Home » Eclipse Projects » Eclipse Platform » Toggle Menu Item
Toggle Menu Item [message #335027] Tue, 17 March 2009 11:45 Go to next message
Madhu Samuel is currently offline Madhu SamuelFriend
I need to use a toggle menu item. The status of the toggle menu item needs
to be persisted even if I close the eclipse instance. That means if I
check the toggle menu item and restart eclipse, the toggle menu item
should be in checked state itself.
Right now, I have implemented the toggle menu item using the command
"org.eclipse.ui.commands" extension point. But I am not able to persist
the toggle state.
If eclipse does not provide a built-in persistence for toggle menu item,
how can I use my own persistence mechanism? Can I use my own
PersistenceStore?
Any help is appreciated.
Madhu
Re: Toggle Menu Item [message #335029 is a reply to message #335027] Tue, 17 March 2009 12:58 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
I'm not sure that's supported in eclipse 3,4, but it should be in 3.5 M6:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=221980
Paul Webster
Re: Toggle Menu Item [message #335032 is a reply to message #335027] Tue, 17 March 2009 14:53 Go to previous messageGo to next message
Prakash G.R. is currently offline Prakash G.R.Friend
This might help you:
http://blog.eclipse-tips.com/2009/03/commands-part-6-toggle- radio-menu.html
- Prakash
"Madhu Samuel" <madhu.samuel@in.bosch.com> wrote in message
news:6dc01efd9ec8c5896b55877207ab4179$1@www.eclipse.org...
> Hello,
> the toggle state.
> PersistenceStore?
> Madhu
Re: Toggle Menu Item [message #335045 is a reply to message #335032] Thu, 19 March 2009 01:06 Go to previous message
> - Prakash
Thanks Prakash! We had read your blog earlier. But unfortunately many
features are available only in Eclipse 3.5. And we are using Eclipse 3.4
now.
Madhu
Previous Topic:Post save event listener
Next Topic:Registering own IDocumentProvider
Current Time: Thu Aug 29 12:40:14 GMT 2024
Powered by FUDForum. Page generated in 0.03349 seconds
