Re: dynamically updating plugin classpath [message #334934 is a reply to message #334900] |
Tue, 10 March 2009 17:32 |
jeevan Messages: 20 Registered: July 2009 |
Junior Member |
I tried the solution, but, Eclipse does not let the user change system
properties programmatically.
Paul Webster wrote:
> jeevan wrote:
>> The way it is now, I can change the environment variable and it works
>> fine (but, I need to exit the application). I am trying to do this
>> without exiting the application, the reason why I was looking to update
>> the manifest file.
>> With you solution, I still need to exit the application.
> why? If you uninstall the bundle it's gone ... then you re-install the
> bundle with the updated variable. I would imagine if you are using
> system properties, uninstalling, change the property, and re-installing
> would allow the system property to be read a second time.
> Nothing in my post or example said "and restart the workbench" :-)
> PW
FUDForum. Page generated in 0.77484 seconds
