NEWBIE - installing my plugin [message #33947] |
Thu, 15 May 2003 19:19 |
Originally posted by: raven609.hotmail.com
I have made an syntax editor that edits simulation tool files...
I've "installed" my plugin so far and its put in a folder in the plugin
directory(the jar and .xml file). However, i can't seem to use the editor
at all. I looked at the error log and their seems to be an error
"Plugin CD++Editor, extension org.eclipse.ui.editors"
Also my plugin is not "activated" I assume because of this error....anyone
know what i should do?? or how i can fix this??
Sherwin
Re: NEWBIE - installing my plugin [message #33969 is a reply to message #33947] |
Thu, 15 May 2003 19:42 |
Originally posted by: acme.us.ibm.com
Double-click on the error in the error log, then click Details. That
will probably have an exception stack trace that might give you a clue.
Bryan
> plugin directory(the jar and .xml file). However, i can't seem to use
> the editor at all. I looked at the error log and their seems to be an
> error
> anyone know what i should do?? or how i can fix this??
> Sherwin
Re: NEWBIE - installing my plugin [message #35562 is a reply to message #33969] |
Fri, 16 May 2003 13:01 |
I did do that and it just gives me the exact discription i have previously
listed. Is their a way to debug it??
Sherwin
> Bryan
> > error
> > Sherwin
FUDForum. Page generated in 0.03192 seconds
