[JFace] tristate tree viewer [message #334836] |
Mon, 02 March 2009 18:04 |
Originally posted by: alamothe.ptt.yu
I'm unsuccessfully trying to get a tristate behaviour in CheckboxTreeViewer,
that is an item can be checked, grayed or unchecked. Is this the limitation
of JFace, SWT Tree control or I'm doing something wrong??
Re: [JFace] tristate tree viewer [message #334840 is a reply to message #334836] |
Mon, 02 March 2009 18:26 |
It appears to be a limitation of SWT...
Nikola Mihajlovic wrote:
> CheckboxTreeViewer, that is an item can be checked, grayed or
> unchecked. Is this the limitation of JFace, SWT Tree control or I'm
Re: [JFace] tristate tree viewer [message #334843 is a reply to message #334841] |
Mon, 02 March 2009 22:59 |
While I can programatically set one of the three states, a user cannot cycle
between three states with a mouse click, but only between two. Since it's a
problem with SWT, I've posted this on their newsgroup (the same problem
exists with a regular checkbox, that is not inside the Tree)
Mircea Luchian wrote:
> Use "checkboxTreeViewer.setChecked()" and
> "checkboxTreeViewer.setGrayChecked()". This will give you the tristate
> behavior.
> Mircea
>>> Hi,
Re: [JFace] tristate tree viewer [message #334849 is a reply to message #334843] |
Tue, 03 March 2009 11:28 |
Hitesh Messages: 19 Registered: July 2009 |
Junior Member |
It should be possible to work around this.I thought I'll share this - hope
it helps.
It is possible to add a ICheckStateListener and manipulate the state, for
example :
chkBoxViewer.addCheckStateListener(new ICheckStateListener(){
public void checkStateChanged(CheckStateChangedEvent event) {
MyModel item=(MyModel) event.getElement();
switch (item.state) {
case 0:{
chkBoxViewer.setGrayChecked(item, true);
break;
case 1:{
chkBoxViewer.setGrayed(item, false);
chkBoxViewer.setChecked(item, true);
break;
case 2:{
chkBoxViewer.setGrayChecked(item, false);
break;
item.state=++item.state%3;
Hitesh
>> behavior.
>> Mircea
>>>> Hi,
Re: [JFace] tristate tree viewer [message #334850 is a reply to message #334849] |
Tue, 03 March 2009 13:13 |
Thanks! It's exactly how I solved this problem :-)
> hope it helps.
> for example :
> case 0:{
> break;
> case 1:{
> break;
> case 2:{
> break;
> Hitesh
>> cannot cycle between three states with a mouse click, but only
>> between two. Since it's a problem with SWT, I've posted this on
>> their newsgroup (the same problem exists with a regular checkbox,
>>> tristate behavior.
>>> Mircea
>>>>> Hi,
FUDForum. Page generated in 0.04471 seconds
