Toggle Menu Item [message #335027] |
Tue, 17 March 2009 11:45 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Madhu Samuel![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=madhusamuel%40eclipsebible.com) Messages: 199 Registered: July 2009 |
I need to use a toggle menu item. The status of the toggle menu item needs
to be persisted even if I close the eclipse instance. That means if I
check the toggle menu item and restart eclipse, the toggle menu item
should be in checked state itself.
Right now, I have implemented the toggle menu item using the command
"org.eclipse.ui.commands" extension point. But I am not able to persist
the toggle state.
If eclipse does not provide a built-in persistence for toggle menu item,
how can I use my own persistence mechanism? Can I use my own
PersistenceStore?
Any help is appreciated.
Madhu
Madhu
http://eclipsebible.com
FUDForum. Page generated in 0.03869 seconds
