exception while starting bundle "org.eclipse.gemini.web.tomcat_1.1.0.RELEASE" [message #1802660] |
Wed, 13 February 2019 12:45 |
Vishakha More Messages: 1 Registered: February 2019 |
Junior Member |
We have upgraded to java SE 7 update 201 and started getting below exception in logs while starting "org.eclipse.gemini.web.tomcat_1.1.0.RELEASE" bundle.
We are configuring tomcat with SSL. below is the configuration in tomcat-server.xml
<Connector port="8443" protocol="HTTP/1.1" SSLEnabled="true"
maxThreads="150" scheme="https" secure="true"
ciphers="SSL_RSA_WITH_RC4_128_SHA, TLS_DHE_DSS_WITH_AES_128_CBC_SHA, SSL_RSA_WITH_3DES_EDE_CBC_SHA, SSL_DHE_RSA_WITH_3DES_EDE_CBC_SHA, SSL_DHE_DSS_WITH_3DES_EDE_CBC_SHA"
clientAuth="false" sslProtocols = "TLSv1.1,TLSv1.2"
keystoreFile="config/keystore"
keystoreType="jceks"
keystorePass="test"
compression="off"
compressionMinSize="4096"
noCompressionUserAgents="gozilla, traviata"
compressableMimeType="text/html,text/xml,text/css,text/javascript,application/json"
URIEncoding="UTF-8"/>
Exceptions stack trace is as below:
Jan 18, 2019 5:11:50 PM org.apache.coyote.http11.Http11Protocol init
[2019-01-18 17:11:50.392] [ERROR] system-artifacts System.err SEVERE: Error initializing endpoint
[2019-01-18 17:11:50.392] [ERROR] system-artifacts System.err java.io.IOException: javax.crypto.spec.SecretKeySpec in KernelBundleClassLoader: [bundle=org.eclipse.gemini.web.tomcat_1.1.0.RELEASE]
[2019-01-18 17:11:50.393] [ERROR] system-artifacts System.err at org.apache.tomcat.util.net.jsse.JSSESocketFactory.init(JSSESocketFactory.java:465)
[2019-01-18 17:11:50.394] [ERROR] system-artifacts System.err at org.apache.tomcat.util.net.jsse.JSSESocketFactory.createSocket(JSSESocketFactory.java:130)
[2019-01-18 17:11:50.394] [ERROR] system-artifacts System.err at org.apache.tomcat.util.net.JIoEndpoint.init(JIoEndpoint.java:538)
[2019-01-18 17:11:50.394] [ERROR] system-artifacts System.err at org.apache.coyote.http11.Http11Protocol.init(Http11Protocol.java:176)
[2019-01-18 17:11:50.394] [ERROR] system-artifacts System.err at org.apache.catalina.connector.Connector.initialize(Connector.java:1013)
[2019-01-18 17:11:50.394] [ERROR] system-artifacts System.err at org.apache.catalina.core.StandardService.initialize(StandardService.java:678)
[2019-01-18 17:11:50.394] [ERROR] system-artifacts System.err at org.apache.catalina.core.StandardServer.initialize(StandardServer.java:793)
[2019-01-18 17:11:50.395] [ERROR] system-artifacts System.err at org.eclipse.gemini.web.tomcat.internal.Tomcat.initialize(Tomcat.java:134)
[2019-01-18 17:11:50.395] [ERROR] system-artifacts System.err at org.apache.catalina.core.StandardService.init(StandardService.java:690)
[2019-01-18 17:11:50.395] [ERROR] system-artifacts System.err at org.eclipse.gemini.web.tomcat.internal.TomcatServletContainer.<init>(TomcatServletContainer.java:61)
[2019-01-18 17:11:50.396] [ERROR] system-artifacts System.err at org.eclipse.gemini.web.tomcat.internal.TomcatServletContainerFactory.createContainer(TomcatServletContainerFactory.java:30)
[2019-01-18 17:11:50.396] [ERROR] system-artifacts System.err at org.eclipse.gemini.web.tomcat.internal.Activator.createContainer(Activator.java:92)
[2019-01-18 17:11:50.396] [ERROR] system-artifacts System.err at org.eclipse.gemini.web.tomcat.internal.Activator.start(Activator.java:50)
[2019-01-18 17:11:50.397] [ERROR] system-artifacts System.err at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
[2019-01-18 17:11:50.397] [ERROR] system-artifacts System.err at java.security.AccessController.doPrivileged(Native Method)
[2019-01-18 17:11:50.397] [ERROR] system-artifacts System.err at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
we are suspecting these errors are because multiple security updates patched by java in java 7update 201.
in past we faced similar exception while loading keystore using custom ClassLoader. Here the Classloader trying to laod keystore related classes is 'KernelBundlerClassLoader'. While we are not sure if this is the same issue but any pointers will be helpful.
FUDForum. Page generated in 0.03591 seconds
