Re: Huge memory consumption of Infocenter [message #334919 is a reply to message #334916] |
Tue, 10 March 2009 12:49 |
Originally posted by: nospam_kowalskilee.gmail.com
There is an Eclipse newsgroup that focuses on questions about the help
system and Infocenter. It is the eclipse.platform.ua newsgroup.
I recommend that you repost your message to that newsgroup. The Eclipse
committers that cover the infocenter code follow that newsgroup and then
will see your posting there.
When you post your message to eclipse.platform.ua newsgroup, I suggest
that you also include what operating system (OS) you're running the
infocenter on, as well as what Eclipse Version you're using for the
infocenter.
Hope this helps,
Lee Anne
Niina Känsälä wrote:
> I'm struggling with large memory consumption of Eclipse Infocenter. We
> have a Infocenter library with 6 books, containing 12 000 pages
> altogether. There are 4 million hits / 34 000 visits per month.
> Allocated memory to eclipse is -vmargs -Xmx1536m (out of 4GB total in
> server), but it is still running out of memory:
> java.lang.OutOfMemoryError: Java heap space
> Can it be true that standalone Infocenter really requires over 1536M
> memory? Is there any recommended value?
> For me it also seems that there might be some memory leak since the
> memory consumption slightly grows until the maximum is reached (takes 24
> hours or so).
> One thing that I found is setting locales (-nl en -locales en), but
> testing didn't provide too convincing results.
> I'd appreciate any help. Thanks!
FUDForum. Page generated in 0.23859 seconds
