Home » Eclipse Projects » Eclipse Platform » 3.5M5 [viewContribution] action activation by the object selection doesn't work
3.5M5 [viewContribution] action activation by the object selection doesn't work [message #334556] Tue, 17 February 2009 15:12 Go to next message
I'd like to have my own action in the debug view. The action has to be
activated when an element of the java stack frame is selected.
I defined the following extension point and created the class
my.test.DebugAction implements IViewActionDelegate.
<extension
point="org.eclipse.ui.viewActions">
<viewContribution
id="my.test.viewDebugContribution"
targetID="org.eclipse.debug.ui.DebugView">
<action
class="my.test.DebugAction"
id="my.test.DebugAction"
label="Test Action"
toolbarPath="additions">
enablesFor="+"
<selection
class="org.eclipse.jdt.debug.core.IJavaStackFrame">
</selection>
</action>
</viewContribution>
</extension>
This solution works fine for eclipse 3.4 (ganymede) but doesn't work for
3.5M5 (galileo) any more. The action is visible in the debug view but
disabled. If I remove the enablesFor="+" parameter then the action is
always enabled.
What is wrong in my extension point implementation or may be is it an
eclipse bug?
Re: 3.5M5 [viewContribution] action activation by the object selection doesn't work [message #334621 is a reply to message #334556] Fri, 20 February 2009 10:26 Go to previous messageGo to next message
> always enabled.
> eclipse bug?
If it works in 3.4 but not in 3.5, something has obviously changed :-)
I suggest you open a bug at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI
Later,
PW
Paul Webster
Re: 3.5M5 [viewContribution] action activation by the object selection doesn't work [message #334645 is a reply to message #334621] Mon, 23 February 2009 02:49 Go to previous message
Thank you Paul!
I wrote a bug report.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=265790
Sergej
Previous Topic:Tutorials, Examples, Articles, etc on Eclipse Text Compare functionality?
Next Topic:How to create a plug-in that uses reflection to find files with annotations ?
Current Time: Mon Apr 28 01:35:52 EDT 2025
Powered by FUDForum. Page generated in 0.03319 seconds
