Re: Tracking every action in eclipse [message #335260 is a reply to message #335250] |
Fri, 27 March 2009 22:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: n.n.nnn
On Fri, 27 Mar 2009 18:36:53 +0100, Jörg wrote:
> Hello,
> i want to create an action trace. This trace should fetch every user
> action. I tried it with event filter such like this:
> Display display = Display.getDefault(); display.addFilter(SWT.MouseDown,
> new EventListener("MouseDown Event"));
> But these listeners dont give me the corresponding plugin, i get only
> the mouse down information wihtout the consequence. Can you give me a
> hint? I would be very glad about some help.
> Greetings
Try implementing a base action class extending from
org.eclipse.jface.action.Action
and from there override one or more of the Action class
methods in the base to hook into the workbench. Finally
do the actual work of the action:
private Action traceMeAction;
traceMeAction = new ActionTracer("Trace Me") {
public void run() {
// trace this
super.run();
// now do the actual action work
// TODO
register(traceMeAction);
in ApplicationActionBarAdvisor().
// This is my opinion.
Re: Tracking every action in eclipse [message #335265 is a reply to message #335260] |
Sat, 28 March 2009 18:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> @Override
> public void run() {
> // trace this
> super.run();
> // TODO
PS Take out that register, throws an exception, works without it.
Re: Tracking every action in eclipse [message #335315 is a reply to message #335294] |
Tue, 31 March 2009 21:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
On Tue, 31 Mar 2009 12:49:18 +0200, Jörg wrote:
> Thanks for your reply, but this helps only by my own created actions.
> Ist it possible to initialize a general actionlistner, which catches
> every action in eclipse?
I see your point, perhaps someone reading this thread is aware of the
best solution. Good luck!
Re: Tracking every action in eclipse [message #335323 is a reply to message #335315] |
Wed, 01 April 2009 12:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Cedric Brun![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=cedric.brun%40obeo.fr) Messages: 431 Registered: July 2009 |
hi,
You might want to have a look on the Usage Data Collector component as that's what it's exactly doing AFAIK.
Cédric
http://cedric.brun.io news and articles on eclipse and eclipse modeling.
FUDForum. Page generated in 0.03671 seconds
