Load my plugin at startup in particular order [message #334525] |
Sun, 15 February 2009 23:55  |
Hi all,
I have written my own plugin to ask for some authentication required in
our case.
I wanted this plugin to run before any other plugin starts like CDT, JDT
etc.
When eclipse gets launched and is loading its other workbench plugins as
UI plugin, the same time I want it to start my plugin as well which is
supposed to be run as UI plugin.
I have used startup extension and implemented IStartup interface and
earlystartup() method of it. Though it runs when Eclipse gets launched but
I am facing following issues :-
1. It is started as one of the Worker thread, but I want it to be started
from UI thread i.e. (main / workebench) thread.
2. When Eclipse is launched with existing C/C++ projects in it, there is
no guarantee that my auth plugin gets loaded before CDT plugins. But I
want to assure that my plugin gets loaded first (though after core
platform plugins) and then CDT or other tool plugins. So, I want to ensure
this order.
3. I want this plugin to be launched always as part of UI thread.
Please help me out how can I achieve this ?
Thanks & Regards,
Re: Load my plugin at startup in particular order [message #334539 is a reply to message #334525] |
Mon, 16 February 2009 17:50   |
On 2/15/2009 11:55 PM, Nayna wrote:
> Hi all,
> our case.
> etc.
> but I am facing following issues :-
> started from UI thread i.e. (main / workebench) thread.
> ensure this order.
First of all, you can use Display.asyncExec() to run a job on the UI thread.
Second, Eclipse does not allow for specifying particular ordering for
plugin activation. It is designed to be loosely coupled and
lazy-loading; ordering of plugins does not agree with those goals.
If you are building an RCP as opposed to just plugins that can be
installed into any Eclipse, there are some options to trigger
authentication at the "beginning," but it is not clear if that is what
you are doing.
Eric
Re: Load my plugin at startup in particular order [message #334565 is a reply to message #334525] |
Wed, 18 February 2009 06:21   |
With 3.5 M5 you can set start levels.
see http://download.eclipse.org/eclipse/downloads/drops/S-3.5M5- 200902021535/eclipse-news-M5.html
May be it was available before and the enhancement for M5 provides only a GUI, I don't know.
Mariot
Nayna a écrit :
> Hi all,
> our case.
> etc.
> ensure this order.
> Thanks & Regards,
FUDForum. Page generated in 0.21812 seconds
