+sOS/9BlP/AMDj/mH9k5r/AM+Jfczx L+ym9BR/ZTeg
r23/AIY6+O//AET8/wDg4sP/AI/R/wAMdfHf/on5/wDBxYf/AB+j/WHJf+gy n/4HH/MP7JzX
/nxL7meJf2U3oKP7Kb0Fe2/8MdfHf/on5/8ABxYf/H6P+GOvjv8A9E/P/g4s P/j9H+sOS/8A
QZT/APA4/wCYf2Tmv/PiX3M8S/spvQUf2U3oK9t/4Y6+O/8A0T8/+Diw/wDj 9H/DHXx3/wCi
fn/wcWH/AMfo/wBYcl/6DKf/AIHH/MP7JzX/AJ8S+5niX9lN6Cj+ym9BXtv/ AAx18d/+ifn/
AMHFh/8AH6P+GOvjv/0T8/8Ag4sP/j9H+sOS/wDQZT/8Dj/mH9k5r/z4l9zP Ev7Kb0FH9lN6
Cvbf+GOvjv8A9E/P/g4sP/j9H/DHXx3/AOifn/wcWH/x+j/WHJf+gyn/AOBx /wAw/snNf+fE
vuZ4l/ZTego/spvQV7b/AMMdfHf/AKJ+f/BxYf8Ax+j/AIY6+O//AET8/wDg 4sP/AI/R/rDk
v/QZT/8AA4/5h/ZOa/8APiX3M8S/spvQUf2U3oK9t/4Y6+O//RPz/wCDiw/+ P0f8MdfHf/on
5/8ABxYf/H6P9Ycl/wCgyn/4HH/MP7JzX/nxL7meJf2U3oKP7Kb0Fe2/8Mdf Hf8A6J+f/BxY
f/H6P+GOvjv/ANE/P/g4sP8A4/R/rDkv/QZT/wDA4/5h/ZOa/wDPiX3M8S/s pvQUf2U3oK9t
/wCGOvjv/wBE/P8A4OLD/wCP0f8ADHXx3/6J+f8AwcWH/wAfo/1hyX/oMp/+ Bx/zD+yc1/58
S+5niX9lN6Cj+ym9BXtv/DHXx3/6J+f/AAcWH/x+j/hjr47/APRPz/4OLD/4 /R/rDkv/AEGU
/wDwOP8AmH9k5r/z4l9zPEv7Kb0FB0psdBXtv/DHXx3/AOifn/wcWH/x+j/h jr47/wDRPz/4
OLD/AOP0f6w5L/0GU/8AwOP+Y/7JzX/nxL7meIf2Y3ofyo/sxvQ/lXt3/DHX x4/6J9/5WbD/
AOPUf8MdfHj/AKJ9/wCVmw/+PU/9Ycl/6C6X/gcf8x/2Tmv/AD4l9zPEf7Mb 0P5Uf2Y3ofyr
27/hjr48f9E+/wDKzYf/AB6j/hjr48f9E+/8rNh/8eo/1hyX/oLpf+Bx/wAw /snNf+fEvuZ4
j/Zjeh/Kj+zG9D+Ve3f8MdfHj/on3/lZsP8A49R/wx18eP8Aon3/AJWbD/49 R/rDkv8A0F0v
/A4/5h/ZOa/8+JfczxH+zG9D+VH9mN6H8q9u/wCGOvjx/wBE+/8AKzYf/HqP +GOvjx/0T7/y
s2H/AMeo/wBYcl/6C6X/AIHH/MP7JzX/AJ8S+5niP9mN6H8qP7Mb0P5V7d/w x18eP+iff+Vm
w/8Aj1H/AAx18eP+iff+Vmw/+PUf6w5L/wBBdL/wOP8AmH9k5r/z4l9zPEf7 Mb0P5Uf2Y3of
yr27/hjr48f9E+/8rNh/8eo/4Y6+PH/RPv8Ays2H/wAeo/1hyX/oLpf+Bx/z D+yc1/58S+5n
iP8AZjeh/Kj+zG9D+Ve3f8MdfHj/AKJ9/wCVmw/+PUf8MdfHj/on3/lZsP8A 49R/rDkv/QXS
/wDA4/5h/ZOa/wDPiX3M8R/sxvQ/lR/Zjeh/Kvbv+GOvjx/0T7/ys2H/AMeo /wCGOvjx/wBE
+/8AKzYf/HqP9Ycl/wCgul/4HH/MP7JzX/nxL7meI/2Y3ofyo/sxvQ/lXt3/ AAx18eP+iff+
Vmw/+PUf8MdfHj/on3/lZsP/AI9R/rDkv/QXS/8AA4/5h/ZOa/8APiX3M8R/ sxvQ/lR/Zjeh
/Kvbv+GOvjx/0T7/AMrNh/8AHqP+GOvjx/0T7/ys2H/x6j/WHJf+gul/4HH/ ADD+yc1/58S+
5niP9mN6H8qP7Mb0P5V7d/wx18eP+iff+Vmw/wDj1H/DHXx4/wCiff8AlZsP /j1H+sOS/wDQ
XS/8Dj/mH9k5r/z4l9zPEf7Mb0P5Uf2Y3ofyr27/AIY6+PH/AET7/wArNh/8 eo/4Y6+PH/RP
v/KzYf8Ax6j/AFhyX/oLpf8Agcf8w/snNf8AnxL7meI/2Y3ofyo/sxvQ/lXt 3/DHXx4/6J9/
5WbD/wCPUf8ADHXx4/6J9/5WbD/49R/rDkv/AEF0v/A4/wCYf2Tmv/PiX3M8 R/sxvQ/lR/Zj
eh/Kvbv+GOvjx/0T7/ys2H/x6j/hjr48f9E+/wDKzYf/AB6j/WHJf+gul/4H H/MP7JzX/nxL
7meI/wBmN6H8qP7Mb0P5V7d/wx18eP8Aon3/AJWbD/49R/wx18eP+iff+Vmw /wDj1H+sOS/9
BdL/AMDj/mH9k5r/AM+JfczxH+zG9D+VH9mN6H8q9u/4Y6+PH/RPv/KzYf8A x6j/AIY6+PH/
AET7/wArNh/8eo/1hyX/AKC6X/gcf8w/snNf+fEvuZ4j/Zjeh/Kj+zG9D+Ve 3f8ADHXx4/6J
9/5WbD/49R/wx18eP+iff+Vmw/8Aj1H+sOS/9BdL/wADj/mH9k5r/wA+Jfcz wyXTSAcjmvrL
RLzRZPFvhvTvEOoyaXo/9haH9puYYzI6J/ZNqeFAJyTgZwcZzg4wfPZP2Nvj w5H/ABb/AP8A
KzYf/H67eP4E/Hiax0+HVvgjoHiC5sraOzjv7zXRBO0MYCxo/wBm1CJW2qAo YqW2qAScCvyH
xJw+F4pwOHo5djKPNTnzNSqJJqzXQ/WfDvMKnDONxFbMcPV5alNxThG7T5k7 66dD0+7+PHhD
xNNL4Q1rQ4rD4Zui29ktsv8ApemupbbdhvmLOSxLj5uD/H84l+aNc+yNoHxY srG6N9ZRaAqw
XLR+WZYxrWmhXKZO3IwcZOM4zXpDfs//ABkYYP7PHhjHf/ip7r/5bVjeIv2f vjtc+H9S0fTP
g9oPhe31IRpfSadraTT3EaOJFjL3F9MVTeqMQm3JRc5wK/Gsh4OxuFz3BZhj cbhuSjUjJ2qq
/KmnZJdNNF09D9dzbjLKquS4zAYDDV1OtDlSlH3eb+Z6t3fV9euup+f3i63E OsMvX5Qf1NFL
42bfrr5+VggBB7HJor+psa19ZqWXVn4lhbuhBvsfqN/wSd/5Fvxr/wBe+mf+ h3tffdfAn/BJ
3/kW/Gv/AF76Z/6He103wYg1D4v2f7RvizxL8RfEHh3WvC/xA17SNG1xvEF5 baXodrZQw/Zp
JLBLiKzlih/1jrMhWXDeaWDMa/AeOP8AkocV6x/9IifR5L/uMPWX/pUj7Vor 418M/tU/GHWo
/jL4vbw/4Hm+HXwv8QeKtN1CIXN5Bq+oRada+baJENrxIxfaJJWJDK52xIY8 yHwW/a5+IXif
Wvhne+JtLt73wT4m8P3Or+INeh8Fav4fsfCrR2SXUbyaheSy291A+Jo/MQov COHwQrfCnuH2
VRXxr4U/bD8XeKfjD8NfCdlPo99pvxJ0zVbnTL9vBus6bDpMsNot1bSLPePE NXgKllZoUtiw
2P8Aut4SvKvgZ+1D8Tvhn+w58I/Fmr65b+MtS8beLYfDFjfarpt/qV9pyy39 8J57gJctLqTB
INsUMQgYZVcyYAIB+j9FeFfs3fGDx18R/E3xB0bxf4euINN0KaxbRvFDeGNR 8Ow6zFPAWlRb
O+LyK0EsbqzeYQwdDtXgsftZfGbxV8HNK+GcfhBdHGpeL/HOmeE5LjW7OW6h torpZszCOOaE
sytGhxvAIyOMggA91or4g0P9tH4i2+q6PJrNn4Xv9Ni+MEnwh1O3sdPubWa6 lLSbNTgka5kE
ChTCDbMkpYxyETL5gEer4i/be1Ow8feA59Au9H8V+CfFXjmLwfGlj4a1aKFY pJZ7cXcGuybb
O6YSRK5hihIIMiLI4jM5APsqivhX4YftrfFPXvhP8CfiT4k0rwf/AGL8QvGc Pg240fS7e6S4
Xzp7uFb1J3mZYtjQKDbmOXeELechl2RdB4i/be1Ow8feA59Au9H8V+CfFXjm LwfGlj4a1aKF
YpJZ7cXcGuybbO6YSRK5hihIIMiLI4jM5APsqivhXwz+2b8U/Efwz+CXxP8A L8H2/hv4lfEC
38Kf8I5/ZF015p1rLe3UG/7b9sCSyhLbr9nRSz52gDBPg1+278UPixp3w18U 2HhH+2NF8V+J
jpmoeH9M8F6yv9iaa9xPALxtcLtZ3Hk7IWkCxJnc6/uypKgH3VRRXxr4i/be 1Ow8feA59Au9
H8V+CfFXjmLwfGlj4a1aKFYpJZ7cXcGuybbO6YSRK5hihIIMiLI4jM5APsqi vhX4YftrfFPX
vhP8CfiT4k0rwf8A2L8QvGcPg240fS7e6S4Xzp7uFb1J3mZYtjQKDbmOXeEL echl2Ref+OPj
F44/aL+Gf7LvxP1ubw/pvhvXvjNpX2Hw5p+mTi8svKvb2CPzb17lkn+SE7tt vFlnBG0LggH6
VUV86/tKfG/4i+AfjD8Ivh/8OdM8L3+peO4deUyeKHuYoYJbO0SaF/Mg3EKG diy7GLhQoaLd
5i8ppv7UHxF05v2mdM8Raf4XbXfhN4S0vVbdtLhufs1zqE2jy3lwrl5dzwCe LCACNvLOGJbk
AH1rRXwV4O/bR+MPxA8L/FnV9Ps/A+l2/gPwNoXjBpbnT7ydrmW70P8AtCW0 ES3KAK0gcLN5
mYlRVMc5kLx+1/GH9qm+8A/sQn47aZ4ft5NSu/D+mara6Pd3LPDBLfG3RFd1 VTIsbXAJACFw
hAKbsqAfRVFfNXxs+MXxT+BeheD7K/m8H6/rXjHxnpHhTTdct9MurW3sftbS +c81gbmRpfLW
EbSt0m8z4KoIczeVeOf21vin8P8A4mat8OP7K8H+I/Eml/EDwt4Y/tP7Pdab Z3trrFlNPt8r
zrh7eWN4NvnbplKvnySVwwB91UV+cH7ZHx4+IusfAb9qL4fanqej2+peAZvD sV1rug2NzYjV
NP1Tyi9ssLXUhgYMSruZJVliZ4zGu7eDT/im37M/x++J3gvwL4H8D6BruseL fAXg9tX0vTbq
2sfNv7GeWW7fT1uigVCkoSGF4T+9zJJKyksAfo/RXwrr/wC2b8U/Anx21L4c avH4P1r+z/iB
4O8KPqdlpF1Z+ba6va3M87iJryXbKnlRqh3FfvEqcgLb+L37bXxF8E/H7xR4 B8P6F4X1C30/
xz4P8LWI1IXMLTRatY3M85lmR2CMJIUVJFiYIpYmOQ4oA+36K+avEXxu8eeC dO8I+EfFWveD
7D4sXtlearqtv4W8L634niS1juBFC0Vha7J0icSKGuJpVUSRMiJJvLRfP+gf tHfFP9oHx3+x
74n0TX9P8Ef8JnZeKI77RhbXV3p0t1ZRPHJLcQpdw/aIm8sPDExDQMWJkmzw AforRX56/B34
/wCvaT8Yda+GngXQPC/hTUvGfxg8a291rd3b32oQ4060t53me2a8QtPO0iAm OWKJBGdsXzcd
B4X/AG1vin4u+LHhL4bWGleDxrV34z8X+DdS1i4t7pLd/wCyYIJob2GATM0f yzktbtI/mGLa
JoRJvjAPuqivhXUP22vinbeFb66/4RTTzYeGPiBrfg/xd430zQ7rVLPTbWxR Xjv20uO5SdIn
EmZH+0SLEtu5+dpY0H1r8F/H8PxS+F/h/wAU2+raPr1vqULSR6noJkFpdKHZ RIscg3wsQuXg
cs0L74i8hjLsAdrRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUVi+J/GW ieDLRLjWdRhs
UkO2JHJaSVv7scags59lBNcgfjZFOxax8H+JtQt/4Z0gt4A3/AZp43H4qKxn Wp03aT1Jcox3
Z6TRXnNt8ddBjlEetWOq+GM8ebqlsphH+9LC0kaD3ZgK9At7uC7to7iCaOe3 kUOksbBlcHoQ
RwRThVhU+B3BSUtUyaoJbpY845I/Ko5rgtkD5VrMuJi+QOF/nXVGF9xOVhbz UpJMqrYHqKzy
cnJ5NSSd6irrikloZN3P56vGv/IxXH4UUeNf+RiuPwor+psZ/vFT1Z8VhP8A d4eiP1I/4JO/
8i341/699M/9Dva+prr9l/4c3Ou63qg0jULT+3b1tQ1fTLHXdQttL1Kd1VJX udPinW1m81UU
SiSJhLz5gfc2fln/AIJPf8i341/699M/9Dva++6/A+OP+ShxXrH/ANIifRZL /uMPWX/pUjiv
C/wX8FeDtK8YaZpnh+3Gm+L9TvNY12zu3e6hv7q6ULcs6TMw2yKoBjACYyAo ya5/wt+y/wDD
nwlZ2tjb6RqGqaVaWTafa6T4h13UNYsLaBoTAyRWt5PLDH+5Z4cogPlySR52 Oynqtf8Aix4H
8KeKtN8Ma34y8P6N4k1Ly/sOj6hqkEF5deY5jj8qF3DvudSi7QcsCByK6uvh T2zx/wAI/smf
DPwR4m8Ja/pml6w+peEoZbbQDqXibVL+HS4pIPIeOCG4uXjRTFhNoXGFXH3R gj/ZJ+FcHhm4
8Ow+HLi30J9Ti1m10+DWL6OHSr2OeSdJ9OVZgNPYSSyH/RPKyGKnK8V7BVTS dWsdf0qy1PTL
231HTb2FLm1vLSVZYZ4nUMkiOpIZWUghgSCCCKAPCviv+x7oHxF8CJ4QtNX1 Cx0XUta0688T
NrN3d61ea5ptpKZhppu7m4NxBEZCHUxyfu2MhVcyybvVfH/wt8MfFD/hHP8A hJ9M/tP/AIR3
WrbxDpf+kSxfZ7+33eTN+7Zd23e3ytlTnkGurooA8q/4Zc+GH/Qs/wDM5/8A Cwf+P+6/5Dv/
AD9/63/yF/qv9ism1/Y2+EtleaJLb+H9Qt7TQ9aXxDpWkReIdSXS9Pv1maZZ oLAXH2aLEkjk
KkYUb2GMEiva6qatq1joGlXup6ne2+nabZQvc3V5dyrFDBEilnkd2ICqqgks SAACTQB5rpn7
Lnww0bwJ4J8G2fhnyfDfgvWo/EOg2X2+6b7HfpLLKk28yl5MPPKdsjMvzYIw ABk2v7G3wlsr
zRJbfw/qFvaaHrS+IdK0iLxDqS6Xp9+szTLNBYC4+zRYkkchUjCjewxgkV6X 4S8eaN42thJp
k9xHceSty+n6lZT2F9DE0ksccktrcIk0Su8EwRnQB/LYrkDNdBQB8VXn7EWs ap4q+G8Vt4c8
H+ENF8IeM7fxS2qaVr+pXm9IXmmkt7DSbiHydMiup3jeSGC4KJsTPnmJDX0B 4W/Zf+HPgq8t
ZNF0jULGwtb1tQttCXXdQbRreczGcPHprTm0TbM3moFiAjcK6BWVSPVaydS8 WaHo39q/b9Z0
+x/smyXUtQ+03SR/Y7U+Zi4myR5cR8ibDthf3UnPynABwH7N/wAC/wDhQfgT UNKvNb/4SjxJ
rWtX3iHXvEH2T7H/AGlf3MpZ5vs4d0hwgiTbGQv7vcACxrJtf2NvhLZXmiS2 /h/ULe00PWl8
Q6VpEXiHUl0vT79ZmmWaCwFx9mixJI5CpGFG9hjBIr2uigDyrTP2XPhho3gT wT4Ns/DPk+G/
BetR+IdBsvt9032O/SWWVJt5lLyYeeU7ZGZfmwRgADJtf2M/g7Z3miXEPg/Z /YOtLr+jW/8A
ad4bfSbwTNOTZw+d5dtE0r73giVYnKR70by02+waTq1jr+lWWp6Ze2+o6bew pc2t5aSrLDPE
6hkkR1JDKykEMCQQQRVTWfFOl+H9R0Kwv7r7Pd65etp+nx+WzefOtvNclMgE L+5tpmy2B8mM
5IBAMrxF8LfDHivx34R8Zarpn2rxJ4T+2f2Le/aJU+y/aohFcfIrBH3IoHzq 2MZGDzXK+O/2
XPhh8Std17V/EPhn7Zd+ILKOw1mOK/ure31SONXWFrqCKVYp5YhIfKmkVpIi sZRlMaFfVaKA
PKvDv7Lnww8KaP4u0rSvDP2Ww8WaLZ+Htah+33T/AGqwtbM2VvDlpSU227FN yFWOdxJbmug1
P4L+Cta+EafDDUPD9vf+BE0yHR10e5d5FW1iRUiUOzFwyBEKybt6sqsGDAGt /wATeKdL8H6d
Df6vdfZLSa9tNPSTy2fM9zcR20CYUE/NNNGueg3ZJABI1qAPKr79l/4c6voU ul6npGoavvvb
XUE1PVNd1C71S3ntmZ7Z4NQlna6h8pnlKCOVQvnTYA82TdUt/wBkn4Vw3MF3 L4cuL/UovEFl
4o/tTUtYvry+l1GzjMVpLLczTNLKsSFlSJ3aMbm+T5jn2CsnxT4s0PwNoV1r fiTWdP8AD+i2
u37RqOqXSW1vDuYIu+RyFXLMqjJ5LAdTQBwHjD9lz4YePf8AhYP9u+Gft3/C f/2f/wAJJ/p9
1H9v+w7fsn3JR5Wzav8Aq9u7Hzbq5/4ufsweGvFFz4h8RaN4Q0fVvFmu6npe p6m2ravf6e1x
LYRvHZy215bl30+eEOCJYIiXUPGw/emRPVfBXxC8K/ErSpdT8IeJtH8VabFM baS80S/ivIUl
CqxjLxswDBXQ7c5wwPcUeFfH/h3xtJfRaJq1vf3FjNNb3VupKzQtFdXFo5aN gGC+faXMavja
5hcqWAzQB81fCX9h7ToPE3xQ1z4gaJo8Fv4s1PRdR07RtB1e9uZtKuNNgYLf rqjJb3Ju5ZpZ
pHlAWQlnLSSGV69Ks/2M/g7Ya6dag8H7dVbWtN8RSXbaneM82pWCyra3UhMx 8yUefMzs2fOe
Rnl8xyWr2uigDz/x18CPBnxE8VWPifVbLULTxJZ2T6bHrGhaze6ReNau6yG3 kms5onki3qHC
OWVWLEAFmzz9p+yT8K9N8G+EPDGn+HLjStN8ITXNxoM+m6xfWt9pzXBkNwIr 2KZbgLJ5r708
za3y5B2rj2CigDx+4/ZJ+Fc1zPdxeHLiw1KXxBe+KP7U03WL6zvotRvIxFdy xXMMyyxLKgVX
iR1jO1fk+UYt+Gf2XPhh4P13wzreleGfI1rw7e6lqVhqMt/dTXButQUJe3E8 kkrNcyyqFUvO
ZGAVQpAUY7WTx/4dh8ZN4Tm1a3g8QiG3uFsZiY2lWcXRiEZYASMVsLxtiEsF gdiAME9BQB5V
F+y/8ObT+1nsNI1DRrvVdavNfu7/AEbXdQsLyS8u/L+1EXEE6SrFKYYWaBWE RaGNtmUUjtfA
HgDw78LPBuk+E/Cek2+h+HtKhFvZ2NsDtjXJJJJJLMzFmZ2JZmZmYkkk2pvF mh232zzdZ0+L
7Hewabc77pB5F1N5Xk275PyyyfaINqH5m86PAO9c61ABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABXIfE/wAfp8P/AA8txFCLzVbyUWun2ZOPNmIJBb0RQCzH0GByQK6+vm34 p69/avxsnhlf
NtoFlHBEh6LLMBLI31KeSP8AgNceLrOjSclu9DlxNb2FJzOs8C+CXur5tZ1u 4OseIrlQJr6c
D5R/cjXpGg7KvHc5JJPYaDqWleIIpFtJl86IlZIG4dCDg8dx7iuf8EeJI3RX 3Dnp9Kj8FeEb
Txr4GtL7zJLPUUnuDDe27bZE/fPjnuPY8V5EnOM4QpRUm1JtPrbl699eu5x0 pc1uXVu7/I0v
EmlRmJwVVhjoRXlWn+KLj4Qa19pszI/hmSQtf6UgysYPWeEfwsOrKOHGeN2D XT+JfFOu+BSb
fxZam407O2PXLSMlPbzkH3D7jivOPHOu289qLm3lSeF8MrxsGVgfQjrWaqwl Lmp+7Jbp6Neq
7fg+5x166pS54aNdD6hW9ivbeKa3kWa3lUSJIhyrqRkEH0xUDkDOeK8s/Z48 RSah4Ak09nLn
SLySyjZjyIsLJGPoqyBB7JXocrs5O4k19hh5e1pxn3PXjUVSKmupLNdRrkZy faqrX3on5mop
OtQnrXcooVz+f7xr/wAjHdfh/Kijxr/yMd1+H8qK/p7F/wC8VPV/mfHYT/d6 fovyP1J/4JO8
+G/Gv/Xvpn/od7X33XwJ/wAEnP8AkW/Gv/XDTf8A0O9r77r8E44/5KHFesf/ AEiJ9Fkv+4w9
Zf8ApUjxT4deIk+F2sax4X8TaV4gl8Ra34mv9Qj1jT/D99qNnfQXV45snlvY IXji8m2NvasL
hozEtoAB5CwyP4XfeE/iVYfBf4Krq3ivxxbw33h833iu9u7DXdV1JdYa2sFt rd4NJubW8hVI
1vVPPlFkLXAkuZVlP2/RXwp7Z8a+KNS+K1p4++Hk1zP4otfENhN4b025SLQd UuYdatZZbUan
e3DWN0+jWTAT38bxTRTOgtvMjlAe2dOU07wT4r8K/Bf4TeGLG/8AHHhbSNG0 yWw8WiXTPFGr
TR69DbafHFFbrYXcF19kCrf7JLaRtPyvALtEw+9aKAPCvijJ4yt/2efDNhfN rFxrd3DY23iH
XbayuzfWDLD5klybLRrlJ5Ge4jjhaKzuNqfaGcs8MThuf8LX3xA1D9km1e9l 8QXGuRa01tdz
rp97YapLoEWumOV44Ji16sraUjMmWe7bKsrvOQ7fStFAHx/48/tX+zrz/hEP +FoeT/wjI/4V
15v/AAkHm/8ACRfaL/zv7T875/K3/wBmbf7W/wBG8vds/dedWB8XPAfjo/Bf xde6dB441bxD
4n1Px3o+pabcXuo38L6WbbXjp6xWUjvFArPBpaxSQxozB40ViJir/b9FAHyr 8QfDPiHwf8Rz
pFvN8QLj4TW9lov9ryafqWsahemNj4haXyJ4pJL15ftbaP5n2djIIvKD4gDA eaaF488XaV8G
fitcafP8SNWt9b8P65o/gmWGy1nVL6HULbWvEMSLIQkk9nOsUulp5lz5bHy0 G4mBwn2/4p8J
6H450K60TxJo2n+INFutv2jTtUtUubebawdd8bgq2GVWGRwVB6irek6TY6Bp VlpmmWVvp2m2
UKW1rZ2kSxQwRIoVI0RQAqqoACgAAAAUAfMGpaR40074ReKLm+u/GFze694z 1a2uLyc6rcy6
BpMWrX72T2llp0sF5NE+23jHkyBzHdozO1rbpEvlWl6J48l8IeOPE+rR/ECb xrd/D/VNF8H6
hpllrdi9zNZXfiIQG4tg7PHL9ln054G1AtM7yAxyST+Y1ff9FAHxV8U/+Fkf 2P45/wCEf/4W
B/wsn/iq/wC0Psv9p/2d/ZH2PU/7G+wf8uP2nf8A2Jj7H/pW7zN/zfaa+gPh p4Z1DwL8U/F/
h61m8QXPgxNF0m/sZtd1K81P/T5Z9RS7WO7u5JJDiKCxJhD7U3KwVTKxf1Wi gD4q+HHhY+Bv
hZ8LPDfiC1+KFl4W0fRZtP8AFFtpMniKS8h8RxQabHCkDWpNy1iI11EKbUmw LAYJbyq9L8Vx
fEmH4ffs/wCr6h4buPFXxF0aY6hrOmwyQwrLqI8L6ojpJPGDBAsl3IkXmf6s NKmOCAfoqigD
4g+GGseP/CnjeC6m1Pxx4g+HWh6np+o38zeF/EtvMwnsNbtp41ttSmur68VZ /wCx2ZImeKMl
JBGhWWQlhpnxC8VaB8XPGIf4kQavpHh/UtX8E20tzq9iJL3+2/Ectqh09mRb hvITSgLeeJ/3
RgQpsYKft+igD4/8a+Fr3xpYeIdH121+IF346uPGenm5W3k1qLS00VPFdm9t LaSREWMUqaet
s7SWxWdNkzOyus5HsHgRfFXgbQ/izYafpeseJU0DU3HhLTtb1KVptRiOk2Vw IRf3Rd5Fe9lu
k86R3EZymQsQRfYKKAPhX4e+H/HPif4gaT4Uutc+IGqfD1tasLm6v47HxT4b dS2ma/8AaEa4
v7uS8MQlg0knbOIA7xAIHdzJ6V480/xVe/ssz2d+PFA1LS/HNvHBcWmny6hq 8Gl2Xi1Ps1yk
bRTSXLR2MEUokeOVpVUSP5u5i31BRQB8v69r41+28HnV9V+LGueALWHVLfVN Sh0HWNH1qfVf
Ms3sTJBptpa3JgFu9+u9IhbkqgkLSiM15Bef8JD4U+IVlp/iv/hYGjeBdS8Z 3u618Pf2xBLd
eZf+OLo+Qthid9wXS5n8oHMYt3f5Apr7/qpe6TY6jc2Fxd2VvdXFhMbmzlmi V2tpTG8RkjJG
UYxyyJuGDtkcdGIIB8laN/wnn/CY/D37f/wmHiK2+2uun+Hpv7b0r7Fph1i6 a21G81KL9xcy
rpyWnmafqf75/J5ZZppIrjW/ZJ034kW3ip7jxr4h8QahfyaKf+Ek0/UNB1O0 s4NXLwn91c31
7LBLtP2xV/sqGO1ZSWbaotVP1VRQB8FftHeLfiVoWv8AxA1zSrzxR4bc6Z4j gvdPtNO12S0s
7G30TUGsr5NSa4bTI2kmt7CcC1hinjecRNIWWfzNbxbq0eneK/C9vbXvxYtf hBf+ILK2eKaX
xOmtXN8NK16W7jjDn+1HgHlaQ+1MwZjcrys5H2pq2k2Ov6Ve6Zqdlb6jpt7C 9tdWd3EssM8T
qVeN0YEMrKSCpBBBINF7pNjqNzYXF3ZW91cWExubOWaJXa2lMbxGSMkZRjHL Im4YO2Rx0Ygg
HwrfaT8bYfE0+p+FbLxQmsXOmNbaLeXkUgMtrHB42bSI717gYZkWbRS63h3i WSA3GJWOfQPH
0lvdeAdJ0zwW3xI0nwzNqdxc3uv63ZeNdQ1KC7jihWK2FrHc2+omCVJZX80S G1RrYqVMsqlf
rWigD4g+G2k+OodKuNf12y8cWfxO8T6n4I1i8NvFqMFlLYlfDkGptLDEBZwz iS3v0ljZUnEK
SZUQHkt9M+IWtaB4b0+B/iRHq93Do9v8SHmudXtguqtrejrOdPldlWODyDre 99LYW6xYLEII
DX2/RQB4/wDDG91bwLr/AIj8LXlh4o1PQv8AhLRpegXl81xfm2sjolvevNPd 3DtLJB9qF5EJ
XeTEskcIIVQqewUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV8dfGSaXRvjZ4wV 8r9tjtrqLtlf
s0ceR/wKNvyr7Fr58/au+HdxqFjY+NNMhaa50qMwX8aDJa0JLB8d/LYsT/su x/hry8yg5Ydu
P2dTyszozr4WUae61+4848KeOGslVHfgdDmvYvgt460jwx8CtK1nWr6KytS1 wxeVsZ/fScAd
z7CvkiHVGt2+U7ozypHpUGlTPFY2EGoXb3y2KbLaFyfJgycnavqSc5Pf0rwY YicpwrYa0lZq
/RX5f8tj5HC5lKg7tXdrfke9fED416v8Q0ltNNL6B4ccFWmYD7XdKePlH/LN T6nn868c8U6j
aaJo6WdmghiLfKgOSe5JPc9Kq6j4rjtYS8smB29T9K5HT01Px94ktbayt3uJ ZZRFb26/8tH7
L7D+Jj0ABJ4FKThSl7SrK83pd7+iX6IxqYmpip92z6w/ZYgkPhLXLtwQk+pl U/2gkEQJ/wC+
tw/4DXsT9TWN4A8Hw+AvB2l6HCwlNtH+9lH/AC1lYlpH/FmY47DArZfqa++w lN0qMYS3PuKV
P2VOMH0SRXk61CetTSdahPWu9Gh/P941/wCRjuvw/lRR41/5GO6/D+VFf03i /wDeKnq/zPj8
J/u9P0X5H6k/8EnP+Rb8a/8AXDTf/Q72vvuvgP8A4JOf8i141/64ab/6He19 +V+Cccf8lDiv
WP8A6RE+iyX/AHGHrL/0qQUUUV8Ke2FFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFV
7ydYomDRPKpGCqrnI9Kn6VE5zmmhM+Vvil8Bbc6hLe+E9PntYpGLSaXLGVhU 9zC4yUH+wQV9
NoryS++FXiSNip0fWYG9PsyyD8GRj/Q+1ff796hkr5+vw/gq83UinBvfldvw PKr5bhq8uaUb
PyPgHT/gL4h1e4XfpWoFT1lvQIUH4As5+mB9a+lfg/8ACjRvh3ALhLSe61h0 2PezQBBGvdIl
ydinvySeMk4GPYJO9VpOpruwOS4TBT9rFOUu7d2vQqhg6GG1px17lZjnnp9a rP1NWX61Wfqa
+lidL3K8nWoT1qaTrUJ61siT+f7xr/yMd1+H8qKPGv8AyMd1+H8qK/pvF/7x U9X+Z8fhP93p
+i/I/SP/AIJn6fZ33hrxT9rsbS92QWG37VbpLty93nG4HGcDp6CvsKa48HW8 rxSxeG45UYq6
Pb2oZSOCCMcGvkT/AIJjf8i14s/64af/AOh3lfY/hn/kGzf9ft3/AOlMlfzn x62uJMX6x/8A
SIn0+R/7hD1l/wClyKP27wX/AHfDP/fm1/wo+3eC/wC74Z/782v+FaP9sSJp Uepy6bdw6fJG
sizs0J3BsbAFEhYsxKgKASSwAGTUej6+NSlNvcWlxpt55azJBdRsheNlVgVJ AyV3qrgZ2PlT
n5S35z9YipKDlZvbc+h5HZtLYpfbvBf93wz/AN+bX/Cj7d4L/u+Gf+/Nr/hW tqd+9j9mCCDM
zspe6m8qONVjeRmZtrYACHtVLSdV1nVwtxbaGt3prO6JeWd/E6yBWK7kDbcq SODxxzVuq07a
v0Tf5LzJ5St9u8F/3fDP/fm1/wAKPt3gv+74Z/782v8AhWvpGr22t2KXVq+6 NuCp4ZG7qw7E
f54ql4v8W2HgjQp9W1Iym3jKoscCb5JHY4VFHck8c4HuKaqpx509C4Up1Jqn GN5N2t1uVft3
gv8Au+Gf+/Nr/hR9u8F/3fDP/fm1/wAKx7341+FbPwzDrK3rXXnHZHp9uA14 ZB95DFkEMvOc
4Ax15Get0PWrPxHo9nqmny+fZXcYlikwRlT04PIoVRSdkzWpha9GPPUg0r21 XVdDK+3eC/7v
hn/vza/4UfbvBf8Ad8M/9+bX/Ctu1meSe8VjkRyhVGOg2If5k1S1zxFb6BsN wjFGRpDJ5kca
IoZFyzSOoHLqBz3rWCnUfLHVnJJqKuyj9u8F/wB3wz/35tf8KPt3gv8Au+Gf +/Nr/hVT/haO
hB0D3MEas6oX+3WrBckDJCzE4GcnA4GTXVwTxXUEc0MiTQyKHSSNgyspGQQR 1BHernCpS+NN
CjKM/hZz/wBu8F/3fDP/AH5tf8KPt3gv+74Z/wC/Nr/hUPjD4hWfhHT9Umez 1G6uLK2ecJHp
9yYXKpvAM6xMig8AtnC856GjwV8QbPx2kc1jbzwW0unWuoxm6Uxy7ZnmUAoR 0HkEhgSrA5Ul
cEpxqJczvYFKLdkyb7d4L/u+Gf8Avza/4UfbvBf93wz/AN+bX/CujorPmfcu xzn27wX/AHfD
P/fm1/wo+3eC/wC74Z/782v+FdHRRzPuFjnPt3gv+74Z/wC/Nr/hR9u8F/3f DP8A35tf8K6O
ijmfcLHOfbvBf93wz/35tf8ACj7d4L/u+Gf+/Nr/AIV0dFHM+4WOc+3eC/7v hn/vza/4Ufbv
Bf8Ad8M/9+bX/Cujoo5n3CxiWKeFdTlMVnZ+H7uULuKQWts7AdM4C9OR+dV/ t3gv+74Z/wC/
Nr/hV65/5GvTv+vK6/8ARlvR4S/5FTRf+vKH/wBFrRzPuFij9u8F/wB3wz/3 5tf8KPt3gv8A
u+Gf+/Nr/hXR0Ucz7hY5z7d4L/u+Gf8Avza/4UfbvBf93wz/AN+bX/Cujoo5 n3Cxzn27wX/d
8M/9+bX/AAo+3eC/7vhn/vza/wCFdHRRzPuFjnPt3gv+74Z/782v+FH27wX/ AHfDP/fm1/wr
o6KOZ9wsc59u8F/3fDP/AH5tf8KPt3gv+74Z/wC/Nr/hXR0Ucz7hY5z7d4L/ ALvhn/vza/4U
fbvBf93wz/35tf8ACujoo5n3Cxzn27wX/d8M/wDfm1/wo+3eC/7vhn/vza/4 V0dFHM+4WOc+
3eC/7vhn/vza/wCFH27wX/d8M/8Afm1/wro6KOZ9wsc59u8F/wB3wz/35tf8 KPt3gv8Au+Gf
+/Nr/hXR0Ucz7hY5z7d4L/u+Gf8Avza/4UfbvBf93wz/AN+bX/Cujoo5n3Cx zn27wX/d8M/9
+bX/AAo+3eC/7vhn/vza/wCFdHRRzPuFjnPt3gv+74Z/782v+FH27wX/AHfD P/fm1/wro6KO
Z9wsc59u8F/3fDP/AH5tf8KPt3gv+74Z/wC/Nr/hXR0Ucz7hY5z7d4L/ALvh n/vza/4UfbvB
f93wz/35tf8ACujoo5n3Cxzn27wX/d8M/wDfm1/wo+3eC/7vhn/vza/4V0dF HM+4WOc+3eC/
7vhn/vza/wCFH27wX/d8M/8Afm1/wro6KOZ9wsc59u8F/wB3wz/35tf8KPt3 gv8Au+Gf+/Nr
/hXR0Ucz7hY5z7d4L/u+Gf8Avza/4UfbvBf93wz/AN+bX/Cujoo5n3Cxzn27 wX/d8M/9+bX/
AAo+3eC/7vhn/vza/wCFdHRRzPuFjnPt3gv+74Z/782v+FH27wX/AHfDP/fm 1/wro6KOZ9ws
c59u8F/3fDP/AH5tf8KPt3gv+74Z/wC/Nr/hXR0Ucz7hY5z7d4L/ALvhn/vz a/4UfbvBf93w
z/35tf8ACujoo5n3Cxzn27wX/d8M/wDfm1/wo+3eC/7vhn/vza/4V0dFHM+4 WOc+3eC/7vhn
/vza/wCFH27wX/d8M/8Afm1/wro6KOZ9wsc59u8F/wB3wz/35tf8KPt3gv8A u+Gf+/Nr/hXR
0Ucz7hY5z7d4L/u+Gf8Avza/4UfbvBf93wz/AN+bX/Cujoo5n3Cxzn27wX/d 8M/9+bX/AAo+
3eC/7vhn/vza/wCFdHRRzPuFjnPt3gv+74Z/782v+FH27wX/AHfDP/fm1/wr o6KOZ9wsc59u
8F/3fDP/AH5tf8KPt3gv+74Z/wC/Nr/hXR0Ucz7hY5z7d4L/ALvhn/vza/4U fbvBf93wz/35
tf8ACujoo5n3Cxzn27wX/d8M/wDfm1/wo+3eC/7vhn/vza/4V0dFHM+4WOc+ 3eC/7vhn/vza
/wCFH27wX/d8M/8Afm1/wro6KOZ9wsc59u8F/wB3wz/35tf8KPt3gv8Au+Gf +/Nr/hXR0Ucz
7hY5z7d4L/u+Gf8Avza/4UfbvBf93wz/AN+bX/Cujoo5n3Cxzn27wX/d8M/9 +bX/AAo+3eC/
7vhn/vza/wCFdHRRzPuFjnPt3gv+74Z/782v+FH27wX/AHfDP/fm1/wro6KO Z9wsc59u8F/3
fDP/AH5tf8KPt3gv+74Z/wC/Nr/hXR0Ucz7hY5z7d4L/ALvhn/vza/4UfbvB f93wz/35tf8A
Cujoo5n3Cxzn27wX/d8M/wDfm1/wo+3eC/7vhn/vza/4V0dFHM+4WOc+3eC/ 7vhn/vza/wCF
H27wX/d8M/8Afm1/wro6KOZ9wsc59u8F/wB3wz/35tf8Ku2Nh4c1OIy2em6H dxBtpeCyt3UH
rjIXryPzrWrK0X/kJa9/1+r/AOk0NHM+4WPwO8a/8jHdfh/Kijxr/wAjHdfh /Kiv7Lxf+8VP
V/mfnWE/3en6L8j9Kv8AgmN/yLXiz/rhp/8A6HeV9j+Gf+QbN/1+3f8A6UyV 8cf8Exv+Ra8W
f9cNP/8AQ7yvrbQ/EWlWNrcQXOp2dvOl7d7o5bhFYZuJCMgnPQ1/OXH3/JSY v1j/AOkRPqMj
/wBwh6y/9Lkb/hS7hvfA2kW9xFHcW82mwxywzKGSRDEAVYHggg4INYHg3w5p Xhu61y30y3aM
JcxwmWVt8jRrbxeVHuwDtjRgig5OBkkszMc6y/svTrK3tLfx5LHbwRrFGnn2 R2qowBkxZPA7
1o6NqmhaOt2T4ltr2a6m8+Sa5uoAxbYqAYQKAMIvaviK6w9RQlGPvR2dultb Hsw9pFtN6Mn8
WXX2T+zJA/l4mm+fdt2/6JcHOdyY+u5f94da4STdfaVpN9Fam7uYGmkhultf tLo63UzKyyfY
7sgg4IIkPrz95u31XVfDOsxwpdaxafuZPNjaHUfJdW2lchkcHozDr3rmbrwx 4PvEMc3iK1uI
QzsqXTWVyVDOzkb5YmYjczH5mJ56104PEU6D99Pr+Nv8jKtTlP4TY8AySSTT NPG0dy9nC8pe
HynY+fdAFl8iA52qoyYl4A+994x/GbxTong74b6zqHiCxbVNMMYgayUf695G CIm7omWI+c42
9eoFXNK1HRNNvLm7l8Uw6hcTxxxF7m5txtVC5AARVHWRuuauahrvhnVrGeyv tQ0m8s7hDFNb
3E8UkciEYKspOCCOxrgq8spS9mrJ3sd+EnGlVpzrJySavZ2bS7Po/M+AbW61 vTdA0XxBq2kX
V54fmuYY5r9l8qLUY0fLwCbqA4VlDnAbsTmv0E8H69p3ijwrpGr6QjR6Xe2s c9sjReWVjZQV
G3tgcYHHpxVK8v8AwhqOjtpN3caJdaU0YiaxmeF4CgxhSh+XAwOMY4q8vivQ UUKusacqgYAF
1GAB+dclKiqV7M+sz/iCGexg3R5JRb2enK9tP5u7/Dtbsf8Aj61D/ruP/RSV zXjqVI9R0VXd
VaSeFUBOCx+22ZwPU4BP4GtO28TaLDNdO2tacRLIHXF2nA2KvPPqppmp614a 1iza1utXsWhZ
kf8Ad3wjYMrBlIZWBBDKDkHtXoYeoqNVTa2PiKsPaQcS1YXnxIk1G2jvvBHh aCxaVVnntvE0
8siR5G5kRtPQMwGSFLKCeCR1qHwL/wAiR4e/7B1v/wCilqh9q8Of9DTdf+FL c/8Ax6r9h4g8
OaZY29nbatp8dvbxrFEn2tDtVRgDJbJ4HeurFYmNeKUVa39d2Y0aDpN63+79 EhfG8iw+D9Zk
eSCKGO0keZrmPzI/KCkyAja3VQwyUcDOSjgbT5ck73XirTrjU7OTxUWit7gt pV1HcMYpYrwW
cvmx2MPybxPsfzlEbSK5Kg7j2XifRfh/4tgv11A6DJdXkLQvfg25uUym0Msj AkMoxg9sD0qf
wxbeDPBwEej6hp1laraw2aWyXcZRUjeVw3J3FmaZyzMSWPJ5JJ8PE4SniY/H JPt03T1WqZ6N
GvKk/hT/AD+/odPo0V7DpdsmoypPehf3rx9CfrgBiBgFgqhiCQqA7R5p8I/g I3wp8XeKtak8
e+M/FsGqzY07TPEeu3N7baTbEKzQxrJIwkbzA2JXy4QImc+Y8voX/CW6H/0G dP8A/AqP/Gj/
AIS3Q/8AoM6f/wCBUf8AjXTFckeVGTd3c1aKyv8AhLdD/wCgzp//AIFR/wCN H/CW6H/0GdP/
APAqP/GmI1aKyv8AhLdD/wCgzp//AIFR/wCNH/CW6H/0GdP/APAqP/GgDVor K/4S3Q/+gzp/
/gVH/jR/wluh/wDQZ0//AMCo/wDGgDVorK/4S3Q/+gzp/wD4FR/40f8ACW6H /wBBnT//AAKj
/wAaAC5/5GvTv+vK6/8ARlvR4S/5FTRf+vKH/wBFrVSHV7HVPFdj9ivbe88u yud/kSq+3MkG
M4PHQ/lVvwl/yKmi/wDXlD/6LWgDVor5l+JP/FIftMeJPiZFx/wiXhHQ/wC1 v9vRJ73V/t/X
OPJ8mC8+RWkf7D5KY85s+Y/D/wCOeueEvDPwJ0zTNfsNKtY9I8IaLN4b1rVb W3m1ZLxLOOS7
s7I2bXFxGiXRUTJdxIstpKDGwhcS6cjewrn3RRXx98O/iz8QF0Dwfq2peNb/ AFySfSPBOsXU
F7Y2KR3T69ftZXMT+TbxsscCxeZBsZXEjt5rTJtRT4VfGnx74h8M+MNS8U+P 9C0fyvCN5q2q
Cxcavd+Dr9URgslnFp8P2byd1xm0u5ridzbhVZvKnZjkYXPq3xVezab4X1i7 tn8u4t7OaWN8
A7WVCQcHg8jvXQf8K5l/6GnWv++LP/5HrmPHH/IleIP+wfcf+i2rmP2tvAv/ AAsi6+DmhR33
9lX8njOS607U/K877BfwaHq09ndeVuUS+TcRQy+Wx2vs2tlWIPZQS5L2W/b0 MJ6yPTv+Fcy/
9DTrX/fFn/8AI9H/AArmX/oada/74s//AJHr4nj/AGg/Fuoa/wCMr7SNZ0f4 YWOqeLbtPEGo
63r9tpsOnavZaJ4ftn0oX91p95BIwlN+MLADMLIyRyCNGEnqtr8dfijoF9d3 3ieC3Om+H4dP
8X+IzaQfZYYNCm020glVIZ4hdKq3Y1y9Cuv2kDRxAyD7VFXRp2X3L/Im3m/v Z9B/8K5l/wCh
p1r/AL4s/wD5Ho/4VzL/ANDTrX/fFn/8j1P8J/8AhJ/+FWeDf+E2/wCRz/sW y/tz/Vf8f/kJ
9o/1X7v/AFu/7ny/3eMV81aH8br/AFD4e+GdT1P4y/2XqOsXtlH47O7SI/8A hXbyWF5cNb7X
tz9k3XsMNljUfOfnywRMd9GnZfcv8gt5v72fR3/CuZf+hp1r/viz/wDkesnT tF0jWNd1fRLD
4hXV7rWj+T/aWnW89hJcWPmqXh86MQFo96gsu4DcBkZFfOR+MXxGv/DnxJ8U xeOtQhtPAXgy
TxFpVtBYaebPxIkWo69HbXV2zWxd4ru10yykLWkkCMszvD5YdNtW51nxb8OP AEHiTw1c3Hir
V7j4jeO5dJ8NX+mW13Db3FvF4qljjtRFCtzummij3nzWkILRoyJIyMadl9y/ yC3m/vZ9W/8A
CuZf+hp1r/viz/8Akej/AIVzL/0NOtf98Wf/AMj18z6D+0KdD+MMcFl8cbf4 gfC+wm0mXXfE
l9Po72mmrc2niFWjnu7O3hihVri00kAuQ2+SNA2Jtravwb+O3i3x14o8c+Ij 4luPFXgnw1pl
9rNpo3hrTLa6udaUa54jtbZLeVceYptrC2CqvzSyRQMJVBmE5p2X3L/ILeb+ 9n0H/wAK5l/6
GnWv++LP/wCR6P8AhXMv/Q061/3xZ/8AyPXxPZfFzXfG3ivRLDxD8XdHbw94 T8QadrNx8QvD
niDStWXSFvNK8QWrJcXn9mW1nEpkhtYlWW2Zg14P3rGWJY+ru/jd4l8O6Z40 WHxXb+Er7SZv
EN94R0O2srCBfGerL4h1uI6aY3hL3LAWunqyWZjuGa/ZnkaSaNgadl9y/wAg t5v72fVv/CuZ
f+hp1r/viz/+R6P+Fcy/9DTrX/fFn/8AI9eOeAfHPjOPxV4W1bUfGOoa3YeK PiB4m8KSaFe2
lklnYWtm+stbvbtDbxz+aBpcCEyyyKVklyu4oyfStGnZfcv8gt5v72cb/wAK 5l/6GnWv++LP
/wCR6P8AhXMv/Q061/3xZ/8AyPXZUUadl9y/yC3m/vZxv/CuZf8Aoada/wC+ LP8A+R6P+Fcy
/wDQ061/3xZ//I9dlRRp2X3L/ILeb+9nG/8ACuZf+hp1r/viz/8Akej/AIVz L/0NOtf98Wf/
AMj12VFGnZfcv8gt5v72cb/wrmX/AKGnWv8Aviz/APkej/hXMv8A0NOtf98W f/yPXZUUadl9
y/yC3m/vZxv/AArmX/oada/74s//AJHo/wCFcy/9DTrX/fFn/wDI9dlRRp2X 3L/ILeb+9nG/
8K5l/wChp1r/AL4s/wD5Ho/4VzL/ANDTrX/fFn/8j12VFGnZfcv8gt5v72cb /wAK5l/6GnWv
++LP/wCR6P8AhXMv/Q061/3xZ/8AyPXZUUadl9y/yC3m/vZxv/CuZf8Aoada /wC+LP8A+R6P
+Fcy/wDQ061/3xZ//I9dlRRp2X3L/ILeb+9nG/8ACuZf+hp1r/viz/8Akej/ AIVzL/0NOtf9
8Wf/AMj12VFGnZfcv8gt5v72cb/wrmX/AKGnWv8Aviz/APkej/hXMv8A0NOt f98Wf/yPXZUU
adl9y/yC3m/vZxv/AArmX/oada/74s//AJHo/wCFcy/9DTrX/fFn/wDI9dlR Rp2X3L/ILeb+
9nG/8K5l/wChp1r/AL4s/wD5Ho/4VzL/ANDTrX/fFn/8j12VFGnZfcv8gt5v 72cb/wAK5l/6
GnWv++LP/wCR6P8AhXMv/Q061/3xZ/8AyPXZUUadl9y/yC3m/vZxv/CuZf8A oada/wC+LP8A
+R6P+Fcy/wDQ061/3xZ//I9dlRRp2X3L/ILeb+9nG/8ACuZf+hp1r/viz/8A kej/AIVzL/0N
Otf98Wf/AMj12VFGnZfcv8gt5v72cb/wrmX/AKGnWv8Aviz/APkej/hXMv8A 0NOtf98Wf/yP
XZUUadl9y/yC3m/vZxv/AArmX/oada/74s//AJHo/wCFcy/9DTrX/fFn/wDI 9dlRRp2X3L/I
Leb+9nG/8K5l/wChp1r/AL4s/wD5Ho/4VzL/ANDTrX/fFn/8j12VFGnZfcv8 gt5v72cb/wAK
5l/6GnWv++LP/wCR6P8AhXMv/Q061/3xZ/8AyPXZUUadl9y/yC3m/vZxv/Cu Zf8Aoada/wC+
LP8A+R6P+Fcy/wDQ061/3xZ//I9dlRRp2X3L/ILeb+9nG/8ACuZf+hp1r/vi z/8Akej/AIVz
L/0NOtf98Wf/AMj12VFGnZfcv8gt5v72cb/wrmX/AKGnWv8Aviz/APkej/hX Mv8A0NOtf98W
f/yPXZUUadl9y/yC3m/vZxv/AArmX/oada/74s//AJHo/wCFcy/9DTrX/fFn /wDI9dlRRp2X
3L/ILeb+9nG/8K5l/wChp1r/AL4s/wD5Ho/4VzL/ANDTrX/fFn/8j12VFGnZ fcv8gt5v72cb
/wAK5l/6GnWv++LP/wCR6P8AhXMv/Q061/3xZ/8AyPXZUUadl9y/yC3m/vZx v/CuZf8Aoada
/wC+LP8A+R6P+Fcy/wDQ061/3xZ//I9dlRRp2X3L/ILeb+9nG/8ACuZf+hp1 r/viz/8Akej/
AIVzL/0NOtf98Wf/AMj12VFGnZfcv8gt5v72cb/wrmX/AKGnWv8Aviz/APke j/hXMv8A0NOt
f98Wf/yPXZUUadl9y/yC3m/vZxv/AArmX/oada/74s//AJHo/wCFcy/9DTrX /fFn/wDI9dlR
Rp2X3L/ILeb+9nG/8K5l/wChp1r/AL4s/wD5Ho/4VzL/ANDTrX/fFn/8j12V FGnZfcv8gt5v
72cb/wAK5l/6GnWv++LP/wCR6yfFvg660HwprOp2/ifV3nsrKa5jWWO0Klkj ZgCBADjI9RXp
Fc58SP8Aknfin/sFXX/olquCi5JOK+5EyVovV/ezErK0X/kJa9/1+r/6TQ1q 1laL/wAhLXv+
v1f/AEmhrxDsPwO8a/8AIx3X4fyoo8a/8jHdfh/Kiv7Nxf8AvFT1f5n51hP9 3p+i/I/Sr/gm
N/yLfiz/AK4af/6HeV90eFtWh0H4f32p3Cu8FlLqNzIsQBYqlxMxABIGcD1F fC//AATG/wCR
b8Wf9cNP/wDQ7yvtKT/kinij/r31f/0bcV/PvGivxRik/wC7/wCkQPo8odsu i/Of/pUjpf8A
hKdT/wChP1r/AL/WP/yTR/wlOp/9CfrX/f6x/wDkmvN0/aEvNF8X/FC017wv qA8LeEdasrBf
EliLf7LDDPaaZLI1zvuBKvkm/lnlm8pYUt4SxYshDW9X/aQtIfGTeGPD/gjx R401ITahEj6K
dPjglWyFkt1JHLdXcKOsc1+luwUlhNBcIVHlEn4/mXb8/wDM9flff8v8jvf+ Ep1P/oT9a/7/
AFj/APJNH/CU6n/0J+tf9/rH/wCSa8ig/bi+Fl9470Dw1Zat9r/tn+zlt7/7 TawYkv4oZbKP
7HLMl9J5iXNsd8Vs8aed87p5U3lVfjJ8ZvEvgr4oeLo7ddYh8MeDfAx8U3Fx plnYXNp5siap
xfxzzRXEqr/Z8RhjtHiJdpBNIEZSpzLt+f8AmHK+/wCX+R7P/wAJTqf/AEJ+ tf8Af6x/+SaP
+Ep1P/oT9a/7/WP/AMk14F8Nv2oNZg8UePbPxhp9xeeE/DUOrareeJ7SGALp VrBrniC3C3KC
VZZFFvpVukYggkcsrmQ/MDWt4a/bl8C+Lo7eDSNL1jV9buNTh0qLRtEn07Vp jLNa3lxbsZrK
7mt0WT7Bcpl5lMRUPMIoT5tHMu35/wCYcr7/AJf5Hs//AAlOp/8AQn61/wB/ rH/5Jo/4SnU/
+hP1r/v9Y/8AyTXL+NfidrPhj40eBPCFh4cuNe03X9M1O7vJbIwLNYm3udOi SdzNPGDAq3sp
dUEkpPl7FOGB4r4e/ts/D/4pXmqW3hiLUNbms7L+1YYNLmsr+4vNPWaKOW6S 2triSeLyxPFI
be4jiuXDFY4ZJUeNTmXb8/8AMOV9/wAv8j13/hKdT/6E/Wv+/wBY/wDyTR/w lOp/9CfrX/f6
x/8AkmvN/wDhoS81f4p+CdG8NeF9Q8Q+FPENlqlwNWthbx+ZHbT6ZGmoQtLc R77H/TpwWVGk
l2RyQo8TLJJ7XRzLt+f+Ycr7/l/kc5/wlOp/9CfrX/f6x/8Akmj/AISnU/8A oT9a/wC/1j/8
k10dFHMu35/5hyvv+X+Rzn/CU6n/ANCfrX/f6x/+SaP+Ep1P/oT9a/7/AFj/ APJNdHRRzLt+
f+Ycr7/l/kc5/wAJTqf/AEJ+tf8Af6x/+SaP+Ep1P/oT9a/7/WP/AMk10dFH Mu35/wCYcr7/
AJf5HOf8JTqf/Qn61/3+sf8A5Jo/4SnU/wDoT9a/7/WP/wAk10dFHMu35/5h yvv+X+Rzn/CU
6n/0J+tf9/rH/wCSaP8AhKdT/wChP1r/AL/WP/yTXR0Ucy7fn/mHK+/5f5GT 4f8AEA14XytY
3WnT2Vx9mmguzGWDeWkgIMbupBWRe/rWtXOeFv8AkOeMP+wrH/6Q2tdHRJJP QcXdahRRRUFH
FeM/+Rr0T/ryvP8A0ZbVg+Ev+RU0X/ryh/8ARa1veM/+Rr0T/ryvP/RltWD4 S/5FTRf+vKH/
ANFrXm1vjZtHY1aKKy5PFOixSMj6vYI6kqytcoCD3BGaxKNSisr/AIS3Q/8A oM6f/wCBUf8A
jR/wluh/9BnT/wDwKj/xoAk8R6dJrHh7VLCFkWa6tZYEaQkKGZCozjPGTWr/ AMJr4j/6AGl/
+DeT/wCRqxv+Et0P/oM6f/4FR/40f8Jbof8A0GdP/wDAqP8AxreFWUFZIzlD md7mz/wmviP/
AKAGl/8Ag3k/+RqP+E18R/8AQA0v/wAG8n/yNWN/wluh/wDQZ0//AMCo/wDG j/hLdD/6DOn/
APgVH/jWn1iXZfj/AJi9n5v8P8jmPFPgM+MNdutXv7LXLe7uNu+PS/iZrun2 42qFGyC3aOJO
FGdqjJyTkkk+gf8ACa+I/wDoAaX/AODeT/5GrG/4S3Q/+gzp/wD4FR/40f8A CW6H/wBBnT//
AAKj/wAaPrEuy/H/ADD2fm/w/wAjZ/4TXxH/ANADS/8Awbyf/I1H/Ca+I/8A oAaX/wCDeT/5
GrG/4S3Q/wDoM6f/AOBUf+NH/CW6H/0GdP8A/AqP/Gj6xLsvx/zD2fm/w/yM 7wLosnw6+3Pp
HhyOa7vdguL/AFnxZf6peSIm7y4jcXUcsvlIXkZY92xWlkYKDI5PVf8ACa+I /wDoAaX/AODe
T/5GrG/4S3Q/+gzp/wD4FR/40f8ACW6H/wBBnT//AAKj/wAaPrEuy/H/ADD2 fm/w/wAjZ/4T
XxH/ANADS/8Awbyf/I1H/Ca+I/8AoAaX/wCDeT/5GrG/4S3Q/wDoM6f/AOBU f+NH/CW6H/0G
dP8A/AqP/Gj6xLsvx/zD2fm/w/yNn/hNfEf/AEANL/8ABvJ/8jUf8Jr4j/6A Gl/+DeT/AORq
xv8AhLdD/wCgzp//AIFR/wCNH/CW6H/0GdP/APAqP/Gj6xLsvx/zD2fm/wAP 8jZ/4TXxH/0A
NL/8G8n/AMjUf8Jr4j/6AGl/+DeT/wCRqxv+Et0P/oM6f/4FR/40f8Jbof8A 0GdP/wDAqP8A
xo+sS7L8f8w9n5v8P8jZ/wCE18R/9ADS/wDwbyf/ACNR/wAJr4j/AOgBpf8A 4N5P/kasb/hL
dD/6DOn/APgVH/jR/wAJbof/AEGdP/8AAqP/ABo+sS7L8f8AMPZ+b/D/ACNn /hNfEf8A0ANL
/wDBvJ/8jUf8Jr4j/wCgBpf/AIN5P/kasb/hLdD/AOgzp/8A4FR/40f8Jbof /QZ0/wD8Co/8
aPrEuy/H/MPZ+b/D/I2f+E18R/8AQA0v/wAG8n/yNR/wmviP/oAaX/4N5P8A 5GrG/wCEt0P/
AKDOn/8AgVH/AI0f8Jbof/QZ0/8A8Co/8aPrEuy/H/MPZ+b/AA/yNn/hNfEf /QA0v/wbyf8A
yNR/wmviP/oAaX/4N5P/AJGrG/4S3Q/+gzp//gVH/jR/wluh/wDQZ0//AMCo /wDGj6xLsvx/
zD2fm/w/yNn/AITXxH/0ANL/APBvJ/8AI1H/AAmviP8A6AGl/wDg3k/+Rqxv +Et0P/oM6f8A
+BUf+NH/AAluh/8AQZ0//wACo/8AGj6xLsvx/wAw9n5v8P8AI2f+E18R/wDQ A0v/AMG8n/yN
R/wmviP/AKAGl/8Ag3k/+Rqxv+Et0P8A6DOn/wDgVH/jR/wluh/9BnT/APwK j/xo+sS7L8f8
w9n5v8P8jZ/4TXxH/wBADS//AAbyf/I1H/Ca+I/+gBpf/g3k/wDkasb/AIS3 Q/8AoM6f/wCB
Uf8AjR/wluh/9BnT/wDwKj/xo+sS7L8f8w9n5v8AD/I2f+E18R/9ADS//BvJ /wDI1H/Ca+I/
+gBpf/g3k/8Akasb/hLdD/6DOn/+BUf+NH/CW6H/ANBnT/8AwKj/AMaPrEuy /H/MPZ+b/D/I
2f8AhNfEf/QA0v8A8G8n/wAjUf8ACa+I/wDoAaX/AODeT/5GrG/4S3Q/+gzp /wD4FR/40f8A
CW6H/wBBnT//AAKj/wAaPrEuy/H/ADD2fm/w/wAjZ/4TXxH/ANADS/8Awbyf /I1H/Ca+I/8A
oAaX/wCDeT/5GrG/4S3Q/wDoM6f/AOBUf+NH/CW6H/0GdP8A/AqP/Gj6xLsv x/zD2fm/w/yN
n/hNfEf/AEANL/8ABvJ/8jUf8Jr4j/6AGl/+DeT/AORqxv8AhLdD/wCgzp// AIFR/wCNH/CW
6H/0GdP/APAqP/Gj6xLsvx/zD2fm/wAP8jZ/4TXxH/0ANL/8G8n/AMjUf8Jr 4j/6AGl/+DeT
/wCRqxv+Et0P/oM6f/4FR/40f8Jbof8A0GdP/wDAqP8Axo+sS7L8f8w9n5v8 P8jZ/wCE18R/
9ADS/wDwbyf/ACNR/wAJr4j/AOgBpf8A4N5P/kasb/hLdD/6DOn/APgVH/jR /wAJbof/AEGd
P/8AAqP/ABo+sS7L8f8AMPZ+b/D/ACNn/hNfEf8A0ANL/wDBvJ/8jUf8Jr4j /wCgBpf/AIN5
P/kasb/hLdD/AOgzp/8A4FR/40f8Jbof/QZ0/wD8Co/8aPrEuy/H/MPZ+b/D /I2f+E18R/8A
QA0v/wAG8n/yNR/wmviP/oAaX/4N5P8A5GrG/wCEt0P/AKDOn/8AgVH/AI0f 8Jbof/QZ0/8A
8Co/8aPrEuy/H/MPZ+b/AA/yNn/hNfEf/QA0v/wbyf8AyNR/wmviP/oAaX/4 N5P/AJGrG/4S
3Q/+gzp//gVH/jR/wluh/wDQZ0//AMCo/wDGj6xLsvx/zD2fm/w/yNn/AITX xH/0ANL/APBv
J/8AI1H/AAmviP8A6AGl/wDg3k/+Rqxv+Et0P/oM6f8A+BUf+NH/AAluh/8A QZ0//wACo/8A
Gj6xLsvx/wAw9n5v8P8AI2f+E18R/wDQA0v/AMG8n/yNR/wmviP/AKAGl/8A g3k/+Rqxv+Et
0P8A6DOn/wDgVH/jR/wluh/9BnT/APwKj/xo+sS7L8f8w9n5v8P8jZ/4TXxH /wBADS//AAby
f/I1H/Ca+I/+gBpf/g3k/wDkasb/AIS3Q/8AoM6f/wCBUf8AjR/wluh/9BnT /wDwKj/xo+sS
7L8f8w9n5v8AD/I2f+E18R/9ADS//BvJ/wDI1H/Ca+I/+gBpf/g3k/8Akasb /hLdD/6DOn/+
BUf+NH/CW6H/ANBnT/8AwKj/AMaPrEuy/H/MPZ+b/D/I2f8AhNfEf/QA0v8A 8G8n/wAjUf8A
Ca+I/wDoAaX/AODeT/5GrG/4S3Q/+gzp/wD4FR/40f8ACW6H/wBBnT//AAKj /wAaPrEuy/H/
ADD2fm/w/wAjZ/4TXxH/ANADS/8Awbyf/I1H/Ca+I/8AoAaX/wCDeT/5GrG/ 4S3Q/wDoM6f/
AOBUf+NH/CW6H/0GdP8A/AqP/Gj6xLsvx/zD2fm/w/yNn/hNfEf/AEANL/8A BvJ/8jUf8Jr4
j/6AGl/+DeT/AORqxv8AhLdD/wCgzp//AIFR/wCNH/CW6H/0GdP/APAqP/Gj 6xLsvx/zD2fm
/wAP8jZ/4TXxH/0ANL/8G8n/AMjUf8Jr4j/6AGl/+DeT/wCRqxv+Et0P/oM6 f/4FR/40f8Jb
of8A0GdP/wDAqP8Axo+sS7L8f8w9n5v8P8jZ/wCE18R/9ADS/wDwbyf/ACNR /wAJr4j/AOgB
pf8A4N5P/kasb/hLdD/6DOn/APgVH/jR/wAJbof/AEGdP/8AAqP/ABo+sS7L 8f8AMPZ+b/D/
ACNn/hNfEf8A0ANL/wDBvJ/8jUf8Jr4j/wCgBpf/AIN5P/kasb/hLdD/AOgz p/8A4FR/40f8
Jbof/QZ0/wD8Co/8aPrEuy/H/MPZ+b/D/I2f+E18R/8AQA0v/wAG8n/yNR/w mviP/oAaX/4N
5P8A5GrG/wCEt0P/AKDOn/8AgVH/AI0f8Jbof/QZ0/8A8Co/8aPrEuy/H/MP Z+b/AA/yNn/h
NfEf/QA0v/wbyf8AyNR/wmviP/oAaX/4N5P/AJGrG/4S3Q/+gzp//gVH/jR/ wluh/wDQZ0//
AMCo/wDGj6xLsvx/zD2fm/w/yNn/AITXxH/0ANL/APBvJ/8AI1H/AAmviP8A 6AGl/wDg3k/+
Rqxv+Et0P/oM6f8A+BUf+NH/AAluh/8AQZ0//wACo/8AGj6xLsvx/wAw9n5v 8P8AI2f+E18R
/wDQA0v/AMG8n/yNWd4k13xH4h8O6ppX9jaXb/brWW283+1ZG2b0K7sfZhnG c4yKr/8ACW6H
/wBBnT//AAKj/wAav2d7b6hAJrWeK5hJIEkLh1P4imsTJO6S/H/MTpXVm3+B NWVov/IS17/r
9X/0mhrVrK0X/kJa9/1+r/6TQ1xmx+B3jX/kY7r8P5UUeNf+Rjuvw/lRX9nY v/eKnq/zPzrC
f7vT9F+R+lX/AATG/wCRa8Wf9cNP/wDQ7yvtKT/kinij/r31f/0bcV8W/wDB Mb/kWvFn/XDT
/wD0O8r71+Hf/IsD/r9vf/SqWv5841fLxRin/h/9IifR5Or5dFec/wD0qR5v 4p0/wuI/iHqP
hzxh4dur7xTpk6T+GvEN5az6DfaibWO2juLpdhn2mK3ggeNJBGY1Y+UZGLnl Lz4b6HZeIfh1
/wAIx8X18Lab4Y8P6rpd3q1nf6bPqupXF3cafMZpzc200UjSvazzTS7VkaV1 bJ3vX0xRXx94
9vx/4B69pd/w/wCCeD+Gfh78NvA2o2Q8L/EWbw34bg+xNN4Y0/XLb7HeSWlv BbW8kszq138s
NpaIyJcLHIsAEiOJJhJq+NfDnw28d/8ACf8A2/xnaw/8Jp4Zi8Kah9m1W2Xy rVPtuHhyDtl/
4mE2S25flj+Xg7vY6KLx7fj/AMALS7/h/wAE+fI/hP8ACiOTW4x44U6b4ih1 O08Q6adXtPJ1
m1vbq/ujBM2zzIlhl1S8MbW7xPiQCRpdq41tL8M+D4ta0DWdd+Lt94u1fRNT /tO0udX1bT41
BFld2gi8i2hhhC7L+4Yusays3lh5GSNEX22ii8e34/8AAC0u/wCH/BPMvFE3 grxJ4q8O+JIf
HtroutaL5sMdzp+o2bfabOZ4ZLizlWZZF8qVra3LMgWVfKGyRAz7uU8OeB/B XhjQm0Kz+MGr
JoMFlHpWl6bFr9nbppOnq0ebWB4Y0kbMUUcIuJnluY0DGKaKR3kb3iii8e34 /wDAC0u/4f8A
BPErLwh8PNE1XQr7RPiEuhHQ5pk063tNTsnhttOna3e40pEljcLaPJaQuAMS QhRHBJDEFiHp
X/CyPCX/AENOi/8Agwh/+Kro6KLx7fj/AMALS7/h/wAE5z/hZHhL/oadF/8A BhD/APFUf8LI
8Jf9DTov/gwh/wDiq6Oii8e34/8AAC0u/wCH/BOc/wCFkeEv+hp0X/wYQ/8A xVH/AAsjwl/0
NOi/+DCH/wCKro6KLx7fj/wAtLv+H/BOc/4WR4S/6GnRf/BhD/8AFUf8LI8J f9DTov8A4MIf
/iq6Oii8e34/8ALS7/h/wTnP+FkeEv8AoadF/wDBhD/8VR/wsjwl/wBDTov/ AIMIf/iq6Oii
8e34/wDAC0u/4f8ABOc/4WR4S/6GnRf/AAYQ/wDxVH/CyPCX/Q06L/4MIf8A 4qujoovHt+P/
AAAtLv8Ah/wTk/AupWmr6h4su7C6gvbWTVU2T28gkRsWVqDhgSDggj8K6yii lJ3dxxVkFFFF
SUcV4z/5GvRP+vK8/wDRltWD4S/5FTRf+vKH/wBFrW94z/5GvRP+vK8/9GW1 YPhL/kVNF/68
of8A0WtebW+Nm0dinrMwvtaXT5iDYxQLPNEf+WzMzBFPqvyMSOM/KOQSK8R0 sfGjUdPstWPj
Lw5oenajAl7a6at9bwrbQSDckaiTT2bao+UZZj8vJbrXq3ie8+yeK5ucbrKD /wBGTVe+GPhy
91/4S+B7m2vWtkbQrMYH2jk+UDn93NGO/pnjr6fQ4Sf1WjTmoq0+a91fZqx4 +Jg69Rxu1y22
djltL8S+MbHSre51PVNF1P7PeWlrdy6Tqkc/yS3CRKzR/ZlwxDfNh1BIYqFG EHRf8Lf8O/8A
Cx/+EC/tL/irP7J/tz+z/Ik/48vO8nzfM27P9Z8u3du74xzV34vaLD4d+H9x PC162/VdJ3G6
u5pwP+JjbjjzGbb17Yzx6CvnX4h/CJfij8RPEFxqqeRo9xpWjW8F1u3eb5cu qx6hb7FdWHm2
WoSQbz937TvT54wV9CjKWKlJwirK363/ACRgo+wXvSbb7v0Pffhz8X/Dvxa8 G6f4r8Kal/au
gah5n2a78iSHzPLkaN/kkVWGHRhyB0yOMGrMcukeITJfraywXAmkha48qWzu GaN2ib5sI7IS
h2nlXXayllKk/EfxO+FfjnWPCt/a2/h68utRtrvxDf8Ahu60RdHa6sr661S9 uI5pri9O+3jZ
GsXjezZZlImLlWWLGjN8CtWvoPipql34VsbjxPLpeonwjqUxtnurS+k1fXbu GS2mLbreTbd2
MgkBTBK8hozt2eHlL3ZU7/Iv2qWqkfZ8Os3GikLeSm908YzduQJovd1VQGUf 3hgjPIwC1dIr
B1DKQykZBHQ151/bH+1U2heJ10GTyJdz6Y33Qilmtz7AclD6D7vbjp5GOymV OPtaKuuq/wAj
qw+MUnyzZvePPHenfD3RI9R1CO5uTPcxWVraWUYknubiRtscSAkDcT6kD3rK 8UfGXwp4V07T
dQm1OG/sb549s+nSxziOF3EYuWCtkwiRkjLqGw0ijvxm/GPw5qXjHQfDGqeH IYtVu9D1y01u
K0Eyx/a44w6vGrt8oYrI2CxAyBk15p4s/Zo1i08Matp2i31vq114oEdnqsj2 cNpHaj7Ubh7i
LBzHGF3J5CB8u6ueQ5byqNKhKMXUlZ3/AK9P1OqpOom+VH0pXM/8LK8N/wDC zP8AhX39o/8A
FX/2R/b39neRJ/x5ed5Hm+Zt8v8A1ny7d27vjHNUPDHwp0vwr401bxNazb73 UvO81P7OsIce
ZIJG/ew26TPyo/1kjZ6tubBHjX/Cpfit/wAJt/wmv23Qv+Sjf29/wjf9lt53 2Ly/7E837X9u
2f8AIL/0vb5W7zflx/yzrjcYp6O50Jt7o+mqK+NL34deHPgT8IPg8/xF8K6T q/h+x0L+z9e8
P63qWmuJdekt7Hyrlm1G5jt5Wgis7yBGEpeON0jhXyQ2w+Ffw38d6B8IPCvh pvA+rXL6zqPg
nX5r8TWsEWlxWNvokd1DdRTzRzrMn9mTtsjicYeMZ3FlRcq7jufZdFfH3w7/ AGZ9c8E6B4PN
j4OsNG1fSNI8EkTWRtYpLbUI79h4ikR0biSWzWFJ5FP+kRoseZQoUYXhT9lT xLDoa6dq+g6t
qt7LNokPieTWJdEXT/EEkWsafcXd0EtoRPfL5VveP5uouJwsxURyPcS7DlXc Ln2XceJdNtfE
1h4fludur39nc39vbbGO+CB4EmfdjaNrXMAwSCd/AIDYfqemfaN11arHFqka YhnYYzjJCOQM
lCTyPfIwwBHzrp3wEfw78a7PWH+H1hqngfR9XuofDulWkVl5eii5ttDdb+3g kdEgjiubLUWf
ysTeZMXSN/MZq6b9mH4c6r4A/wCEl+2eGv7Fsbn7MsOoa3aWC+JdUmXzWmm1 K5sZZIbvmRfL
mOyUkzeYrN+9lTSte4HsE/iWxtPD0etXLvBYvFHLuMZdlD425VcnPzDpmuVu fiiX1K3On6bJ
d6Q6MftUmYmlKo8jeWCOqrDIMMBlivKj5m6HQdOtdV8FaTa3ttDeWsllBvhu Iw6NhFIyp4PI
B/CvIvidp0PhHWrm9h0yXStPWMraJFPttLthbylwFRG8n5XlUp8hkyWV0ZWL ehhaEcTTqUqa
vVcZct2kr20+d/VW1to2RyVZ1YqPw3V+9r6/h8z2jRdfttdWb7Ok8ckDGOZJ oWTY4JVkDY2u
VZWBKFhkdeleda1+074E0XTPE960+rTJ4fh1N5idGureK7lsFmN1b2txPHHB cTL9nn+SOQki
GRvuozDpfBEkX9o3R0/RYINMmhVzqsKsDcSgnhncB7jKsHE2Cp3N8zHk+G69 +zb4i1z4OfEe
3vr7VtT1q5m8YXXhzwvNNYpZW1zfy6lHbTxyJGshaS3vW+WedkX7S2VVkXy/ CwVR1qKnUd35
JpfK501oqE2on1JRXyj40+F/xH1XSbfwVoOh3+l31r4j8Va3beNU1G2hsIP7 RtNa+yMhSb7W
skcup2ysRB8rJIVLKqs1b4BaX4f+I/jnx/qXwutJ/hF4bbTtEtzd+EItAniu 7qKXVGmQvbi9
tSwS4tiwyJlAiJ2oy7+3l0vcxufV2najFqlu80KToizSwEXNvJA26ORo2IV1 BKkqSrgbXUqy
llYEpf6ZBqGxnXZcRZMNwgHmQk9SpI46DI6EcEEZFfJE/wCzPrl/bfF/Vrzw dYXPiuXSNTPg
zU5javd2moSa14gvIJLWYtutpNt5p8gk3JtLLyGjYL6b8Kvhzqvh345eMNeb w15GmXv2xpPE
XiO0sH1q6mkuUaKG1vLWVpH05Y4yFhu0SWMLbqGdRsgHFdwuepalrd0vgXVN QRlh1C1tLnLo
uVWaIOpKg5yu9CRntjNYFlqt7c6tFHJrWqJplxeXen288L2c1y09sjNLut1t 9wU+XJtKlmOE
yo3itDU/+Sb+J/8Arnqf/oyameGoNfX4o3d4mgqL2bz4biaXTEghNqqH7Owv BGWctstcjzJT
+8lBij8kE+lhIxcG2r69l+pz1LuVr9O5NBeyx6tpYt9Y127jkvPs9xDq2k/Y 0ZTbzyAozW8Z
YhohnaTjv1FN8Y/Fjw74H1OLTb86te6i8IuGtND0O+1aWGJmZUeVLSGUxK5S QIZAocxyBc7G
xv8AiWTXJL7w9/bGnafYIuqfuGsb97kv/od1u3BoY9uPlxgtnJ6Y585dPEXw t8ZeMb+w8Hat
4407xVqMWrq2h3FjDLYypY2tm8MqXdxACpFpHIkkbMSZJFZI/LVpcsXGKqLl VtPLuFC/Lqz1
euZ8eePIPAtpppOm3+uanqt59g03SdM8oXF5OIpJ2RWmkjiXbDBNITJIgxGQ CWKq3zJ8S/gP
4u8RaT40sdK8GY8X3n/CTyXXjL7RZp/b9heWmox6fpfneb9pfymutOXy7hEg T7B8rkRQlun8
S/syWFz8YNCsdP8AAGhD4TRXmn6hd6LHaWiaablLHX4Z52s+FaTdcaUpfYS2 2LkiE7OPlXc6
Ln0jp2oxapbvNCk6Is0sBFzbyQNujkaNiFdQSpKkq4G11KspZWBNmvgT48eC 4/B3hDxvp/jf
wnYeKNT8VWfiK28FadNdabNd2F/Nq+rXAuLWC5nSQyTx6hpZAs1lnJhVWQMs St3Xxc+E3xA8
Q+A7/wAB6X4Kv76SLV/F+sR66l9YpYXCalY659liQPcLOJPM1O3ibfCqBlkO 4oA7HIu4rn2D
WFpHjbSNet7efTpp7yCfUbvSRLDZzMqXNtJPHOsh2YjVZLaZPMfCMwUKxLoG +bv2mfgZr+q6
Jb6Z4K8L395HpOkXLeGbzQl0h76z1mVpHluLu71Q+fHvkFrILi0cXDSC5kkc v5LVW8Q/s9+K
WsdU03wr4ag8N+LJ/FPiDV5fHFtNb2y3a39hrwsZjNE5ui1s+o2sTb4wyMzG Leil6FFW3Hc+
t6x72GPQ7iK8tkWGGe4SO6iQYEhkbasgH9/ey5buuc5IXHzTb/s9x+LPHXh+ Y/CWw8KfDNNX
tJ7zwXqdvpptxNFp2tRy37WttLLbt5j3mmxBgTKTbAsqpEjH1/4eeGtS8H/D OPR9StvsX2bx
JdixtVdWSDTzrUrWMcYUlUjW1MCpGMeWgVMLt2iWkuoHeeI765sNOja0aFLi a7tbVHnjLonm
zxxFioZScBycZHSs6+uvEOmxrcw/8T6ON4vPs7fQ7m0lMboWDRvJIyswwMrj g/KxQnjG+L9l
cXGn+HrmLSNM16G11mAT6bq0xihnEySWqfMIpeVluIn5Q8Icc4rz6XwlfjWb FP8AhAdAXc0H
7hVYwSZC/wCsk/sH5A38XzrtJb7mMDvw+XQxcHL2jUvLpr2vrfzRhPFOjJJx uvz/AAPbZPEF
knh1tcQz3Oni0N6Da20s8skWzf8AJCimR2I6IqlicAAk4rA+HPxY8O/FW3v5 /Dp1aSCxma3m
l1LQ77Tl81ZJI5EQ3MMYdkkikRwmSjLhtpIBZ8HIZk+HOlTzWlrp4vmn1GKz snLxW8NxPJPF
Ep2JnZHIinCgZBxxXlb/AAP1LxDongfR9f0X7Tplp8RvEWu6patdKEbT7ltb aAyBXHmRy/bL
VXh+bckzJIhXzFricYxbSd7de/n/AEzZNtJ2sfQ9VpNRii1O3sCk5nnhknV1 t5GiCoyKwaUL
sViZF2ozBmAcqCEcr8j/ABF+CvxL8S/FXWNY0Cwv/D3iXU/7XspfFWnHSbLS /scml3kGnE3E
I/taSRJDprSLJvjWaJ3jXbFAVteMfgMfGt14Wh8PfBiDwR4XhmMWraDdQ6TD FcK2t+HbmSR4
bWeSKRXtrC6BBJYi3KlfmjDnKtNR3PresdIY9B1GzgtkWGwu2aIW8YwscoUu Co6KpVH3Afxb
SBksT8rfETwXoPwg1++1Dxp4T0K9+DkOr3dtovhG7utKtrCOaew0lobiC2vp 4bWPZLa6yCAy
yhrqVlRlllevaPgZpd7ofwM+COm6laT6fqNnoem29zaXUTRSwSppjK6OjAFW UgggjIIINS42
VwuYXx2/aB1D4T+OtD0G2gjn/teBPskSaZLezzzmVk8tFjmQ5P7sBdpJLcE9 B51Zft5aI4H2
nVI4j/seHJz/AO3Vei/Gjwo+r/Eiz1VdJ1G9vLHSPL0u6tbKSaOC6kldTIXQ fI8aEujAgrII
m6Cvm/xDZRfC7xJc6G/h2/BijgeNYHeAuHjBMhAKlsv5iZOR+6IHQ19jlNLD YynGlKnFzSd+
9k7flY8DHzqYVurzvlb/AE/4c+19R+I+neE/hzYeK/EsklrbSxWQlFjZzXTm e5eOKOOOGFXk
ctLKiBVDH5h9a0vB3jPT/HOmS3+m2+rW0EcxgZNY0e70yUsFVsiK6ijdlww+ cKVJyAcggeK6
9beIfi9+yrorJo+oarqcuo6Tdmy027SxvLqztdYt5WkhmMsKxyNbQGRXWROS CrLlaLL4PWHx
I8Y+CZPFXwxv28KaDpGuWn2P4h3dprtwtzPc6ZLDLva6u2fcsd2qszkoI2XC qUDfKVabpzlC
drptO22nby7Ht05qcIzjs0nrufQ9VtL1GLWNMtL+BJ44LqFJ40ureS3lVWUM A8Uiq8bYPKOo
ZTkEAgivnf4e/BTxhCngG28RzTtp15p2j674whup0uJZPEGm20ESb5/MMjtN IllKXjOwHRiG
D/bHJ4/4Xfs1eJPDvwd1iPVfDn/FUyf8IzBJYyX0cv2zTLTTtETU7CMeYYV+ 0mxurZ1Yok+y
ISsYlRly5V3NLn2DRXy34Q/ZwtfEPxJsb7xN8M9Jtfh5HDrMul+FNYtbC4i0 Npk0SOOMW0bS
QRtLLZ6lPmAsuJyXZZJWWsL4afsz65eP4cv/AIg+DrDWNXvdX04eJ7zVza30 1/p8XhOCCSO5
kLObiMatBG/lsWzLEkwBCiSjlXcLn2DWZ4i8S6b4T0+K91W5+y2st5a2CSbG fM9zcR28CYUE
/NLLGueg3ZJABI+R/AX7Pvj4eMvBmu+MYPEl/wCKLeHQZjrUd9pDxafHb2Nm l7az3ssUuohp
J4b5nitWME4usNInn3DqW/7KeoaR8Mvhto2neA9Jtkh8LWDeNdJtUtI11m/s 9Q0S68i4AIju
pnjttUjSSQmPdM4aRFlLF8qvuFz6zSGPQdRs4LZFhsLtmiFvGMLHKFLgqOiq VR9wH8W0gZLE
5fjXxdqvh7UNNs9J0Jtcnu4ppnVWnBjWMxjOIoJTyZR129O+eH2FtBZ6X4Kt 7XRv+EdtYikc
Wj7Ik+wILOULBthZoxsGExGzINvykjBqt4v1L+yfFei3E1ndXFobK8jaS3sJ boI5ktioYR28
+0kK+MqPunnsdMPGMqqUlda/kRUbUboyrX4h+MLmKORfh/dMjqGBR7ogg+5t AK6+18T2Y8IR
eItSmg0jTxYjULma6mVIrWLy/MdnkbACqMkscAAEnFcxYeNbFLG3WTT9TEgj UMH8P3m7OOc/
8Sxuf+BN9T1qjrngzU/GvwU8PabbBLPWbT+xdWjt9QDxK89lc214LeUhS0Qd rfy2fYxTeW2O
V2nqxNOnBLkVtfMypSk3q7nT+CviJpXj77Z/Zlprtr9k2eZ/bXh+/wBK3bt2 Nn2uCLzPunOz
O3jONwz01eF/EP8At/4raTo41L4Ua62iaRq6Xeq+Ftan0ib+37ZrS7iWJI1v ZIJPKuJLWcrc
PGB5QZCzoq15lZ/sz65fXt3qGp+DrCeQ/wBh2+lx3JtZJNM0lvEuo3F9pinc RHHHpN3DbSwx
kwvGGhjMqAA8HKu50XPsGivj62/Zn1y71jWbrUvB1hdeReaXp2jSXBtZDbaK virVJbu0hyxM
VudHuYI2gGFeFvI2naYwax8B/Fz6Xr2nz+DP7Zuriz1HSvBF8txZsngqb+1d Ue0vYzJKr2kY
trjSihs1klRLFVMamGJS+VdwufXN9p9tqUQjuYVlVW3oT95G7Mp6qwzwwwR2 qvo11LMl1b3D
eZcWk5geTAG8bVdG4xzsdM4AG7dgYxXhHgb4GXXhHxN4Z8R2Xhew0rxDP468 RX3iHVrRbeO7
u9IuH1eS1WeVDvmjLy6awiJYqViJUGL5fctF/wCQlr3/AF+r/wCk0NQ1YDVo oopDCiiigAoo
ooAKKKKACiiigAooooAKwvENqumwXGtWiJDeW6+bMyjHnxKBuV/7x2g7c9CB yATndrK8W/8A
Iqa1/wBeU3/otqANWsrRf+Qlr3/X6v8A6TQ1q1laL/yEte/6/V/9JoaAPwO8 a/8AIx3X4fyo
o8a/8jHdfh/Kiv7Oxf8AvFT1f5n51hP93p+i/I/Sr/gmN/yLXiz/AK4af/6H eV96/Dv/AJFg
f9ft7/6VS18Ff8Exv+Rb8Wf9cNP/APQ7yvvX4d/8iwP+v29/9Kpa/nrjb/kp 8X/27/6RE+ly
b/kXw9Zf+lyL/ifW38P6QbuK3W6maeC3jieTy1LyzJEu5grYALgkgHgHg1i3 fizXNIa0k1LS
dKjtZrqC1LWuqySygyyrGpCNboDguCfmHAP0rS8b6Lea/wCHZbTT3hjvVnt7 mI3BIjLRTpKA
xAJAOzGcHr0rw/wR+zRbeE/FFvqGj+C/AfhR4LqD7Vd+H9MW0uJIklinMYZb aPepMafxbcj1
XA+Tjay066/1c9OV7uzPo6vkfxRPbReOtXuJtR8LbC9/bSafqUSSTtJ9unIm Z/szsjhNqKpc
gKFPGePq210ixsHV7ayt7d1XYrRRKpC4RcDA6YjjGPRF9BXgfizVNds01bRr bRvEjo82orIb
bTZ5LeQTXU7oVZRhgUkUkjPXHbFYKCqTXNJJLvsKqrpeR7J8OHaT4eeF2di7 tpVqSzHJJ8le
SawvGHxr0PwV8R/C3g29tdQuLvXM+ZqNrGjWWk7jstft0hcGD7VMGgt8qfOl RkXkGui8AWk9
h4E8N2t1C9vcw6bbRywyDDI4iUMp9wQRXhHxZ/Zi8Z/EXXfiX4ksfiLqGha1 qH9mf8IvYWiW
RsI/7MVLvTvtnm2Msvyao93K3lud0bopyBsBG/Krmx7VoHxY8D+K/FWpeGNE 8ZeH9Z8Sab5n
27R9P1SCe8tfLcRyebCjl02uwRtwGGIB5NVbL43/AA61Hwbf+L7Tx94XuvCd hMLa816HWbZ7
G2lJQCOScPsRiZYxtJB/eJ/eGfCvB3wr+Jfi7TjaY0/4f2mg+M/GGt6H4gd5 LzUXnurjWba3
kfT5beOJYgNR+0K/nyCRYYxtAmLR1PDP7N3xC0L4iP48isdHh1LTZtMuNP0T UvHur66t40Ft
rVrMJdQvLUy2y7NYV0RIpVLW7DCeaXWgPYPAf7SXgfx38QPEHg+38SeH01qz vYYtKs4tZglu
NZtZdMtb9byCEEM0W25dQU3qRAzbsEhe18N/ELwr4x1XWtM0DxNo+ualok32 bVLPTb+K4msJ
dzr5c6IxMTbo5BtYA5Rh2NeVXPwZ8Va3pXi+S+bR7HUvEHjnw34sNvb3ks8N vFYron2mHzDC
hdt2mXAjOwBg0Rby9zBMr9mz9m3U/g3qukNqkdvOnh3w+fDlhqjeKNW1Wa+i LW26VbS5ZbfT
Fb7HGzW8AmGWRVlRYf3oB3+h/Ge51r4uap4BPw/8UWFxpsMd3cazcy6abFbW V7lLecbLxpis
z2cyqvlb1+UyLGDmrf8Aw0L8LP8AhFf+En/4WX4P/wCEb+2/2b/bH9vWv2P7 Vs8z7P53mbPN
2fPszu284xXP/EL4IX3xB1X4uRyanb6dpvjfwNaeE4LhUaaa1lRtV8yZo/lD KF1CIqA4LFHB
28E8/b/B3xx4p+NXhz4k+JIfD+h3dhe2cdxo+l6nPqCfZbbT9dhWVJ3toCZX m1tQYjGFVLct
5jF9igHqt18WPA9loWt63ceMvD9vouh3rabquoy6pAtvp90rKjW88hfbFKGk RSjkMC6jGSKL
X4seB73XdE0S38ZeH7jWtcsl1LStOi1SBrjULVlZ1uIIw+6WIrG7B0BUhGOc A14B4V/Zj8ce
CJfhzrVlP4f1PWvBfhnw1pcenT309vb311Y2OtWV0DcC3dootusLLG4idmMJ RkjDBxq/Ej4J
fEj4h+NtE1W8k0+W0TWtA1h0Xxjqdtb6PHZ3NpcXNlHp8VuLbUcyW9w6XVwI pM3KqVQQR0Ae
wfB34xeFfjr4A0vxf4Q1S31HTb2GKSSKK4ilmspXiSU21wI3cRzosiB48kqT 9DXa15/8B/B2
ufDf4WeH/Butpp7f8IzZW+iWN7p908v2+1t4I4o7mVHiTyJZNhLQq0qpwBK/ UegUAFFFFABR
RRQAVBd/6pf+uif+hCp6rX8iQ2xkkYIiujMzHAADDJJpMDwb4j/GrTPh7ptl fa3rF1a/bHWK
KKGaRnckjcwRTnaoO5iOgwBklQej8G+K59QmWdNRkvbOcWzRsbgyowe5hUMp JIwQ55HXNcRJ
8H7e68Tz+INQ8O3t/qktkNPK3ULzwxx4YOI0YFV3hiGxwRnH33Lanwt+HI+H lsumWVjf2mnm
7heFL1nJDNexSlE3/wAKqrnA7KWOSWY/X1oUlRklY8aMp863PTfGf/I16J/1 5Xn/AKMtqwfC
X/IqaL/15Q/+i1re8Z/8jXon/Xlef+jLasHwl/yKmi/9eUP/AKLWvz+t8bPf jsYWveGm8ReK
7jbdfZvJsoP+We/dmSb3HpXLf8M2eFf+gXov/gnhr0a2/wCRr1H/AK8rX/0Z cVoS3cFuwWWa
ONiM4dwDiuunmGIpU1Si1yra6i99eqMJYelKTm1q/N/5nltt+zr4bsrmK4t7 DSIJ4nEkcsWk
xKyMDkMCDkEHnNb/APwrST/oK/8Akv8A/ZVD4g+LVt4am1uK+tYraXTtVsrJ EuLoRNPazpE8
l6AV4jiQ3jE8rixnJZQr7Jz8WdLtbvVoryG62WuoyWNp/ZtpPqEt6scULTzJ FBGzBIppWgds
FVkTazBmCj14Vs2jFSprR66Rjronslro1+PZ24pU8G3aT27t+fn5f1dCf8K0 k/6Cv/kv/wDZ
Uf8ACtJP+gr/AOS//wBlVLX/AIz6KUa38Oaja6vqMOo6Tb3Cxo8sMcF5c2iB /MXC/PDdh4zu
w5VsbvLkC7kPxO8PXdxpsNpc3WoPqGGgNjp1zcL5bSNGkztHGwjhcq5SZysc iqzIzKCap4rO
YwU2nZ/3V2T/AJdmnddxKjgXLlVvv87d+5Q/4VpJ/wBBX/yX/wDsqP8AhWkn /QV/8l//ALKr
Hhz4teGvFli93pk+oSxCyOoxLNpN3BJdW4AJkt0kiVrgDcn+qD8yRjq65H+L XhpbGK4WfUJp
ZJHi/s+DSbuS/jKBS5ktFiM8YAkiJZ0AxNEc4kTdLxmcqTg4yuunIr/+kjVD Atcyat/i/wCC
Q2fw8u9NlMllrstm5bcfJhwrH1ZN21j9Qa3obLXYolQ6rZTFRjzJLBtze52y gZ+gFVbP4haF
f+IW0WC7la88ySBJWtJltppUz5kUVwUEUki7JN0aOWXypMgeW+3nNR+KOpaZ q/iuebQrX/hF
PDFwsGo6muosbtE+yQXMky23k7WRFnBYCXeVRyqs21G86VDGYybUoe9a+0Y3 TaSfS927Lds6
lUoUY3UtL23b6X87aHYfZtc/6COn/wDgBJ/8eo+za5/0EdP/APACT/49XO+O vizpfgnT/ELS
Q3Umo6Vp1xfRwXFpPbW940Vu0/kxXTR+U7lFYlUZmAVzt+RsXrv4maHp+mWG o3Y1WzsbzzCJ
7nRb2JbdUbDvcloh9mQdd82xdoLZ2gmuZYHFOMZqm7S20eul9Plr5622Zr7e ldx5lpvr8jU+
za5/0EdP/wDACT/49R9m1z/oI6f/AOAEn/x6tCW7gt2CyzRxsRnDuAcUz+0r T/n6g/7+D/Gu
E3KX2bXP+gjp/wD4ASf/AB6j7Nrn/QR0/wD8AJP/AI9V3+0rT/n6g/7+D/Gj +0rT/n6g/wC/
g/xoApfZtc/6COn/APgBJ/8AHqPs2uf9BHT/APwAk/8Aj1Xf7StP+fqD/v4P 8aP7StP+fqD/
AL+D/GgDK07SNZ0zT7Wzi1KxaK3iWJC9g5YhQAM/vuvFPuNM1a8jEc95pc6B 1kCyaa7AMrBl
bBm6hgCD2IBrS/tK0/5+oP8Av4P8aP7StP8An6g/7+D/ABpptaoCl9m1z/oI 6f8A+AEn/wAe
o+za5/0EdP8A/ACT/wCPVd/tK0/5+oP+/g/xo/tK0/5+oP8Av4P8aQFL7Nrn /QR0/wD8AJP/
AI9R9m1z/oI6f/4ASf8Ax6rv9pWn/P1B/wB/B/jR/aVp/wA/UH/fwf40AUvs 2uf9BHT/APwA
k/8Aj1H2bXP+gjp//gBJ/wDHqu/2laf8/UH/AH8H+NH9pWn/AD9Qf9/B/jQB jQaDqkNlNaNf
adPbzPK8iTae7BvMdmZSPOwR8xGPSs//AIV5b/8AQP8ADX/gjH/x2up/tK0/ 5+oP+/g/xo/t
K0/5+oP+/g/xqlKUdmJpPc52y8FnTbpLmzg8P2twmds0GjbHXIwcES5HBI/G tX7Nrn/QR0//
AMAJP/j1Xf7StP8An6g/7+D/ABo/tK0/5+oP+/g/xpOTe4Ky2KX2bXP+gjp/ /gBJ/wDHqPs2
uf8AQR0//wAAJP8A49V3+0rT/n6g/wC/g/xo/tK0/wCfqD/v4P8AGkMpfZtc /wCgjp//AIAS
f/HqPs2uf9BHT/8AwAk/+PVd/tK0/wCfqD/v4P8AGj+0rT/n6g/7+D/GgCl9 m1z/AKCOn/8A
gBJ/8eo+za5/0EdP/wDACT/49V3+0rT/AJ+oP+/g/wAaP7StP+fqD/v4P8aA KX2bXP8AoI6f
/wCAEn/x6q99pGs6hAsUmpWKqsscoK2D5yjq4/5bdMqM+1av9pWn/P1B/wB/ B/jR/aVp/wA/
UH/fwf40AZGp6Ff61YyWWoS6Pf2cuN9vc6W0kb4IIyrTEHBAP1ArB/4VJpH/ AEAvCP8A4Tqf
/HK7X+0rT/n6g/7+D/Gj+0rT/n6g/wC/g/xpNJ7hczbXTNWsbWG2trvS7e3h QRxQxaa6oigY
CqBNgAAYAFS/Ztc/6COn/wDgBJ/8eq7/AGlaf8/UH/fwf40f2laf8/UH/fwf 40wKX2bXP+gj
p/8A4ASf/HqPs2uf9BHT/wDwAk/+PVd/tK0/5+oP+/g/xo/tK0/5+oP+/g/x oApfZtc/6COn
/wDgBJ/8eqvdaRrN3PaSvqViGtpTKgWwfBJRk5/fdMOfxxWr/aVp/wA/UH/f wf40f2laf8/U
H/fwf40AUvs2uf8AQR0//wAAJP8A49WN4h8BReLjbHXbLw5rRtiWgOo6IJ/K JxkrvlO3oOnp
XTf2laf8/UH/AH8H+NH9pWn/AD9Qf9/B/jVRlKDvF2ZLSkrS1KItdbUADUNO AHAA09+P/I1L
9m1z/oI6f/4ASf8Ax6rv9pWn/P1B/wB/B/jR/aVp/wA/UH/fwf41JRS+za5/ 0EdP/wDACT/4
9R9m1z/oI6f/AOAEn/x6rv8AaVp/z9Qf9/B/jR/aVp/z9Qf9/B/jQBS+za5/ 0EdP/wDACT/4
9R9m1z/oI6f/AOAEn/x6rv8AaVp/z9Qf9/B/jR/aVp/z9Qf9/B/jQBlXWkaz dz2kr6lYhraU
yoFsHwSUZOf33TDn8cVY+za5/wBBHT//AAAk/wDj1Xf7StP+fqD/AL+D/Gj+ 0rT/AJ+oP+/g
/wAaAKX2bXP+gjp//gBJ/wDHqPs2uf8AQR0//wAAJP8A49V3+0rT/n6g/wC/ g/xo/tK0/wCf
qD/v4P8AGgCl9m1z/oI6f/4ASf8Ax6j7Nrn/AEEdP/8AACT/AOPVd/tK0/5+ oP8Av4P8aP7S
tP8An6g/7+D/ABoApfZtc/6COn/+AEn/AMeo+za5/wBBHT//AAAk/wDj1Xf7 StP+fqD/AL+D
/Gj+0rT/AJ+oP+/g/wAaAKX2bXP+gjp//gBJ/wDHqr2ukazaT3cqalYlrmUS uGsHwCEVOP33
TCD8c1q/2laf8/UH/fwf40f2laf8/UH/AH8H+NAFL7Nrn/QR0/8A8AJP/j1H 2bXP+gjp/wD4
ASf/AB6rv9pWn/P1B/38H+NH9pWn/P1B/wB/B/jQBS+za5/0EdP/APACT/49 R9m1z/oI6f8A
+AEn/wAeq7/aVp/z9Qf9/B/jR/aVp/z9Qf8Afwf40AUvs2uf9BHT/wDwAk/+ PUfZtc/6COn/
APgBJ/8AHqu/2laf8/UH/fwf40f2laf8/UH/AH8H+NAFL7Nrn/QR0/8A8AJP /j1H2bXP+gjp
/wD4ASf/AB6rv9pWn/P1B/38H+NH9pWn/P1B/wB/B/jQBS+za5/0EdP/APAC T/49R9m1z/oI
6f8A+AEn/wAeq7/aVp/z9Qf9/B/jR/aVp/z9Qf8Afwf40AUvs2uf9BHT/wDw Ak/+PUfZtc/6
COn/APgBJ/8AHqu/2laf8/UH/fwf40f2laf8/UH/AH8H+NAFL7Nrn/QR0/8A 8AJP/j1Znii3
1lfDWrGW/sXiFpNvVLJ1YjYcgHzjg++D9K6D+0rT/n6h/wC/g/xql4t/5FTW v+vKb/0W1AGr
WVov/IS17/r9X/0mhrVrK0X/AJCWvf8AX6v/AKTQ0Afgd41/5GO6/D+VFHjX /kY7r8P5UV/Z
uL/3ip6v8z86wn+70/RfkfpV/wAExv8AkW/Fn/XDT/8A0O8r71+Hf/IsD/r9 vf8A0qlr4K/4
Jjf8i34s/wCuGn/+h3lfevw7/wCRYH/X7e/+lUtfz3xt/wAlPi/+3f8A0iJ9 Lk3/ACL4esv/
AEuR0tUNOk33mqDfu2XKrjfu2/uYzjG9sdc4wnXO053Nfqhp0m+81Qb92y5V cb9239zGcY3t
jrnGE652nO5vjT2C/VDUZNl5pY37d9yy437d37mQ4xvXPTOMP0ztGNy36zNZ RZpdPgeR40nn
eM+XMYmYGGXgFXU54zwGIxnAxvUYGnXkP7QF/r9vBYweHpnjvms7iWPdfNaw K6z2i75WWaEk
BJJFADH5pFODjI9Pk0W3l35kuxv3Z23ky9d+cYbj/WNjHTCYxsTb5j8dL7Rt L1HR7rXEsWt1
sbxIP7Rt1mjM5ltNoAZWG4qJO2cBveonHnXL387fj0M6i5oNd+25N8FtZvtT 1vxLFdG4jgii
tHit59SN8ELGYMyyGWTrsXI3dug7+g+LPFOl+BvCus+JNbuvsWi6PZTahfXP ltJ5MESGSR9q
As2FUnCgk44BNeT/ALPF7Yal4h8Z3WmR2qWTrYhRYwrHCGCyhgAqgA9yMdwe 9bP7Q/g3xf8A
EDQvCmheEZ9P0/f4m0/UNS1TUbQ3aWUFkzX8LiETwNJvu7SzhYK+QkznAxuX S1rr+v0Ki7q5
3/hPxTpfjnwro3iTRLr7bousWUOoWNz5bR+dBKgkjfa4DLlWBwwBGeQDWtXw rP8ADHV/D/xg
8O+GfiT8NNP+NdpD/wAJnqmlwadpWnIk8d7e6HfS3Zt9Rvikfl3V5e2y/vfM 2Kh2kMznV1L4
F/FKPxV8ML3V9O1DX/F/hv8A4Rix/wCEw0M6O0DWUD2v9qm9vrwLqplkP9pk rbERywywqylp
LhSFH1r4m8a2PhXWvCemXcVxJceJdTfSrNoVUrHKtlc3haQlgQvl2kgyATuZ BjBJHQV8f+E/
2botY0z4ZaB4o+Dmnvd6NrVtceN9f1S20u5t/Fc0Wi6pbtqDlZXmus3k8cga 6jSbNyHKAiTZ
yvij9lrxtrOpxJfaX4gmsLb+0NP8KwaBdaIieHANa1OS1nE99DNLp0X2OfS1 jk01WniS0CmM
Nb26UAfWvxN+MPhr4Q22n3HiU6xHb38y20Eul6Df6mvmtJHFHG5tYJBG0kk0 aIr4Ls2F3EED
qtJ1OHWtKstQt0uI7e7hS4jS7tpLaZVZQwDxSKrxtg8o6hlOQQCCK4r44eFt U8YeC9NsNItf
td3D4m8Pag8fmKmILbWbK5nfLED5YYZGx1O3ABJAPlXjL4Sa/qnxl1LVI/CP 2/WrvxNo+q6N
8QPMtP8AiRaPbiw+26Z5ryC8i8/7NqI8qCJ4X/tH52Aln2AH0rRXxV8NP2WN f8B+HPBRsPBO
n6JrWjaL4DImsTaRS2upR6iw8Syo6NxLNZLDHPIp/wBJjRI90oUKNWz+C+tW /wADj4Rl+E3l
62/9m23jjW7ey0C7vfGLwxyl720a7kkiuJTeLFMz6nHG5immZVE5AUA+qrbx Tpd34q1Hw3Fd
b9a0+yttQubby2HlwXDzxwvuI2nc1rOMAkjZyACudavkr9mv4Ha74G8c6J4g 8Y+BLjULz+zJ
tI0fVtSGlS33hi3g1PWpoUlMMgSBZrK/soUjsA8a+U0bJFGiZ9K8TfBzVNU+ MsM1vJt8A6xe
2nifXbbavz6tpwjjtRuL+aPOK6dNmPCJ/Ymxlb7ZJQB1fwz+OnhT4u+Q/hhf EFxaXFkuoW9/
qHhjU9Ps7iBtm14ri5t44pNwdWUKxLLlgCASCb46eFIvHd54QjXxBe61ZXsG n3baf4Y1O6s7
aeWKKZElu4rdreP93PC7FpAEVwWKjNeVfC/wZ4v+FX28eE/APiDSNF0LwzdW q+FNb8ZnU7PV
9Si8n+z49LnnuJ2tbZViu4y8kdrlbi3LwsU2w6viz4d65bfGWbVvCfhjxBpO q6nrWm6jdeKb
bxS7aFNaxi2ivEu9Ne5VRcvaW8tsnl2kygm2k86N9xgAPVfG3xO0D4d3mhW+ uyahb/21exaf
aXFvpN3dW6zyzRQRJNNDE8dvvlniRTMyBi3BODjpL0BoACMgugIP+8K8x+NW n6/41n0LwjpX
hjUJrQ61omtT+JXntE061Sy1SC8lhdTP9pMrR2pVdkDIWljBdRvZPI/gT8Kv G3hP48XXiTWP
DmoaFHqmk3p8T3MMOiWuj6hrD3tlJFLZrZYvJ4hi/McmohpkSTlleWXcnsB6 Bcw6ZeATtoel
qzqGIOnWzcn3MZNXvB11BpuqzG202wg3Nbx77ezhhYbrmFD8yIpIw+cH0FZ6 82kWP7g/lU3h
3/kJOP8Aptaf+ltvX2denD2Elb+rniQb50zuPGf/ACNeif8AXlef+jLasHwl /wAipov/AF5Q
/wDota3vGf8AyNeif9eV5/6MtqwfCX/IqaL/ANeUP/ota/O63xs+hjsFt/yN eo/9eVr/AOjL
irenxqFmkx+8eV9zHqcMQPyAqpbf8jXqP/Xla/8Aoy4q7Yf6hv8ArrL/AOht WJRyHi34SaL4
28Tpqeqx/aLV9OmsLuzy6/aNySxRPvVwV2RXd+mAPm+1ZJzGhFG1+F2paHae H7nRtdtYfEWn
W95BdX2oac1xb3j3csdxdzGBJozG7zxBwFk2IHdQpG0r6LRXoxzHFRjGHPdR 2Ts1s11T6Sa9
LLorczw1Jty5dX8uz/Rf02eWWXwC02x8EX/hT7b9t0e51HSrvyr+2WbdBZRW EfkSDIWTzFsO
WwAPNPykLgzzfCG+n8U6XqDa/ELTTpIvJu0tJV1p7eN/MW0lvxOPOgL8MksT b0+8Wl/fV6ZR
Wv8AauM1/eb36Lqkn07JIj6nQ0938+7f5tniHg/4J6/ffD3w3ZeKdWtYNR0z w9DpNtZWliRF
CpNrJNBefv3F0jGziicIYleNpl/5aKUveFPgXqXgi7m1TQ9X0DTNYkuLllit PDzQ6ZFBPFZp
IiWqXQYPusIn3+bj55MoSQV9horeed42fOuZJSbbXLG2u+ltv6ZnHAUFbTVW 1u76fM8z8NfB
Gx8NePJvEECaKVN7d6gk66HENUaW4aRpFlvSxLRgzSBVRI2CrGpdgriSfUfh dqWp6v4rgm12
1/4RTxPcLPqOmLpzC7dPskFtJCtz521UdYAGIi3hXcKyttde30nT9a8R3usf ZNSsLG3srpbZ
UnsHndv3EUhYsJkHWQjGO1aX/CFeI/8AoP6X/wCCiT/5Jp/W8bKftZVFzOKW qW11JdN76338
wVGio8ig7Xvv127/AIbHifiP9m628U+JLm8vdQ0/7HcyX7TXaaSP7akS6tbi 3aFr8yEGOMXJ
8tTFhUhhTnZkz/Ej4F6l8TtMePV9X0C71G406TT5bi98PNcw2mWkxPYxtdZt piJAHcvJvMMJ
wuzB9l/4QrxH/wBB/S//AAUSf/JNH/CFeI/+g/pf/gok/wDkmuiOZZjGVOaq q8NI6LT/AMl+
/vpfZGbwmHalHkdpb67/AIkdFSf8IV4j/wCg/pf/AIKJP/kmj/hCvEf/AEH9 L/8ABRJ/8k14
n1aXdfj/AJHf7Tyf4f5kdFSf8IV4j/6D+l/+CiT/AOSaP+EK8R/9B/S//BRJ /wDJNH1aXdfj
/kHtPJ/h/mR0VJ/whXiP/oP6X/4KJP8A5Jo/4QrxH/0H9L/8FEn/AMk0fVpd 1+P+Qe08n+H+
ZHRUn/CFeI/+g/pf/gok/wDkmj/hCvEf/Qf0v/wUSf8AyTR9Wl3X4/5B7Tyf 4f5kdFSf8IV4
j/6D+l/+CiT/AOSaP+EK8R/9B/S//BRJ/wDJNH1aXdfj/kHtPJ/h/mR0VJ/w hXiP/oP6X/4K
JP8A5Jo/4QrxH/0H9L/8FEn/AMk0fVpd1+P+Qe08n+H+ZHRUn/CFeI/+g/pf /gok/wDkmj/h
CvEf/Qf0v/wUSf8AyTR9Wl3X4/5B7Tyf4f5kdFSf8IV4j/6D+l/+CiT/AOSa P+EK8R/9B/S/
/BRJ/wDJNH1aXdfj/kHtPJ/h/mR0VJ/whXiP/oP6X/4KJP8A5Jo/4QrxH/0H 9L/8FEn/AMk0
fVpd1+P+Qe08n+H+ZHRUn/CFeI/+g/pf/gok/wDkmj/hCvEf/Qf0v/wUSf8A yTR9Wl3X4/5B
7Tyf4f5kdFSf8IV4j/6D+l/+CiT/AOSaP+EK8R/9B/S//BRJ/wDJNH1aXdfj /kHtPJ/h/mR0
VJ/whXiP/oP6X/4KJP8A5Jo/4QrxH/0H9L/8FEn/AMk0fVpd1+P+Qe08n+H+ ZHRUn/CFeI/+
g/pf/gok/wDkmj/hCvEf/Qf0v/wUSf8AyTR9Wl3X4/5B7Tyf4f5kdFSf8IV4 j/6D+l/+CiT/
AOSaP+EK8R/9B/S//BRJ/wDJNH1aXdfj/kHtPJ/h/mR0VJ/whXiP/oP6X/4K JP8A5Jo/4Qrx
H/0H9L/8FEn/AMk0fVpd1+P+Qe08n+H+ZHRUn/CFeI/+g/pf/gok/wDkmj/h CvEf/Qf0v/wU
Re: Plug-in: Bad version number in .class file [message #335372 is a reply to message #335369] |
Sat, 04 April 2009 07:51 |
Originally posted by: karl.weber99.gmx.net
Hi Rich,
Well, there was _no_ -vm argument in eclipse.ini -- and that was the
problem. I have SDK 1.5 and 1.6 on my system and eclipse, not instructed
with -vm, found the wrong one, i.e. the 1.5 SDK. I added a -vm for the 1.6
on the commandline and it worked!
Great many thanks.
-Karl.
Re: Plug-in: Bad version number in .class file [message #335373 is a reply to message #335370] |
Sat, 04 April 2009 07:53 |
Hi Olivier,
Olivier Thomann wrote:
>> eclipse.buildId=M20090211-1700
>> java.version=1.5.0_16
>> java.vendor=Sun Microsystems Inc.
>> BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
>> Command-line arguments: -os linux -ws gtk -arch x86 -clean
> Do you have a -vm option in the eclipse.ini file ?
> Make sure that your bundle target 1.6. You can do this by setting the EE
> of your bundle to J2SE-1.5.
> Olivier
Well, the target bundle was 1.6 and there was _no_ -vm argument in
eclipse.ini -- and that was the problem. I have SDK 1.5 and 1.6 on my
system and eclipse, not instructed with -vm, found the wrong one, i.e. the
1.5 SDK. I added a -vm for the 1.6 on the commandline and it worked!
Great many thanks.
-Karl.
FUDForum. Page generated in 0.03560 seconds
