Home » Eclipse Projects » Eclipse Platform » String Externalization/Localization/I18N Tools
String Externalization/Localization/I18N Tools [message #334711] Wed, 25 February 2009 08:15 Go to next message
Are there tools/editors out there that can help me edit the .properties
files needed to localize a plugin? Is there some tool that lets me edit
a central file and then generates all the *_xy.properties files?
Another question. Suppose I use Eclipse's string externalization
mechanism: then I have to keep in sync the public static String field
names with the names of the keys in the properties file. I was
pleasantly surprised to find out that renaming the field name with a
refactoring will also change it in the properties file. But only in the
main properties file: not in the various *_xy.properties files sitting
next to the main one. Is this normal behavior, or am I doing anything
wrong? Any other tool support I should be aware of?
J.-P.
Re: String Externalization/Localization/I18N Tools [message #334736 is a reply to message #334711] Wed, 25 February 2009 12:48 Go to previous message
J.-P. Pellet wrote:
In PDE, we have some tooling to help you as a plug-in developer:
http://eclipsesource.com/blogs/2008/12/11/tip-generate-nls-f ragments-in-eclipse/
http://eclipsesource.com/blogs/2008/07/23/tip-internationali zation-and-rcp/
Hope this helps a bit.
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/caniszczyk | http://twitter.com/eclipsesource
Previous Topic:WizardDialog default button
Next Topic:Flickering SDK welcome screen on 3.5M5
Current Time: Wed Apr 16 05:37:39 EDT 2025
Powered by FUDForum. Page generated in 0.01832 seconds
