Home » Eclipse Projects » Eclipse Platform » [DataBindings] validation in inline editing
Re: [DataBindings] validation in inline editing [message #334939 is a reply to message #334931] |
Tue, 10 March 2009 18:58 |
Matthew Hall Messages: 368 Registered: July 2009 |
Here is your problem:
final WritableList wlLignes = new WritableList(SWTObservables
.getRealm(peopleViewer.getTable().getDisplay()), viewModel
.getPeople(), Person.class);
MultiValidator ligneValidator = new MultiValidator(SWTObservables
.getRealm(peopleViewer.getTable().getDisplay())) {
protected IStatus validate() {
IStatus status = ValidationStatus.ok();
for (Iterator it = wlLignes.iterator(); it.hasNext();) {
Person person = (Person) it.next();
if (person.name == "") // << this
status = ValidationStatus.error("nom obligatoire");
return status;
The observable that you are accessing in MultiValidator is wlLignes, and
so the validator is only revalidated when this observable changes state.
However this list is observing the Person objects, not their
respective "name" properties which is what you are really interested in.
This list does not fire a change event when properties of the objects
change, just when the objects themselves are added, moved, replaced or
removed. What you want to observe instead is the "name" property over
each element in the master list:
// Observe the names of each person directly.
final IObservableList personNames =
BeanProperties.value(Person.class, "name").observeDetail(wlLignes);
for (Iterator it = personNames.iterator(); it.hasNext();) {
String name = (String) it.next();
if (name == null || name.length() == 0)
return status;
Also I want to point out one error in your code:
== compares by identity. You should be using equals() here since you
are interested in equality, not object identity.
Also, there is a method BeanProperties.values() that you can use to
shorten this:
ViewerSupport.bind(peopleViewer, wlLignes, new IValueProperty[] {
BeanProperties.value(Person.class, "name"),
BeanProperties.value(Person.class, "city"),
BeanProperties.value(Person.class, "age"),
BeanProperties.value(Person.class, "prix") });
to this:
ViewerSupport.bind(peopleViewer, wlLignes, BeanProperties.values(
Person.class, new String[] { "name", "city", "age", "prix" }));
Hope this helps,
Matthew
david wrote:
> thanks Matthew
> i call the addValidationProvider.
> do i have to call the validate() method myself ???
> i've posted a snippet (based on the snippet013)
> "Matthew Hall" <matthall@woodcraftmill.com> a écrit dans le message de
> groupe de discussion : gp6388$u7t$1@build.eclipse.org...
>> david wrote:
>>> i've got a tableViewer with inline editing.
>>> i would like to add a validator (maybe a global one) to the data
>>> entered in cells
>>> but i don't have any idea of how to do it
>> Are you using ObservableValueEditingSupport? You can override the
>> createBinding() method to customize the converter / validators.
>>> i've tried with a multiValidator , but the validate() methods never
>>> get called.
>> MultiValidator.validate() method should be called any time one of your
>> observable dependencies change. Did you remember to call
>> DataBindingContext.addValidationStatusProvider(MultiValidato r)?
>> Please post a snippet with your MultiValidator code and we'll try to
>> troubleshoot.
>> Matthew
Re: [DataBindings] validation in inline editing [message #334944 is a reply to message #334939] |
Wed, 11 March 2009 07:59 |
david leloup Messages: 36 Registered: July 2009 |
Member |
Hi Matthew,
thanks for all this informations.
i've made the modifications in my snippet
and the validate() method still not called
(and the label error bound to status is still "OK" when i empty a name cell
in the table)
thanks
David
groupe de discussion : gp6d84$n5e$1@build.eclipse.org...
> return status;
> However this list is observing the Person objects, not their respective
> "name" properties which is what you are really interested in. This list
> does not fire a change event when properties of the objects change, just
> when the objects themselves are added, moved, replaced or removed. What
> you want to observe instead is the "name" property over each element in
> the master list:
> return status;
> == compares by identity. You should be using equals() here since you are
> shorten this:
> to this:
> Hope this helps,
> Matthew
> david wrote:
>> thanks Matthew
>> message de groupe de discussion : gp6388$u7t$1@build.eclipse.org...
>>>> the data entered in cells
>>> the createBinding() method to customize the converter /
>>> validators.
>>>> never get called.
>>> of your observable dependencies change. Did you remember to
>>> call DataBindingContext.addValidationStatusProvider(MultiValidato r)?
>>> try to troubleshoot.
>>> Matthew
Re: [DataBindings] validation in inline editing [message #334964 is a reply to message #334944] |
Thu, 12 March 2009 14:50 |
David,
Please post your revised snippet and I'll take a look.
Matthew
david wrote:
> Hi Matthew,
> cell in the table)
> thanks
> David
>> return status;
>> and so the validator is only revalidated when this observable changes
>> state. However this list is observing the Person objects, not their
>> in. This list does not fire a change event when properties of the
>> objects change, just when the objects themselves are added, moved,
>> replaced or removed. What you want to observe instead is the "name"
>> property over each element in the master list:
>> return status;
>> shorten this:
>> to this:
>> Hope this helps,
>> Matthew
>> david wrote:
>>> thanks Matthew
>>>>> to the data entered in cells
>>>> override the createBinding() method to customize the
>>>>> methods never get called.
>>>> one of your observable dependencies change. Did you
>>>> remember to call
>>>> we'll try to troubleshoot.
>>>> Matthew
Re: [DataBindings] validation in inline editing [message #334966 is a reply to message #334965] |
Thu, 12 March 2009 15:20 |
Your aggregate validation status is observing
bindingContext.getBindings(), but MultiValidator is a
ValidationStatusProvider, not a binding. Use
getValidationStatusProviders() instead.
bindingContext
.bindValue(SWTObservables.observeText(error),
new AggregateValidationStatus(bindingContext
.getValidationStatusProviders(),
AggregateValidationStatus.MAX_SEVERITY),
null, null);
Note that Binding extends ValidationStatusProvider so this collection
includes all bindings as well.
Matthew
david wrote:
> hi Matthew
> here it is
> David
> groupe de discussion : gpb7eq$t3t$1@build.eclipse.org...
>> David,
>> Matthew
>> david wrote:
>>> Hi Matthew,
>>> name cell in the table)
>>> thanks
>>> David
>>> de groupe de discussion : gp6d84$n5e$1@build.eclipse.org...
>>>> return status;
>>>> changes state. However this list is observing the Person objects,
>>>> not their respective "name" properties which is what you are really
>>>> interested in. This list does not fire a change event when
>>>> properties of the objects change, just when the objects themselves
>>>> are added, moved, replaced or removed. What you want to observe
>>>> instead is the "name" property over each element in the master list:
>>>> return status;
>>>> you are interested in equality, not object identity.
>>>> shorten this:
>>>> to this:
>>>> Hope this helps,
>>>> Matthew
>>>> david wrote:
>>>>> thanks Matthew
>>>>>>> one) to the data entered in cells
>>>>>> remember to call
>>>>>> Matthew
Re: [DataBindings] validation in inline editing [message #334967 is a reply to message #334966] |
Thu, 12 March 2009 15:26 |
Member |
thanks for your help, Matthew
it works
but it's sometimes hard to navigate through all these classes in databinding
have a good day
david
groupe de discussion : gpb98f$d1j$1@build.eclipse.org...
> bindingContext
> null, null);
> Matthew
> david wrote:
>> hi Matthew
>> here it is
>> David
>>> David,
>>> Matthew
>>> david wrote:
>>>> Hi Matthew,
>>>> cell in the table)
>>>> thanks
>>>> David
>>>>> return status;
>>>>> return status;
>>>>> shorten this:
>>>>> to this:
>>>>> Hope this helps,
>>>>> Matthew
>>>>> david wrote:
>>>>>> thanks Matthew
>>>>>>> override the createBinding() method to customize the converter
>>>>>>> / validators.
>>>>>>> remember to call
>>>>>>> Matthew
Current Time: Sun Oct 20 05:07:19 GMT 2024
Powered by FUDForum. Page generated in 0.04490 seconds
