Re: Find a class [message #335156 is a reply to message #335146] |
Tue, 24 March 2009 12:09 |
Ed Merks Messages: 33264 Registered: July 2009 |
Adam,
Given he explicitly said "find a class" I have to assume that the extra
files provided by Ctrl-Shift-R would be noisy rather than helpful. I
used this only to find things other than .java files, and yes, for that
it's very useful!
Adam Lucarz wrote:
> Doesn't Al want something like "Open Resource" by CTRL+SHIFT+R? This
> is my preferred way to find a class.
> Adam
> Madhu Samuel schrieb:
>> You can also check the menu 'Help > Key Assist' to get the rest of
>> the short cuts. There are lot of convenient short cuts available.
>> Ed Merks wrote:
>>> Al,
>>> You mean like content assist, Ctrl-Space by default, in the editor
>>> or a hot key like Ctrl-Shift-T for searching all classes that's
>>> generally available in the perspective?
>>> Al wrote:
>>>> In IntelliJ, it is very easy to find a class of a given name.
>>>> One enters ctrl-n, then types in the name of the class, and you are
>>>> presented with a list.
>>>> Eclipse does not appear to have anything so convenient.
>>>> The best I can find is:
>>>> Search -> Java -> Type
>>>> Is this is, or is there a faster way?
Ed Merks
FUDForum. Page generated in 0.04311 seconds
