Which basebuilder to use? [message #335007] |
Mon, 16 March 2009 08:08 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: Stefan.Stern.spamDOTremove-this.mind8DOTcom.TinvalidDOTspam
Hello
Every time I make a refresh of our internal build environment, I'm
looking into whether to update the basebuilder or not. And every time I
do so, I again dig into Eclipse build configuration to find out, which
basebuilder version would match to our internal stuff. This time, we do
an upgrade from 3.4.1 to 3.4.2. In 3.4.2 build result page, I am not
able to see which basebuilder version was used during bootstrap. The
basebuilder project TAGs do not offer a clearly candidate. There is a
R3_4_1 tag, but no R3_4_2 tag.
Is it possible to either introduce definite tag on
org.eclipse.releng.basebuilder? Or to add an info on the build results
page on eclipse.org, that tells which basebuilder (and maybe even which
eclipsebuilder) tag was used to build this project?
In the WIKI the Info page about 3.4 tells that 3.4 builds still use
"RC2_34" tagged version. Is this correct or is this information outdated?
If this is not the right list for these questions, which list shall I
use? I wasn't able to find a mailing list for the Eclipse internal build
structure...
Thanks and kind regards,
Stefan
FUDForum. Page generated in 0.04179 seconds
