JFace Dialog...carriage return in Text widget...Button event sent from Display.readAndDispatch() on [message #334687] |
Tue, 24 February 2009 19:37 |
Originally posted by: james.towers.siemens.com
--------------060607080607080408050907
This is an AIX only issue...windows works fine...we have no reports of
issues on Linux, HP, or Solaris.
We have a RCP application and our Application class displays a login
dialog to gather credentials. This login dialog extends JFace Dialog.
We have several Text widgets and three Button widgets. We create all
these controls in our createDialogArea() method. The password Text
widget has a KeyListener that attempts a login. If we have an invalid
password in the password widget and hit enter...the password KeyListener
attempts a login...the login fails and we place the focus into the useid
text. We can enter another password into the password text and hit
enter. This time the cancel button gets the event instead of the
password text...and we do a buttonPressed().
I searched for this and similar issues on the message board and bugzilla
but didn't find any. Are there any thoughts on the cause or a
workaround? I have attached a test dialog class that shows the problem.
Thanks and regards,
Jim
name="MyLoginDialog.java"
Content-Disposition: inline;
filename="MyLoginDialog.java"
package com.towers.myrcp;
import org.eclipse.jface.dialogs.Dialog;
import org.eclipse.jface.dialogs.IDialogConstants;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.KeyAdapter;
import org.eclipse.swt.events.KeyEvent;
import org.eclipse.swt.events.KeyListener;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.FormAttachment;
import org.eclipse.swt.layout.FormData;
import org.eclipse.swt.layout.FormLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class MyLoginDialog extends Dialog {
private Text userId;
private Text password;
private Button loginButton;
private Button cancelButton;
KeyListener keyL;
protected void createButtonsForButtonBar(Composite parent) {
// TODO Auto-generated method stub
protected Control createDialogArea(Composite parent) {
Composite dcomp = new Composite( parent, SWT.NONE );
FormLayout layout = new FormLayout();
dcomp.setLayout( layout );
Label l = new Label (dcomp, SWT.NONE);
l.setText("userId:");
FormData fd = new FormData();
fd.left = new FormAttachment( 0, 1000, 10 );
fd.top = new FormAttachment( 0, 1000, 10 );
l.setLayoutData( fd );
userId = new Text(dcomp, SWT.BORDER);
FormData fd2 = new FormData();
fd2.left = new FormAttachment( 0, 1000, 80 );
fd2.top = new FormAttachment( 0, 1000, 10 );
userId.setLayoutData( fd2 );
keyL = new IC_KeyListener();
userId.addKeyListener(keyL);
userId.setEnabled(true);
Label l2 = new Label (dcomp, SWT.NONE);
l2.setText("password:");
FormData fd3 = new FormData();
fd3.left = new FormAttachment( 0, 1000, 10 );
fd3.top = new FormAttachment( 0, 1000, 50 );
l2.setLayoutData(fd3);
password = new Text(dcomp, SWT.PASSWORD | SWT.BORDER);
FormData fd4 = new FormData();
fd4.left = new FormAttachment( 0, 1000, 80 );
fd4.top = new FormAttachment( 0, 1000, 50 );
password.setLayoutData(fd4);
password.addKeyListener(keyL);
password.setEnabled(true);
loginButton = new Button( dcomp, SWT.PUSH | SWT.CENTER );
FormData fd5 = new FormData();
fd5.left = new FormAttachment( 0, 1000, 10 );
fd5.top = new FormAttachment( 0, 1000, 100 );
loginButton.setLayoutData(fd5);
loginButton.setText( "loginButton" );
loginButton.setEnabled( false );
loginButton.addSelectionListener( new SelectionAdapter()
public void widgetSelected( SelectionEvent e )
doLogin();
cancelButton = new Button( dcomp, SWT.PUSH | SWT.CENTER );
FormData fd6 = new FormData();
fd6.left = new FormAttachment( 0, 1000, 80 );
fd6.top = new FormAttachment( 0, 1000, 100 );
cancelButton.setLayoutData(fd6);
cancelButton.setText( "cancelButton" );
cancelButton.setEnabled( true );
cancelButton.addSelectionListener( new SelectionAdapter()
buttonPressed( IDialogConstants.CANCEL_ID );
return dcomp;
protected void configureShell(Shell newShell) {
super.configureShell(newShell);
newShell.setText("MyLoginDialog");
public int open()
int ret = super.open();
Display display = getShell().getDisplay();
while( getShell() != null && !getShell().isDisposed() )
try
if( !display.readAndDispatch() )
display.sleep();
catch( Throwable e )
e.printStackTrace();
display.update();
return ret;
public MyLoginDialog(Shell parentShell) {
super(parentShell);
setBlockOnOpen( false );
// TODO Auto-generated constructor stub
public MyLoginDialog() {
this (null);
private void doLogin()
userId.setEnabled(false);
loginButton.setEnabled(false);
password.setEnabled(false);
cancelButton.setEnabled(false);
if (password.getText().equalsIgnoreCase("jim"))
this.close();
return;
userId.selectAll();
userId.setFocus();
loginButton.setEnabled(true);
cancelButton.setEnabled(true);
private class IC_KeyListener
extends KeyAdapter
public void keyReleased( KeyEvent e )
if (userId.getText().equalsIgnoreCase(""))
else
if( loginButton.isEnabled() && e.character == SWT.CR )
doLogin();
--------------060607080607080408050907--
FUDForum. Page generated in 0.03048 seconds
