Expose encoding validation to another plugins [message #334800] |
Fri, 27 February 2009 12:16  |
I'm not sure if here's the right place, but we need help from ui.ide team
to solve a kind of inconsistency in Eclipse behavior.
File encoding selection and validation in "project properties > resource"
(ui.ide) is different from the one in "run configurations > common"
(debug.ui).
I've wrote a patch to change both plug-ins and allow debug.ui having the
same behavior and reusing code from ui.ide.
The problem is that even tough ui.ide changes are simple, debug.ui team
doesn't have commit access to implement them. This is the related bug:
http://bugs.eclipse.org/bugs/show_bug.cgi?id=244708. We start ui.ide
discussion after comment 10.
Could you guys please help us to implement the enhancement? You could just
apply the patch, and move encoding validation out from the internal
package if suitable (we discuss this in the comments).
Thanks in advance.
FUDForum. Page generated in 0.03227 seconds
