Home » Eclipse Projects » Eclipse Platform » FormText Tabbing.
Re: FormText Tabbing. [message #335158 is a reply to message #335104] |
Tue, 24 March 2009 13:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
On 3/23/2009 9:10 AM, Irum Godil wrote:
> I am using a FormText control to display some labels, however, I want to
> prevent tab to enter into this control at all. Today it enters but does
> not show the cursor. I want the tab key to completely skip the FormText
> Control.
> Since I do not have direct access to the FormText code, I tried to add a
> listener for Tab key and reflectively invoke the "advance" method on it
> as follows, but this does not work either.
> label1.addListener(SWT.Traverse, new Listener() {
> public void handleEvent(Event e) {
> if (e.detail == SWT.TRAVERSE_TAB_NEXT) {
> try {
> Object obj = //reflective call to Advance
> e.doit = ((Boolean)obj).booleanValue();
> I will really appreciate if someone can tell me what to do here and how
> to resolve this issue.
Have a look at TraverseListener and TraverseEvent.
Hope this helps,
Eric
Re: FormText Tabbing. [message #335194 is a reply to message #335158] |
Wed, 25 March 2009 14:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Irum Godil![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=irum%40ca.ibm.com) Messages: 35 Registered: July 2009 |
Member |
I did look at the classes mentioned by you, but it does not solve my
problem exactly. Basically, I have 2 controls in my form, one is a
FormText, and the other can be any SWT/more complex widget.
I actually have a series of them, so something like:
Label1 Text
Label2 Combo
Label3 Something more complex
Now, what I want is that the tab always comes in the 2nd field, but skips
all the labels.
If I set e.doit = false, for the labels, then the tab does not continue
past the first label. If I set it to true, I see the same behaviour as
today.
How can I just skip tab from the FormText, but ensure it goes to the next
control on the page?
Thanks for your responses.
Irum.
Re: FormText Tabbing. [message #335231 is a reply to message #335194] |
Thu, 26 March 2009 16:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Member |
Irum Godil wrote:
> Label1 Text
> Label2 Combo
> all the labels.
> today.
> Irum.
I was hoping if someone can please help me on this one, or direct me to
some resources where I can find the solution.
Really appreciate your help.
Irum.
Re: FormText Tabbing. [message #335233 is a reply to message #335194] |
Thu, 26 March 2009 18:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
On 3/25/2009 10:44 AM, Irum Godil wrote:
> Label1 Text
> Label2 Combo
> skips all the labels.
> today.
> next control on the page?
I don't understand; Label widgets don't take focus (on Windows, at
least). So the default focus traversal for a Composite should
automatically find the "next" focusable control.
Eric
Re: FormText Tabbing. [message #335235 is a reply to message #335233] |
Thu, 26 March 2009 18:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Member |
>> Label1 Text
>> Label2 Combo
>> today.
> Eric
In my example, the Labels are actually "FormText" object and they are
taking focus, although I do not see any cursor.
Thanks.
Current Time: Thu Jul 25 20:59:37 GMT 2024
Powered by FUDForum. Page generated in 0.03414 seconds
