Enable launch shortcut depending on content type [message #335328] |
Wed, 01 April 2009 16:04 |
Patrick Schoenbach![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=schoenbach%40itemis.de) Messages: 110 Registered: July 2009 |
I want to enable the launch shortcut depending on the content type of
the selected file. In my plugin.xml, I defined the following:
<!-- content type definition -->
<extension
point="org.eclipse.core.contenttype.contentTypes">
<content-type
base-type="org.eclipse.core.runtime.xml"
file-extensions="mwe,oaw"
id="org.eclipse.emf.mwe.ui.contentType.workflow"
name="%contentType"
priority="high">
<describer
class=" org.eclipse.core.runtime.content.XMLRootElementContentDescri ber ">
<parameter name="element" value="%rootElement"/>
</describer>
</content-type>
</extension>
<!-- launch shortcut -->
<extension
point="org.eclipse.debug.ui.launchShortcuts">
<shortcut
label="MWE Workflow"
icon="icons/oawlaunch.gif"
category="org.eclipse.ui.externaltools"
class=" org.eclipse.emf.mwe.internal.ui.eclipse.launch.MWELaunchShor tcut "
modes="run, debug"
id="org.eclipse.emf.mwe.ui.debug.launching.shortcut">
<contextualLaunch>
<enablement>
<with variable="selection">
<count value="1"/>
<iterate
ifEmpty="false"
operator="and">
<adapt
type="org.eclipse.core.resources.IFile">
</adapt>
<test
forcePluginActivation="false"
property="org.eclipse.core.resources.contentTypeId"
value="org.eclipse.emf.mwe.ui.contentType.workflow">
</test>
</iterate>
</with>
</enablement>
<contextLabel
mode="run"
label="MWE Workflow"/>
<contextLabel
mode="debug"
</contextualLaunch>
</shortcut>
</extension>
However, if I enable the commented out test, the launch shortcut is
never available.
What am I missing?
Patrick
Patrick Schönbach
Software Architect
PGP public key available. Key ID: 0B7DDE39
Or email to pgp@robustsoft.de with subject 'pschoenb'.
Fingerprint: BE80 0E7E B68E CE99 623C 902D 62A6 806A 0B7D DE39
web: http://www.itemis.de
mail: schoenbach@itemis.de
xing: https://www.xing.com/profile/Patrick_Schoenbach
itemis AG
Schauenburgerstraße 116
24118 Kiel
Germany
Rechtlicher Hinweis:
Amtsgericht Dortmund, HRB 20621
Vorstand: Wolfgang Neuhaus, Jens Wagener, Dr. Georg Pietrek
Aufsichtsrat: Dr. Burkhard Igel(Vors.), Stephan Grollmann, Michael
Neuhaus
FUDForum. Page generated in 0.02929 seconds
