Re: Load my plugin at startup in particular order [message #334539 is a reply to message #334525] |
Mon, 16 February 2009 22:50 |
On 2/15/2009 11:55 PM, Nayna wrote:
> Hi all,
> I have written my own plugin to ask for some authentication required in
> our case.
> I wanted this plugin to run before any other plugin starts like CDT, JDT
> etc.
> When eclipse gets launched and is loading its other workbench plugins as
> UI plugin, the same time I want it to start my plugin as well which is
> supposed to be run as UI plugin.
> I have used startup extension and implemented IStartup interface and
> earlystartup() method of it. Though it runs when Eclipse gets launched
> but I am facing following issues :-
> 1. It is started as one of the Worker thread, but I want it to be
> started from UI thread i.e. (main / workebench) thread.
> 2. When Eclipse is launched with existing C/C++ projects in it, there is
> no guarantee that my auth plugin gets loaded before CDT plugins. But I
> want to assure that my plugin gets loaded first (though after core
> platform plugins) and then CDT or other tool plugins. So, I want to
> ensure this order.
> 3. I want this plugin to be launched always as part of UI thread.
First of all, you can use Display.asyncExec() to run a job on the UI thread.
Second, Eclipse does not allow for specifying particular ordering for
plugin activation. It is designed to be loosely coupled and
lazy-loading; ordering of plugins does not agree with those goals.
If you are building an RCP as opposed to just plugins that can be
installed into any Eclipse, there are some options to trigger
authentication at the "beginning," but it is not clear if that is what
you are doing.
Eric
Re: Load my plugin at startup in particular order [message #334565 is a reply to message #334525] |
Wed, 18 February 2009 11:21 |
Mariot Chauvin Messages: 174 Registered: July 2009 |
With 3.5 M5 you can set start levels.
see http://download.eclipse.org/eclipse/downloads/drops/S-3.5M5- 200902021535/eclipse-news-M5.html
May be it was available before and the enhancement for M5 provides only a GUI, I don't know.
Mariot
Nayna a écrit :
> Hi all,
> our case.
> etc.
> ensure this order.
> Please help me out how can I achieve this ?
> Thanks & Regards,
FUDForum. Page generated in 0.04022 seconds
