workingSets and headless environments [message #335116] |
Mon, 23 March 2009 12:35  |
Build ID: 3.4
We (a product building on Eclipse) provide an environment for performing
headless, non UI builds, of Eclipse based projects. Included is an Ant
task which does the equivalent of File > Import > Team Project Set to
import a PSF file into the workspace. When importing a PSF file including
working sets, there does not appear to be any way to load the working set
into the workspace without interacting with UI based plugins. Note: the
projects from the PSF file can be loaded, just not the workingSets.
As this product runs in a completely headless manor and does not include
UI plugins it doesn't appear that the workingSets can be imported.
Questions:
1) Is there a means to headlessly import the working sets that I'm
missing, or a workaround to achieve this?
2) Is there reasoning, other than historical, for the working set to be
tied to UI code?
Any help/insight is appreciated,
mike.
Re: workingSets and headless environments [message #335202 is a reply to message #335116] |
Wed, 25 March 2009 18:23  |
I cannot answer your question, but I would like to know more about the
ant task to automate the import projectset? Are you using ant4eclipse
or something else?
Thanks for sharing :)
/Thorbjørn
FUDForum. Page generated in 0.03561 seconds
