Home » Eclipse Projects » Eclipse Platform » Parameterized View
Parameterized View [message #334629] Fri, 20 February 2009 17:40 Go to next message
Will Horn is currently offline Will HornFriend
Is there any way to parameterize a view programmatically? I would like
an action from one summary view to launch a new view with detail
information.
My detail view supports multiple instances and I'm using
IWorkbenchPage#showView(String, String, int) to open it. Any way to
tell it what to show?
I know IExecutableExtension can be used declaratively, but I need to do
it at runtime.
Will
Re: Parameterized View [message #334658 is a reply to message #334629] Mon, 23 February 2009 18:29 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
Views don't have the concept of input, which is why there's nothing to
specify in the showView(*) call. The pattern that is commonly used in
eclipse is to make your secondaryId a key, that your view can use to
retrieve information from a common location at runtime.
PW
Paul Webster
Previous Topic:Paint a line across Eclipse?
Next Topic:Preferences vs. IPreferenceStore
Current Time: Thu Dec 26 19:31:59 GMT 2024
Powered by FUDForum. Page generated in 0.02994 seconds
