Re: externalized strings : conver to 'eclipse mechanism' [message #335362 is a reply to message #335361] |
Fri, 03 April 2009 17:51 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
On 4/3/2009 1:18 PM, Edoardo Comar wrote:
> Hi
> is there a recommended way to change already externalized strings to use
> the 'eclipse mechanism' (i.e. Messages extends NLS ...) rather than the
> default one ?
> I think that the "eclipse mechanism" is better due to not having
> literals left in code (hence far fewer //$NON-NLS-1$) and easy junit
> testability for broken keys.
A follow-up question: why is the default in the Externalize Strings
wizard still to NOT use the "Eclipse mechanism" (at least as of 3.4.2)?
Is there a bug report about that already?
Eric
Re: externalized strings : conver to 'eclipse mechanism' [message #335413 is a reply to message #335379] |
Mon, 06 April 2009 20:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
>> 3.4.2)? Is there a bug report about that already?
> It should definitely remember your last choice which it currently
> doesn't and given we already test whether org.eclipse.osgi is on the
> build path we could also change the default. Can you file a bug against
> JDT UI?
Done:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=271375
I might even find time to submit a patch for it later this week, but no
promises.
Eric
FUDForum. Page generated in 0.03294 seconds
