Home » Eclipse Projects » Eclipse Platform » Login Required for feature update/install?
Login Required for feature update/install? [message #334864] Wed, 04 March 2009 14:40
We've developed an Eclipse feature which we deploy updates using both
remote update sites as well as dowloadable site archives.
Just recently when someone tries to install the update, a "Login Required"
message box pops up asking for username/password claiming that our update
site JAR file requires a login (it doesn't). If you cancel, the install
continues just fine.
What is odd is that we have not seen this before and appears to have just
started to appear. I can't find any changes to our site.xml or
feature.xml files that would cause this behavior. It also doesn't appear
with Eclipse 3.3.
Has anyone seen this before?
If, so, do you know what triggers this?
Configuation details:
*** Date: Wednesday, March 4, 2009 11:40:07 AM PT
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=M20080911-1700
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
-launcher
C:\DD5_PDC\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
C:\DD5_PDC\eclipse\plugins\org.eclipse.equinox.launcher.win3 2.win32.x86_1.0.101.R34x_v20080731\eclipse_1115.dll
-startup
C:\DD5_PDC\eclipse\plugins\org.eclipse.equinox.launcher_1.0. 101.R34x_v20080819.jar
-exitdata
cc4_38
-debug
-data
C:\DD5_PDC\workspace
-vm
C:\tools\sun\jdk1.5.0_13\bin\javaw.exe
eclipse.ee.install.verify=false
eclipse.home.location=file:/C:/DD5_PDC/eclipse/
eclipse.launcher=C:\DD5_PDC\eclipse\eclipse.exe
eclipse.p2.data.area=@config.dir/../p2
eclipse.p2.profile=SDKProfile
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1236195505807
eclipse.vm=C:\tools\sun\jdk1.5.0_13\bin\javaw.exe
eclipse.vmargs=-Xmx512M
-XX:MaxPermSize=256m
-jar
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\DD5_PDC\eclipse\plugins\org.eclipse.equin ox.launcher_1.0.101.R34x_v20080819.jar
java.class.version=49.0
java.endorsed.dirs=C:\tools\sun\jdk1.5.0_13\jre\lib\endorsed
java.ext.dirs=C:\tools\sun\jdk1.5.0_13\jre\lib\ext
java.home=C:\tools\sun\jdk1.5.0_13\jre
java.io.tmpdir=d:\Temp\SysTemp\
java.library.path=C:\tools\sun\jdk1.5.0_13\bin;.;C:\WINDOWS\ system32;C:\WINDOWS;C:\Program
Files\Common Files\Avaya Modular
Messaging;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32 \Wbem;C:\Program
Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Avaya Modular
Messaging\Common;C:\Program Files\Avaya Modular
Messaging\Common;C:\Program Files\QuickTime\QTSystem\;C:\Program
Files\Windows Imaging\
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_13-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_13
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_13-b05
line.separator=
org.eclipse.equinox.launcher.splash.location=c:\DD5_PDC\ecli pse\plugins\org.eclipse.platform_3.3.101.v200809111700\splas h.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator\bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1.0
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.c ss,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3 c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal,o rg.w3c.dom.views
,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=reference:file:org.eclipse.equinox.simpleconfigurator_1.0.0.v20080604.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=C:\DD5_PDC\eclipse\configuration\org.eclips e.osgi\bundles
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/C:/DD5_PDC/eclipse/configurati on/
osgi.debug=
osgi.framework=file:/c:/DD5_PDC/eclipse/plugins/org.eclipse. osgi_3.4.2.R34x_v20080826-1230.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.4.2.R34x_v20080826-1230
osgi.install.area=file:/C:/DD5_PDC/eclipse/
osgi.instance.area=file:/C:/DD5_PDC/workspace/
osgi.instance.area.default=file:/C:/Documents and
Settings/ejohnson/workspace/
osgi.launcherIni=eclipse
osgi.launcherPath=.
osgi.logfile=C:\DD5_PDC\workspace\.metadata\.log
osgi.manifest.cache=C:\DD5_PDC\eclipse\configuration\org.ecl ipse.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=c:\DD5_PDC\eclipse\plugins\org.eclipse.p latform_3.3.101.v200809111700\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\DD5_PDC\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\tools\sun\jdk1.5.0_13\jre\lib\rt.jar; C:\tools\sun\jdk1.5.0_13\jre\lib\i18n.jar;C:\tools\sun\jdk1. 5.0_13\jre\lib\sunrsasign.jar;C:\tools\sun\jdk1.5.0_13\jre\l ib\jsse.jar;C:\tools\sun\jdk1.5.0_13\jre\lib\jce.jar;C:\tool s\sun\jdk1.5.0_13\jre\lib\charsets.jar;C:\tools\sun\jdk1.5.0 _13\jre\classes
sun.boot.library.path=C:\tools\sun\jdk1.5.0_13\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386
i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=C:\DD5_PDC\eclipse
user.home=C:\Documents and Settings\ejohnson
user.language=en
user.name=ejohnson
user.timezone=America/Los_Angeles
user.variant=
*** Features:
com.avaya.cc (5.0.0.1401) "Dialog Designer Call Control"
com.avaya.sce (5.0.0.1401) "Dialog Designer"
org.eclipse.cvs (1.1.1.r34x_20080902-7C79E8N9nJD4oAW9V1938) "Eclipse CVS
Client"
org.eclipse.datatools.common.doc.user
(1.6.1.v200809191145-1507w31191939244824) "Data Tools Platform Tutorial
Documentation"
org.eclipse.datatools.connectivity.doc.user
(1.6.1.v200809191145-27A18s733I3I7I599G59) "Data Tools Platform
Connectivity Documentation"
org.eclipse.datatools.connectivity.feature
(1.6.1.v200809191145-7_7K7_Dn-QY4jNGDlg0YiVa76H) "Data Tools Platform
Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature
(1.6.1.v200809191145-7C67OCYQCD4D-JkHcYh) "DTP ODA Designer UI Framework
Plug-in"
org.eclipse.datatools.connectivity.oda.feature
(1.6.1.v200809191145-7F27PBcMAAwAtKkESVZ) "DTP Open Data Access"
org.eclipse.datatools.doc.user (1.6.1.v200809191145-37A09oA55S5P_P8CEO24)
"Data Tools Platform User Documentation"
org.eclipse.datatools.enablement.apache.derby.feature
(1.6.1.v200809191145-652AlJAKaLiJyLhdmBEKK) "High-level Sybase Enablement
Plug-in"
org.eclipse.datatools.enablement.feature
(1.6.1.v200809191145-7D8H7C9FSwOBZabCz-MXEZLR8Rnc) "Eclipse Data Tools
Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature
(1.6.1.v200809191145-57_1_pF9IQJZIsJcVhBEKK) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.ibm.feature
(1.6.1.v200809191145-7D43EB7sQS9RbiYgHAa) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.jdbc.feature
(1.6.1.v200809191145-3-09oA55S5J8JADJJ) "High-level Sybase Enablement
Plug-in"
org.eclipse.datatools.enablement.msft.feature
(1.6.1.v200809191145-442_kE77c7VBQDFNW) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.mysql.feature
(1.6.1.v200809191145-442_kE77c7TBTBKPQ) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.oda.designer.feature
(1.6.1.v200809191145-2118s733I3I6C4_6C) "Eclipse Data Tools Platform XML
ODA Designer"
org.eclipse.datatools.enablement.oda.feature
(1.6.1.v200809191145-797P6CYQCD4CvIcEeNW) "Eclipse Data Tools Platform XML
ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature
(1.6.1.v200809191145-442_kE77c7UAOBJML) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.postgresql.feature
(1.6.1.v200809191145-441_kE77c7R_RCIOP) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.sap.feature
(1.6.1.v200809191145-440_kE77c7QAQEIQQ) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.sybase.feature
(1.6.1.v200809191145-7A-5E9IgKLhLGetRuu9) "High-level Sybase Enablement
Plug-in"
org.eclipse.datatools.intro (1.6.1.v200806271731-1507w311918132411)
"Eclipse Data Tools Platform Intro Plug-in"
org.eclipse.datatools.modelbase.feature
(1.6.1.v200809191145-6-0BcMAAwAmEgFXTT) "Eclipse Data Tools Platform
SQLModel Plug-in"
org.eclipse.datatools.sqldevtools.feature
(1.6.1.v200809191145-7F7d5E8yz-UHrDYUGnc_DXkE39Kp) "Eclipse Data Tools
Platform SQL Tools Common UI Plug-in"
org.eclipse.datatools.sqltools.doc.user
(1.6.1.v200809191145-1507w31191939244824) "Data Tools Platform SQL Dev
Tools Documentation"
org.eclipse.draw2d (3.4.1.v20080806-3307w31191_2102462) "Graphical Editing
Framework Draw2d"
org.eclipse.emf (2.4.1.v200808251517) "EMF - Eclipse Modeling Framework"
org.eclipse.emf.codegen (2.4.0.v200808251517) "EMF Code Generation"
org.eclipse.emf.codegen.ecore (2.4.1.v200808251517) "EMF Ecore Code
Generator"
org.eclipse.emf.codegen.ecore.ui (2.4.1.v200808251517) "EMF Ecore Code
Generator UI"
org.eclipse.emf.codegen.ui (2.4.0.v200808251517) "EMF Code Generation UI"
org.eclipse.emf.common (2.4.0.v200808251517) "EMF Common"
org.eclipse.emf.common.ui (2.4.0.v200808251517) "EMF Common UI"
org.eclipse.emf.converter (2.4.1.v200808251517) "EMF Model Converter"
org.eclipse.emf.databinding (1.0.0.v200808251517) "EMF Data Binding"
org.eclipse.emf.databinding.edit (1.0.0.v200808251517) "EMF Edit Data
Binding"
org.eclipse.emf.ecore (2.4.1.v200808251517) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.4.1.v200808251517) "EMF Ecore Edit"
org.eclipse.emf.ecore.editor (2.4.0.v200808251517) "EMF Sample Ecore
Editor"
org.eclipse.emf.ecore.sdo (2.4.0.v200808251517) "EMF SDO - EMF's Service
Data Objects Implementation"
org.eclipse.emf.ecore.sdo.edit (2.4.0.v200808251517) "EMF SDO Edit"
org.eclipse.emf.ecore.sdo.editor (2.4.0.v200808251517) "EMF SDO Editor"
org.eclipse.emf.edit (2.4.1.v200808251517) "EMF Edit"
org.eclipse.emf.edit.ui (2.4.1.v200808251517) "EMF Edit UI"
org.eclipse.emf.mapping (2.4.0.v200808251517) "EMF Mapping"
org.eclipse.emf.mapping.ecore (2.4.0.v200808251517) "EMF Ecore Mapping"
org.eclipse.emf.mapping.ecore.editor (2.4.0.v200808251517) "EMF Ecore
Mapping Editor"
org.eclipse.emf.mapping.ui (2.4.0.v200808251517) "EMF Mapping UI"
org.eclipse.gef (3.4.1.v20080806-67718083A56B4H2A3213573) "Graphical
Editing Framework GEF"
org.eclipse.help (1.0.1.R34x_v20080827-7r7xEIxEI6Zu5nEqN7M3UBpglaat) "Help
System Base"
org.eclipse.jdt (3.4.1.r341_v20080709-0800-7o7tEAfEF_U5qyUgrb2HAp539P97)
"Eclipse Java Development Tools"
org.eclipse.jst (3.0.2.v200808250510-7U-8r9LJ9cNr7UGsQ02P0aZsUk1o) "J2EE
Standard Tools (JST)"
org.eclipse.jst.ws.axis2tools.feature
(1.0.1.v200807092124-77-E_BCYQCD4CyNjOPRU) "J2EE Standard Tools (JST)"
org.eclipse.pde (3.4.1.r341_v20080731-7T7U0E9mlRIuGUYviF_VP) "PDE"
(3.4.1.r341_v20080731-9I96EiDElYevwz-p1bP5z-NlAaP7vtX6Utotqs u) "Eclipse
Platform"
org.eclipse.rcp (3.4.100.r341_v20080814-989JESIEdAciFYfkZZsBfSwQ2341)
"Eclipse RCP"
org.eclipse.sdk
(3.4.1.R34x_v20080827-7O7S78C2J40sK2o_ALcK8tLN_yZSJeg0P-3EtL 4Ra90kv)
"Eclipse Project SDK"
org.eclipse.wst (3.0.2.v200808250510-7A-8f8QqVJLTFUkFahb1QIq2z0t8) "Web
Standard Tools (WST)"
org.eclipse.wst.ws_wsdl14.feature (1.4.0.v200802280619-13-7w311917141518)
"Web Standard Tools (WST)"
org.eclipse.wst.ws_wsdl15.feature (1.5.1.v200802280619-1407w311917141519)
org.eclipse.xsd (2.4.1.v200808251517) "XSD - XML Schema Definition Model"
org.eclipse.xsd.ecore.converter (2.4.0.v200808251517) "XSD Ecore Converter"
org.eclipse.xsd.edit (2.4.0.v200808251517) "XSD Edit"
org.eclipse.xsd.editor (2.4.0.v200808251517) "XSD Sample Editor"
org.eclipse.xsd.mapping (2.4.0.v200808251517) "XSD Mapping"
org.eclipse.xsd.mapping.editor (2.4.0.v200808251517) "XSD Mapping Editor"
org.eclipse.zest (1.0.0.v20080115-5308xB5CE899O2A3213573) "Graphical
Editing Framework Zest Core"
*** Plug-in Registry:
com.avaya.ade.common.core (5.0.0.1401) "Common Core Plug-in" [Active]
com.avaya.ade.common.j2ee (5.0.0.1401) "J2EE Plug-in" [Active]
com.avaya.ade.common.j2ee.ui (5.0.0.1401) "J2EE UI Plug-in" [Starting]
com.avaya.ade.common.variables (5.0.0.1401) "Variables Plug-in" [Active]
com.avaya.cc.ccxml.ui (5.0.0.1401) "Ccxml UI Plug-in" [Starting]
com.avaya.cc.core (5.0.0.1401) "Callcontrol Core Plug-in" [Starting]
com.avaya.cc.dialogdesigner (5.0.0.1401) "Dialog Designer Call Control"
[Resolved]
com.avaya.sce.callflow (5.0.0.1401) "Callflow Plug-in" [Active]
com.avaya.sce.callflow.ui (5.0.0.1401) "Callflow Ui Plug-in" [Active]
com.avaya.sce.core (5.0.0.1401) "Core Plug-in" [Active]
com.avaya.sce.cti.ui (5.0.0.1401) "CTI Plug-in" [Active]
com.avaya.sce.db (5.0.0.1401) "Database Plug-in" [Active]
com.avaya.sce.db.ui (5.0.0.1401) "Database Ui Plug-in" [Active]
com.avaya.sce.dialogdesigner (5.0.0.1401) "Dialog Designer" [Resolved]
com.avaya.sce.grammars (5.0.0.1401) "Grammars Plug-in" [Active]
com.avaya.sce.grammars.ui (5.0.0.1401) "Grammars Ui Plug-in" [Starting]
com.avaya.sce.help (5.0.0.1401) "Dialog Designer Online Help" [Starting]
com.avaya.sce.ic.ui (5.0.0.1401) "IC Ui Plug-in" [Active]
com.avaya.sce.media (5.0.0.1401) "Media Plug-in" [Starting]
com.avaya.sce.media.ui (5.0.0.1401) "Media Ui Plug-in" [Starting]
com.avaya.sce.navigator (5.0.0.1401) "Navigator Plug-in" [Starting]
com.avaya.sce.phrases (5.0.0.1401) "Phrases Plug-in" [Starting]
com.avaya.sce.phrases.ui (5.0.0.1401) "Phrases Ui Plug-in" [Starting]
com.avaya.sce.prompts (5.0.0.1401) "Prompts Plug-in" [Starting]
com.avaya.sce.prompts.ui (5.0.0.1401) "Prompts Ui Plug-in" [Starting]
com.avaya.sce.rtsupport (5.0.0.1401) "Avaya Runtime Support Libraries
Plug-in" [Starting]
com.avaya.sce.variables.ui (5.0.0.1401) "Variables Ui Plug-in" [Starting]
com.avaya.sce.ws (5.0.0.1401) "WebServices Plug-in" [Starting]
com.avaya.sce.ws.ui (5.0.0.1401) "WebServices Ui Plug-in" [Active]
com.avaya.sceavb (5.0.0.1401) "Application Simulator" [Starting]
com.avaya.tools.audiorecorder (5.0.0.1401) "AudioRecorder Plug-in"
[Starting]
com.avaya.vp.admin.variables (5.0.0.1401) "VP Configurable Variables
Plug-in" [Active]
com.avaya.ws.axis (5.0.0.1401) "Axis Plug-in" [Starting]
com.ibm.icu (3.8.1.v20080530) "International Components for Unicode for
Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.37.v200803061811) "JSch" [Resolved]
com.sysdeo.eclipse.tomcat (5.0.0.1401) "Tomcat Plugin" [Active]
javax.activation (1.1.0.v200806101325) "Apache Geronimo Activation
Plug-in" [Resolved]
javax.mail (1.4.0.v200804091730) "Javax Mail Plug-in" [Resolved]
javax.servlet (2.4.0.v200806031604) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle"
[Resolved]
javax.wsdl (1.4.0.v200806030407) "WSDL4J" [Resolved]
javax.wsdl (1.5.1.v200806030408) "WSDL4J" [Resolved]
javax.xml (1.3.4.v200806030440) "JAXP XML" [Resolved]
javax.xml.rpc (1.1.0.v200806030420) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v200806030421) "SAAJ" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200803061910) "SourceForge LPG"
[Resolved]
org.apache.ant (1.7.0.v200803061910) "Apache Ant" [Resolved]
org.apache.axis (1.4.0.v200807230600) "Apache Web Services" [Resolved]
org.apache.cactus (1.7.2.v200805140145) "Cactus Resource Plug-in"
[Starting]
org.apache.commons.discovery (0.2.0.v200806030120) "Jakarta-Commons
Discovery" [Resolved]
org.apache.commons.el (1.0.0.v200806031608) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
org.apache.commons.logging (1.0.4.v20080605-1930) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.jasper (5.5.17.v200806031609) "Apache Jasper 2 Plug-in"
[Resolved]
org.apache.log4j (1.2.13.v200806030600) "Apache Jakarta log4j Plug-in"
[Resolved]
org.apache.lucene (1.9.1.v20080530-1600) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20080530-1600) "Apache Lucene Analysis"
[Resolved]
org.apache.wsil4j (1.0.0.v200806040330) "WSIL4J" [Resolved]
org.apache.xerces (2.9.0.v200805270400) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v200806030312) "Apache XmlResolver"
[Resolved]
org.apache.xml.serializer (2.7.1.v200806030322) "Apache XML Commons
Serializer" [Resolved]
org.eclipse.ant.core (3.2.0.v20080529) "Ant Build Tool Core" [Starting]
org.eclipse.ant.ui (3.3.0.v20080529) "Ant UI" [Starting]
org.eclipse.compare (3.4.0.I20080604) "Compare Support" [Starting]
org.eclipse.core.boot (3.1.100.v20080218) "Core Boot" [Starting]
org.eclipse.core.commands (3.4.0.I20080509-2000) "Commands" [Resolved]
org.eclipse.core.contenttype (3.3.0.v20080604-1400) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.databinding (1.1.1.M20080827-0800b) "JFace Data Binding"
[Active]
org.eclipse.core.databinding.beans (1.1.1.M20080827-0800a) "JFace Data
Binding for JavaBeans" [Resolved]
org.eclipse.core.expressions (3.4.0.v20080603-2000) "Expression Language"
[Active]
org.eclipse.core.filebuffers (3.4.0.v20080603-2000) "File Buffers" [Active]
org.eclipse.core.filesystem (1.2.0.v20080604-1400) "Core File Systems"
[Active]
org.eclipse.core.filesystem.win32.x86 (1.1.0.v20080604-1400) "Core File
System for Windows" [Resolved]
org.eclipse.core.jobs (3.4.0.v20080512) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.1.0.I20080604) "Internet Connection Management"
[Active]
org.eclipse.core.net.win32.x86 (1.0.0.I20080521) "Proxy for Windows"
[Resolved]
org.eclipse.core.resources (3.4.1.R34x_v20080902) "Core Resource
Management" [Active]
org.eclipse.core.resources.compatibility (3.4.0.v20080604-1400) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32.x86 (3.4.0.v20071204) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.4.0.v20080512) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.0.v20071008) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.200.v20080610)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.100.v20080529-1300) "Core Variables"
[Starting]
org.eclipse.cvs (1.0.100.v20080603) "Eclipse CVS Client" [Starting]
org.eclipse.datatools.common.doc.user (1.6.1.v20080828133713) "Data Tools
Platform Tutorial Documentation" [Resolved]
org.eclipse.datatools.connectivity (1.1.1.v200809180120) "Data Tools
Platform Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby (1.0.1.v200807150030)
"Eclipse Data Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform Apache Derby Database
Definition" [Starting]
org.eclipse.datatools.connectivity.apache.derby.ui (1.0.1.v200807010433)
"Eclipse Data Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.console.profile (1.0.0.v200805231345)
"DTP Connection Profiles Storage File Editor Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.0.v200805152355)
"Eclipse Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.v200805152355)
"Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC
(1.0.0.v200805152355) "Eclipse Data Tools Platform DBDefinition Generic
JDBC Plug-in" [Starting]
org.eclipse.datatools.connectivity.doc.user (1.6.1.v20080828133713) "Data
Tools Platform Connectivity Documentation" [Resolved]
org.eclipse.datatools.connectivity.doc.user.contexts
(1.6.1.v20080828133713) "Data Tools Platform Connectivity Documentation
for context-sensitive help" [Resolved]
org.eclipse.datatools.connectivity.oda (3.1.3.v200808270255) "DTP Open
Data Access" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.1.3.v200808270255) "DTP
ODA Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.0.7.v200807231215) "DTP
ODA Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.0.7.v200808051050)
"DTP ODA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.0.7.v200808261835)
"Eclipse Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.0.7.v200808130628)
"Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.0.6.v200805152355) "DTP
ODA Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.0.6.v200805152355)
"DTP ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.0.3.v200809180120) "Eclipse
Data Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.1.1.v200808140022)
"Eclipse Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.1.1.v200808300421)
"Eclipse Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.1.2.v200809150616) "Data Tools
Platform Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.1.1.v200807230727) "Eclipse
Data Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.doc.user (1.6.1.v20080828133713) "Data Tools
Platform User Documentation" [Resolved]
org.eclipse.datatools.enablement.finfo (1.5.1.v200805152355) "Eclipse Data
Tools Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.v200805152355) "Eclipse
Data Tools Platform HSQLDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.dbdefinition (1.0.0.v200805152355)
"Eclipse Data Tools Platform HSQLDB Database Definition Enablement
Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.ui (1.0.0.v200807220100) "Eclipse
Data Tools Platform HSQLDB UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries (1.0.0.v200805152355)
"Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n
(1.0.0.v200806100223) "DB2 UDB iSeries Database Definition Plug-in"
[Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.ui (1.0.0.v200805160737)
"Eclipse Data Tools Platform IBM DB2 UDB UI iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw (1.0.0.v200805152355)
"Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform DB2 UDB Database
Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.ui (1.0.1.v200806260315)
"Eclipse Data Tools Platform IBM DB2 UDB LUW UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries (1.0.0.v200805152355)
"Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n
(1.0.0.v200805152355) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.ui (1.0.0.v200805160737)
"Eclipse Data Tools Platform IBM DB2 UDB zSeries UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix (1.0.0.v200805152355)
"Eclipse Data Tools Platform Informix Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition
(1.0.1.v200807170829) "Eclipse Data Tools Platform Informix Database
org.eclipse.datatools.enablement.ibm.informix.ui (1.0.1.v200806260315)
"Eclipse Data Tools Platform Informix UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.ui (1.0.0.v200806271414) "Eclipse
Data Tools Platform IBM UI Plug-in" [Starting]
org.eclipse.datatools.enablement.jdt.classpath (1.0.1.v200805152355) "Data
Tools Platform Connectivity JDT Extension Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver (1.0.1.v200807181158)
"Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform SQL Server Database
org.eclipse.datatools.enablement.msft.sqlserver.ui (1.0.1.v200808222228)
"Eclipse Data Tools Platform Microsoft SQL Server UI Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.1.v200808261158) "Eclipse Data
Tools Platform MySQL Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.1.v200805170742)
"Eclipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.ui (1.0.0.v200805152355) "Eclipse
Data Tools Platform MySQL UI Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.1.1.v200808211640) "Eclipse
Data Tools Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.1.1.v200808271112) "Eclipse
Data Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.1.1.v200808261409) "Eclipse
Data Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.1.1.v200808130628) "Eclipse
Data Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle (1.0.0.v200805152355) "Eclipse
Data Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.1.v200808021450)
"Eclipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.ui (1.0.1.v200806260315) "Eclipse
Data Tools Platform Oracle UI Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql (1.0.1.v200805152355)
"PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition
(1.0.0.v200805152355) "PostgreSQL DB Definition" [Starting]
org.eclipse.datatools.enablement.postgresql.ui (1.0.0.v200806060334)
"PostgreSQL Connection Profile and Driver Template UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb (1.0.0.v200805152355) "Eclipse
Data Tools Platform MaxDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform MaxDB Definition
Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.ui (1.0.0.v200805152355)
"Eclipse Data Tools Platform MaxDB UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.v200805310538) "High-level
Sybase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.1.v200805310538) "Sybase
ASA Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa.dbdefinition
(1.0.0.v200805240040) "Eclipse Data Tools Platform Sybase ASA Database
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.v200805152355)
"Sybase ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.asa.ui (1.0.1.v200805310538)
"Sybase ASA Connection Profile UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase (1.0.1.v200807010411)
"JDBC/Sybase ASE Connection Profile Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition
(1.0.0.v200805240040) "Eclipse Data Tools Platform Sybase ASE Database
org.eclipse.datatools.enablement.sybase.ase.models (1.0.1.v200805152355)
"Sybase ASE Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.ui (1.0.1.v200806260315) "ASE
Enablement UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.models (1.0.0.v200805152355)
"Sybase Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ui (1.0.0.v200808221518) "Sybase
org.eclipse.datatools.help (1.5.0.v200805152355) "Data Tools Platform Help
Utilities" [Resolved]
org.eclipse.datatools.intro (1.6.1.v200807021300) "Eclipse Data Tools
Platform Intro Plug-in" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.0.v200808020150)
"Eclipse Data Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.v200805152355) "Derby
Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql (1.0.0.v200805152355) "Eclipse Data
Tools Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.0.v200805152355) "Eclipse
Data Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.0.1.v200807251820) "Eclipse
Data Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.query.edit (1.0.0.v200806070329) "SQL
Query Edit Support Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.0.v200807080500)
"Eclipse Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.1.0.v200808280228) "DTP ODA
Context-sensitive Help" [Starting]
org.eclipse.datatools.sqltools.common.ui (1.0.0.v200807211830) "Eclipse
Data Tools Platform SQL Tools Common UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.data.core (1.0.0.v200808260630) "Data Core
Plugin" [Starting]
org.eclipse.datatools.sqltools.data.ui (1.1.0.v200808260630) "Data UI
Plugin" [Starting]
org.eclipse.datatools.sqltools.db.derby (1.0.0.v200805152355) "Eclipse
Data Tools Platform Derby SQL Tools Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic (1.0.0.v200808140643) "Eclipse
Data Tools Platform SQL Tools Generic Database Plug-in" [Starting]
org.eclipse.datatools.sqltools.ddlgen.ui (1.0.0.v200808140615) "Eclipse
Data Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.debugger.core (1.0.0.v200808140615)
"Eclipse Data Tools Platform SQL Debugger Framework" [Starting]
org.eclipse.datatools.sqltools.doc.user (1.6.1.v20080828133713) "Data
Tools Platform SQL Dev Tools Documentation" [Resolved]
org.eclipse.datatools.sqltools.editor.core (1.0.0.v200808271350) "Eclipse
Data Tools Platform SQL Editor Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql (1.0.1.v200808140615) "Eclipse
Data Tools Platform SQL Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.1.v200808080530)
"Eclipse Data Tools Platform Lexer Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.query (1.0.1.v200808140615)
"Eclipse Data Tools Platform SQL Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (1.0.0.v200808140615)
"Eclipse Data Tools Platform SQL XML Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.plan (1.0.0.v200807211830) "Eclipse Data
Tools Platform SQL Execution Plan View Plug-in" [Starting]
org.eclipse.datatools.sqltools.result (1.0.0.v200808271350) "Eclipse Data
Tools Platform SQL Results View Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor (1.0.0.v200807211830)
"Eclipse Data Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql (1.0.0.v200808140615) "Eclipse Data
Tools Platform SQL Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.sqlbuilder (1.0.0.v200808271350) "SQL
Builder" [Starting]
org.eclipse.datatools.sqltools.sqleditor (1.0.0.v200808271350) "Eclipse
Data Tools Platform SQL Editor" [Starting]
org.eclipse.datatools.sqltools.sqlscrapbook (1.0.0.v200808271350) "Eclipse
Data Tools Platform Sqlscrapbook Plug-in" [Starting]
org.eclipse.datatools.sqltools.tabledataeditor (1.0.0.v200808300730)
"Eclipse Data Tools Platform Table Data Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.tablewizard (1.0.0.v200808140615) "Eclipse
Data Tools Platform Database Table Creation Plug-in" [Starting]
org.eclipse.debug.core (3.4.0.v20080612) "Debug Core" [Active]
org.eclipse.debug.ui (3.4.1.v20080811_r341) "Debug UI" [Starting]
org.eclipse.draw2d (3.4.1.v20080910-1351) "Graphical Editing Framework
Draw2d" [Starting]
org.eclipse.ecf (2.0.0.v20080611-1715) "Eclipse Communication Framework
(ECF)" [Starting]
org.eclipse.ecf.filetransfer (2.0.0.v20080611-1715) "ECF Filetransfer API"
[Starting]
org.eclipse.ecf.identity (2.0.0.v20080611-1715) "ECF Identity API"
[Starting]
org.eclipse.ecf.provider.filetransfer (2.0.0.v20080611-1715) "ECF
Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20080611-1715) "ECF
Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.0.0.v20080611-1715) "Eclipse Communication
Framework (ECF)" [Resolved]
org.eclipse.emf (2.4.0.v200808251517) "EMF - Eclipse Modeling Framework"
[Starting]
org.eclipse.emf.ant (2.4.0.v200808251517) "EMF Ant Tasks" [Starting]
[Starting]
Generator" [Starting]
Generator UI" [Starting]
[Starting]
org.eclipse.emf.common (2.4.0.v200808251517) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.4.0.v200808251517) "EMF Common UI" [Starting]
org.eclipse.emf.commonj.sdo (2.4.0.v200808251517) "CommonJ SDO - Service
Data Objects" [Starting]
org.eclipse.emf.converter (2.4.0.v200808251517) "EMF Model Converter"
[Starting]
[Starting]
Binding" [Starting]
org.eclipse.emf.ecore (2.4.1.v200808251517) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.4.0.v200808251517) "EMF Change Model"
[Starting]
org.eclipse.emf.ecore.change.edit (2.4.0.v200808251517) "EMF Change Edit"
[Starting]
[Starting]
Editor" [Starting]
Data Objects Implementation" [Starting]
[Starting]
[Starting]
org.eclipse.emf.ecore.xmi (2.4.1.v200808251517) "EMF XML/XMI Persistence"
[Starting]
org.eclipse.emf.edit (2.4.1.v200808251517) "EMF Edit" [Starting]
org.eclipse.emf.edit.ui (2.4.1.v200808251517) "EMF Edit UI" [Starting]
org.eclipse.emf.exporter (2.4.0.v200808251517) "EMF Model Exporter"
[Starting]
org.eclipse.emf.importer (2.4.1.v200808251517) "EMF Model Importer"
[Starting]
org.eclipse.emf.importer.ecore (2.4.0.v200808251517) "EMF Ecore Importer"
[Starting]
org.eclipse.emf.importer.java (2.4.1.v200808251517) "EMF Annotated Java
Importer" [Starting]
org.eclipse.emf.importer.rose (2.4.0.v200808251517) "EMF Rose Importer"
[Starting]
org.eclipse.emf.mapping (2.4.0.v200808251517) "EMF Mapping" [Starting]
[Starting]
Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.4.0.v200808251517) "EMF Ecore to
Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.4.0.v200808251517) "EMF
Ecore to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.4.0.v200808251517) "EMF Ecore to XML
Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.4.0.v200808251517) "EMF Ecore to
XML Mapping Editor" [Starting]
[Starting]
org.eclipse.emf.mapping.xsd2ecore (2.4.0.v200808251517) "XSD to Ecore
Mapping" [Starting]
org.eclipse.emf.mapping.xsd2ecore.editor (2.4.0.v200808251517) "XSD to
org.eclipse.equinox.app (1.1.0.v20080421-2006) "Equinox Application
Container" [Active]
org.eclipse.equinox.common (3.4.0.v20080421-2006) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.frameworkadmin (1.0.2.R34x_v20080910) "Equinox
Framework Admin" [Active]
org.eclipse.equinox.frameworkadmin.equinox (1.0.2.R34x_v20080911) "Equinox
Framework Admin for Equinox" [Active]
org.eclipse.equinox.http.jetty (1.1.0.v20080425) "Jetty Http Service"
[Starting]
org.eclipse.equinox.http.registry (1.0.100.v20080427-0830) "Http Service
Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.0.100.v20080427-0830) "Http Services
Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.100.v20080427-0830) "Jasper Jsp
Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20080427-0830) "Jasper Jsp
Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.0.101.R34x_v20080819) "Equinox Launcher"
[Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.0.101.R34x_v20080731)
"Equinox Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.0.2.R34x_v20080808-1156)
"Equinox Provisioning Artifact Repository Support" [Active]
org.eclipse.equinox.p2.console (1.0.0.v20080514-1900) "Equinox
Provisioning Console" [Starting]
org.eclipse.equinox.p2.core (1.0.0.v20080530-1237) "Equinox Provisioning
Core" [Active]
org.eclipse.equinox.p2.director (1.0.2.v20080806-1619) "Equinox
Provisioning Director" [Active]
org.eclipse.equinox.p2.director.app (1.0.1.R34x_v20080729) "Equinox
Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.directorywatcher (1.0.2.v20080806-1619) "Equinox
Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.engine (1.0.1.R34x_v20080827) "Equinox Provisioning
Engine" [Active]
org.eclipse.equinox.p2.exemplarysetup (1.0.0.v20080427-2136) "Equinox
Provisioning Exemplary Setup" [Active]
org.eclipse.equinox.p2.extensionlocation (1.0.2.R34x_v20080825) "Extension
Location Repository Support" [Active]
org.eclipse.equinox.p2.garbagecollector (1.0.1.R34x_v20080818)
"Provisioning Garbage Collector" [Active]
org.eclipse.equinox.p2.jarprocessor (1.0.0.v20080514-1900) "Equinox
Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.metadata (1.0.0.v20080514-1900) "Equinox
Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.generator (1.0.1.R34x_v20080819) "Equinox
Provisioning Metadata Generator" [Active]
org.eclipse.equinox.p2.metadata.repository (1.0.0.v20080604) "Equinox
Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.reconciler.dropins (1.0.2.R34x_v20080909) "Dropin
Reconciler Plug-in" [Active]
org.eclipse.equinox.p2.touchpoint.eclipse (1.0.2.R34x_v20080910) "Equinox
Provisioning Eclipse Touchpoint" [Active]
org.eclipse.equinox.p2.touchpoint.natives (1.0.0.v20080505-1850) "Equinox
Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.ui (1.0.1.R34x_v20080909) "Equinox Provisioning UI
Support" [Active]
org.eclipse.equinox.p2.ui.sdk (1.0.1.R34x_v20080818) "Equinox Provisioning
Platform Update Support" [Active]
org.eclipse.equinox.p2.updatechecker (1.0.0.v20080427-2136) "Equinox
Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatesite (1.0.1.R34x_v20080808-1156) "Update site
repository adapter bundle (Incubation)" [Starting]
org.eclipse.equinox.preferences (3.2.201.R34x_v20080709) "Eclipse
Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.4.0.v20080516-0950) "Extension Registry
Support" [Active]
org.eclipse.equinox.security (1.0.1.R34x_v20080721) "Equinox Java
Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.ui (1.0.0.v20080603-1810) "Equinox Security
Default UI" [Starting]
org.eclipse.equinox.security.win32.x86 (1.0.0.v20080529-1600) "Windows
Data Protection services integration" [Resolved]
org.eclipse.equinox.simpleconfigurator (1.0.0.v20080604) "Simple
Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (1.0.2.R34x_v20080911)
"Simple Configurator Manipulator" [Active]
org.eclipse.gef (3.4.1.v20080806) "Graphical Editing Framework GEF"
[Active]
org.eclipse.help (3.3.101.v20080702_34x) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.300.v20080507) "Help Application Server"
[Starting]
org.eclipse.help.base (3.3.101.M20080728_34x) "Help System Base" [Starting]
org.eclipse.help.ui (3.3.101.M20080715_34x) "Help System UI" [Starting]
org.eclipse.help.webapp (3.3.101.M20080805_34x) "Help System Webapp"
[Starting]
org.eclipse.jdt (3.4.1.r341_v20080709-0800) "Eclipse Java Development
Tools" [Resolved]
org.eclipse.jdt.apt.core (3.3.101.R34x_v20080902-1220) "Java Annotation
Processing Core" [Starting]
org.eclipse.jdt.apt.pluggable.core (1.0.100.v20080407-1345) "Java Compiler
Apt IDE" [Installed]
org.eclipse.jdt.apt.ui (3.3.100.v20080407-1345) "Java Annotation
Processing UI" [Starting]
org.eclipse.jdt.compiler.apt (1.0.100.v20080513-1235) "Java Compiler Apt"
[Installed]
org.eclipse.jdt.compiler.tool (1.0.100.v_883_R34x) "Java Compiler Tool
Support" [Installed]
org.eclipse.jdt.core (3.4.2.v_883_R34x) "Java Development Tools Core"
[Active]
org.eclipse.jdt.core.manipulation (1.2.0.v20080603-2000) "Java Code
Manipulation Functionality" [Active]
org.eclipse.jdt.debug (3.4.0.v20080604) "JDI Debug Model" [Starting]
org.eclipse.jdt.debug.ui (3.3.1.v20080730_r341) "JDI Debug UI" [Starting]
org.eclipse.jdt.doc.isv (3.4.1.r341_v20080716-0800) "Eclipse JDT Plug-in
Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.4.1.r341_v20080820-0800) "Eclipse Java
development user guide" [Resolved]
org.eclipse.jdt.junit (3.4.0.v20080603-2000) "Java Development Tools JUnit
support" [Active]
org.eclipse.jdt.junit.runtime (3.3.0.v20080603-2000) "Java Development
Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.200.v20080603-2000) "Java Development
Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.4.1.v20080729_r341) "Java Development Tools
Launching Support" [Active]
org.eclipse.jdt.ui (3.4.1.r341_v20080827-1100) "Java Development Tools UI"
[Active]
org.eclipse.jem (2.0.201.v200806201600) "Java EMF Model" [Starting]
org.eclipse.jem.beaninfo (2.0.100.v200806051600) "Java EMF Model BeanInfo
(Introspection) Support" [Starting]
org.eclipse.jem.proxy (2.0.100.v200806051600) "Java EMF Model Proxy
Support" [Starting]
org.eclipse.jem.ui (2.0.100.v200806051600) "Java EMF Model UI" [Starting]
org.eclipse.jem.util (2.0.100.v200805140020) "Java EMF Model Utilities"
[Active]
org.eclipse.jem.workbench (2.0.101.v200807170530) "Java EMF Model
Workbench Support" [Starting]
org.eclipse.jface (3.4.1.M20080827-2000) "JFace" [Active]
org.eclipse.jface.databinding (1.2.1.M20080827-0800a) "JFace Data Binding
for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.4.1.r341_v20080827-1100) "JFace Text" [Resolved]
org.eclipse.jpt (2.0.0.v200802060000) "Java Persistence API Tools"
[Resolved]
org.eclipse.jpt.core (2.0.101.v200809020200) "Java Persistence API Tools -
Core" [Starting]
org.eclipse.jpt.db (1.1.2.v200809112059) "Java Persistence API Tools - DB"
[Starting]
org.eclipse.jpt.db.ui (1.0.1.v200805020000) "Java Persistence API Tools -
DB UI" [Resolved]
org.eclipse.jpt.doc.user (1.0.201.v200809020200) "Java Persistence
Documentation - Doc" [Starting]
org.eclipse.jpt.eclipselink.core (1.0.0.v200806050000) "Java Persistence
API Tools - EclipseLink Support - Core" [Starting]
org.eclipse.jpt.eclipselink.core.ddlgen (1.0.0) "Java Persistence API
Tools - EclipseLink Support - DDL Generation" [Resolved]
org.eclipse.jpt.eclipselink.ui (1.0.0.v200805300000) "Java Persistence API
Tools - EclipseLink Support - UI" [Starting]
org.eclipse.jpt.gen (1.1.0.v200805020000) "Java Persistence API Tools -
Entity Gen" [Resolved]
org.eclipse.jpt.ui (2.0.101.v200809030200) "Java Persistence API Tools -
UI" [Starting]
org.eclipse.jpt.utility (1.2.100.v200808060200) "Java Persistence API
Tools - Utility" [Resolved]
org.eclipse.jsch.core (1.1.100.I20080604) "JSch Core" [Starting]
org.eclipse.jsch.ui (1.1.100.I20080415) "JSch UI" [Starting]
org.eclipse.jst (1.0.100.v200805140017) "J2EE Standard Tools (JST)"
[Resolved]
org.eclipse.jst.common.annotations.controller (1.1.100.v200805140020)
"Annotation Controller Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (1.1.100.v200805140020)
"Annotation Core Plug-in" [Resolved]
org.eclipse.jst.common.annotations.ui (1.1.102.v200806010600) "Annotations
org.eclipse.jst.common.frameworks (1.1.200.v200805140020) "Integration
Plug-in" [Starting]
org.eclipse.jst.common.project.facet.core (1.3.1.v200807031821) "Project
Facet Core (Java Support)" [Starting]
org.eclipse.jst.common.project.facet.ui (1.3.1.v200807031821) "Project
Facet UI (Java Support)" [Starting]
org.eclipse.jst.ejb.doc.user (1.1.0.v200805152320) "EJB docs" [Starting]
org.eclipse.jst.ejb.ui (1.1.202.v200809040612) "WTP EJB UI Plug-in"
[Starting]
org.eclipse.jst.ejb.ui.infopop (1.0.100.v200805222207) "EJB infopop"
[Starting]
org.eclipse.jst.j2ee (1.1.203.v200809102205) "Java EE Component" [Starting]
org.eclipse.jst.j2ee.core (1.1.201.v200808071630) "J2EE Core Component"
[Starting]
org.eclipse.jst.j2ee.doc.user (1.1.1.v200808070608) "J2EE tools
documentation" [Resolved]
org.eclipse.jst.j2ee.ejb (1.1.202.v200809040612) "EJB component Plug-in"
[Starting]
org.eclipse.jst.j2ee.ejb.annotation.model (1.1.102.v200805140020) "EJB
Annotation Model Plug-in" [Starting]
org.eclipse.jst.j2ee.ejb.annotations.emitter (1.1.102.v200805140135) "EJB
Emitter Plug-in" [Starting]
org.eclipse.jst.j2ee.ejb.annotations.ui (1.1.102.v200805140020) "EJB
Annotations Ui Plug-in" [Starting]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.2.0.v200805140020)
"Xdoclet Annotations Plug-in" [Starting]
org.eclipse.jst.j2ee.infopop (1.0.300.v200805140415) "J2EE tools infopops"
[Resolved]
org.eclipse.jst.j2ee.jca (1.1.202.v200809102205) "JCA Plug-in" [Starting]
org.eclipse.jst.j2ee.jca.ui (1.1.200.v200805140020) "WTP JCA UI Plug-in"
[Starting]
org.eclipse.jst.j2ee.navigator.ui (1.1.201.v200807240600) "J2EE Extensions
to Common Navigator" [Starting]
org.eclipse.jst.j2ee.ui (1.1.203.v200809102205) "WTP J2EE UI Plug-in"
[Starting]
org.eclipse.jst.j2ee.web (1.1.201.v200807290757) "Web Plug-in" [Starting]
org.eclipse.jst.j2ee.webservice (1.1.201.v200807240600) "Web Service
Plug-in" [Starting]
org.eclipse.jst.j2ee.webservice.ui (1.1.200.v200805140020) "WTP Webservice
org.eclipse.jst.j2ee.xdoclet.runtime (1.1.102.v200805140135)
"XDocletRuntime Plug-in" [Starting]
org.eclipse.jst.jee (1.0.101.v200807240600) "JEE common Plug-in" [Starting]
org.eclipse.jst.jee.ejb (1.0.101.v200807240600) "JEE Ejb Plug-in"
[Starting]
org.eclipse.jst.jee.ui (1.0.102.v200809102205) "Ui Plug-in" [Starting]
org.eclipse.jst.jee.web (1.0.100.v200805140020) "JEE Web Plug-in"
[Starting]
org.eclipse.jst.jsf.apache.trinidad.tagsupport (1.0.100.v200808071446)
"JavaServer Faces Tools - Taglibrary Metadata (Apache Trinidad)" [Starting]
org.eclipse.jst.jsf.common (1.1.3.v20080915) "JavaServer Faces Tools -
Common" [Active]
org.eclipse.jst.jsf.common.runtime (1.0.100.v200808071446) "JavaServer
Faces Tools - Common Runtime" [Starting]
org.eclipse.jst.jsf.common.ui (1.1.0.v20080605) "JavaServer Faces Tools -
org.eclipse.jst.jsf.core (1.1.102.v20080909) "JavaServer Faces Tools -
Core" [Active]
org.eclipse.jst.jsf.doc.user (1.1.100.v20080811) "JavaServer Faces Tools -
User Guide" [Starting]
org.eclipse.jst.jsf.facesconfig (1.1.0.v20080605) "JavaServer Faces Tools
- FacesConfig Model" [Starting]
org.eclipse.jst.jsf.facesconfig.ui (1.1.2.v20080909) "JavaServer Faces
Tools - FacesConfig Editor" [Starting]
org.eclipse.jst.jsf.standard.tagsupport (1.1.101.v20080828) "JavaServer
Faces Tools - Taglibrary Metadata" [Starting]
org.eclipse.jst.jsf.ui (1.1.101.v20080909) "JavaServer Faces Tools - UI"
[Starting]
org.eclipse.jst.jsp.core (1.2.110.v200809120122) "Structured Source JSP
Model" [Starting]
org.eclipse.jst.jsp.ui (1.1.310.v200809120122) "SSE JSP Source Editor"
[Starting]
org.eclipse.jst.jsp.ui.infopop (1.0.100.v200805301545) "JSP tools
infopops" [Resolved]
org.eclipse.jst.pagedesigner (1.1.0.v20080605) "JavaServer Faces Tools -
Web Page Editor" [Starting]
org.eclipse.jst.pagedesigner.jsf.ui (1.1.0.v20080605) "JavaServer Faces
Tools - Pagedesigner UI" [Starting]
org.eclipse.jst.pagedesigner.jsp.core (1.1.0.v20080605) "JavaServer Faces
Tools - JSP Core Pagedesigner" [Starting]
org.eclipse.jst.server.core (1.1.1.v20080730) "Java Server Support"
[Starting]
org.eclipse.jst.server.generic.core (1.0.305.v200805140145) "Generic
Server Plugin" [Starting]
org.eclipse.jst.server.generic.jboss (1.5.205.v200805140145) "JBoss
Generic server definitions" [Starting]
org.eclipse.jst.server.generic.jonas (1.5.205.v200805140145) "JOnAS
Generic Server definitions" [Starting]
org.eclipse.jst.server.generic.oc4j (1.5.205.v200805140145) "Oracle OC4J
v10.1.3 DP4 Generic Server Definition Core Plug-in" [Starting]
org.eclipse.jst.server.generic.ui (1.0.305.v200805140145) "Generic Server
Plugin UI" [Starting]
org.eclipse.jst.server.installable (1.5.202.v200805140145) "Installable
server adapters" [Resolved]
org.eclipse.jst.server.preview.adapter (1.0.101.v20080730) "JEE Preview
Server Support" [Starting]
org.eclipse.jst.server.tomcat.core (1.1.103.v20080827) "Apache Tomcat
Support" [Starting]
org.eclipse.jst.server.tomcat.ui (1.1.101.v20080620) "Apache Tomcat UI
Support" [Starting]
org.eclipse.jst.server.ui (1.0.303.v200805140145) "Java Server UI Support"
[Starting]
org.eclipse.jst.server.ui.doc.user (1.0.400.v200805150133) "Server Tools
documentation for J2EE Standard Tools" [Starting]
org.eclipse.jst.server.ui.infopop (1.0.400.v200805140145) "Server Tools
infopops for J2EE Standard Tools" [Resolved]
org.eclipse.jst.server.websphere.core (1.0.302.v20080620) "WebSphere
org.eclipse.jst.servlet.ui (1.1.202.v200809102205) "WTP Servlet UI
Plug-in" [Starting]
org.eclipse.jst.servlet.ui.infopop (1.0.300.v200805140415) "Servlet
infopop" [Starting]
org.eclipse.jst.standard.schemas (1.0.101.v200807220523) "JEE Related
Schemas" [Resolved]
org.eclipse.jst.ws (1.0.305.v200807302152) "Web Services" [Starting]
org.eclipse.jst.ws
Previous Topic:Properties from plugin.properties are not resolved
Next Topic:Plugin supplies global ant property, but build.xml doesn't see it
Current Time: Wed Apr 16 16:59:27 EDT 2025
Powered by FUDForum. Page generated in 0.03192 seconds
