Home » Eclipse Projects » Eclipse Platform » Open Resource window issue
Open Resource window issue [message #334527] Mon, 16 February 2009 09:33 Go to next message
Tomasz Sendela is currently offline Tomasz SendelaFriend
I am using GANYMEDE distribution version
Eclipse Platform - Version: 3.4.1.
In EUROPA distribution version
Eclipse Platform - Version: 3.3.2
when you have some projects checked out from SVN, when You click
CTRL+SHIFT+R (Open Resouce) in opened window you can see svn icons.
This is very usefull because during build process compiled classes and
generated source are placed in directory with svn:ignore flag.
So when for example you are searching specific resource thanks to this
little icon you see immediately whether it is in SVN repo or not.
The problem is that this vanished in GANYMEDE release.
Greetings
TS
Re: Open Resource window issue [message #334529 is a reply to message #334527] Mon, 16 February 2009 10:13 Go to previous message
I mean is this reported as a bug in bugzilla ?
Previous Topic:Editors opening very slowly on Linux
Next Topic:How to change Console encoding?
Current Time: Thu Dec 26 19:58:42 GMT 2024
Powered by FUDForum. Page generated in 0.03081 seconds
