Contributing content assist to any editor? [message #335061] |
Thu, 19 March 2009 21:36 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: clemens.froglogic.com
Hello.
I want to provide content assist for a specific API, but the user could
potentially use any Eclipse-based editor, and I would like to offer
content assist based on heuristics (file name extension, document
content) in possibly any editor with just one implementation of the
content assist code.
(I imagine that spellcheckers are a somewhat similar case - the
implementor of a spellchecker may not know what type of document the
user is editing, and in what editor, but "tpyo" still looks like a typo!)
Is this possible, while being a "regular" content assist provider?
Should I file a bug for such a feature (configurable content assist
contributors for any text editors)?
Should this is not possible, can I register an action (without being
bound to any editor) which the user binds to a preferred key combination
and which shows the "standard" content assist dialog when triggered?
With best regards
Clemens Anhuth
www.froglogic.com - Squish - Multi-Platform GUI Testing
Re: Contributing content assist to any editor? [message #335067 is a reply to message #335061] |
Fri, 20 March 2009 08:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Dani Megert![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=Daniel_Megert%40ch.ibm.com) Messages: 3802 Registered: July 2009 |
Clemens Anhuth wrote:
> Hello.
> could potentially use any Eclipse-based editor, and I would like to
> offer content assist based on heuristics (file name extension,
> document content) in possibly any editor with just one implementation
> of the content assist code.
No.
Currently each editor decides whether and if yes, how it supports
content assist. Even if we added configurable content assist for all
editors it would have to be an opt-in feature i.e. only those who want
it will get it.
> combination and which shows the "standard" content assist dialog when
> triggered?
This won't help because as just explained, the concrete editor decides
about content assist support.
Dani
> With best regards
> Clemens Anhuth
Re: Contributing content assist to any editor? [message #335070 is a reply to message #335067] |
Fri, 20 March 2009 10:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Daniel Megert wrote:
Hello Daniel.
> it will get it.
Spell checkers, content assistants, more specialized content assistants
(Mylyn) and template/snippet plugins could be independent of the
individual editor. To be able to share such functionalities across all
editors seems desirable.
(When I use AutoHotkey or any such macro tool to steer Eclipse via
operating system level input events I am already taking control away
from the author of the editor and can implement the above functionality,
but it would not be integrated (well enough) and not be cross-platform.
It would still be my choice however, within the realm of text editors
which deal with text input.)
What is your opinion, am I off base with this? Does it go against
Eclipse design goals or so?
>> triggered?
Sorry Daniel, I phrased this badly.
What I meant to ask is if it is possible to use and show the content
assist functionality existing in RCP by myself, without having my own
editor?
If I cannot use the existing content assist functionality I guess I
could write and display my own, but I would still need to be able to
read and modify the editor's text/document. Is this possible in general,
for text editors? Or would I have to resort to sending keyboard events
to the editor to make it insert the desired text piece?
Thank you for your answers, Daniel.
With best regards
Clemens Anhuth
Re: Contributing content assist to any editor? [message #335071 is a reply to message #335070] |
Fri, 20 March 2009 11:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> Hello Daniel.
>> want it will get it.
> assistants (Mylyn) and template/snippet plugins could be independent
> of the individual editor. To be able to share such functionalities
> across all editors seems desirable.
> functionality, but it would not be integrated (well enough) and not be
> cross-platform. It would still be my choice however, within the realm
> of text editors which deal with text input.)
No, I just wanted to tell how it currently is. Those editors that
inherit from the text editor could probably get it for free but not
those that implement their own based on abstract classes.
>>> when triggered?
>> decides about content assist support.
> editor?
You can trigger it but it would show those proposals that the editor
decides to show. What you could do is using the existing content assist
APIs to write your own (additional) content assist that shows your
proposals but they would not appear on Ctrl+Space but on a separate key
binding.
Dani
> general, for text editors? Or would I have to resort to sending
> keyboard events to the editor to make it insert the desired text piece?
> With best regards
> Clemens Anhuth
Re: Contributing content assist to any editor? [message #335081 is a reply to message #335071] |
Fri, 20 March 2009 16:38 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
>> editor?
> binding.
Hi Dani,
what you describe is what I meant. I just have no idea if the content
assist APIs allows for showing the content assist dialog somewhere
completely unrelated. How would I go about that, would I implement an
invisible dummy editor that has content assist?
With best regards
Clemens Anhuth
Re: Contributing content assist to any editor? [message #335221 is a reply to message #335219] |
Thu, 26 March 2009 13:28 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
>>>> own editor?
>>> assist APIs to write your own (additional) content assist that shows
>>> your proposals but they would not appear on Ctrl+Space but on a
>>> separate key binding.
>> Hi Dani,
> No, see org.eclipse.jface.text.contentassist.ContentAssistant. You can
> simply create a second instance of it and configure it for your viewer.
Hi Dani,
thank you for your reply. I will have (another) look at it. I saw some
install() and uninstall() methods before, but without further
description in the API docs I was too uncertain of their function and
intended use.
With best regards
Clemens Anhuth
FUDForum. Page generated in 0.03881 seconds
