Re: Editors opening very slowly on Linux [message #334491 is a reply to message #334486] |
Thu, 12 February 2009 14:58 |
Originally posted by: igor.ifedorenko.com
Do you see the same problem with SUN or IBM JDK? I am on Ubuntu and have
not seen any performance problems running Eclipse using either JDK.
Igor
Mary Ellen Foster wrote:
> I'm using Eclipse 3.4.1 on Fedora, although colleagues who use Ubuntu
> have also seen similar issues. Every time I open a new file, it takes a
> perceptibly long time -- several seconds -- to actually open the editor
> window. I've tried with an empty .eclipse directory and a fresh
> workspace and with both GCJ 1.5 and OpenJDK 1.6, and it always happens.
> Oddly, for me this is only on my desktop machine; I have no issue on my
> laptop, which is running the same version of Fedora.
> Is this a known problem? Where should I look for suggestions?
> MEF
Re: Editors opening very slowly on Linux [message #334493 is a reply to message #334491] |
Thu, 12 February 2009 16:24 |
Originally posted by: mickael.istria.openwide.fr
I agree with Igor.
My colleagues and I experimented the same troubles under Ubuntu with gcj
or OpenJDK, and the only solution we found was to switch to the Sun JVM...
Hope that helps
Mickael
> Igor
>> a perceptibly long time -- several seconds -- to actually open the
>> editor window. I've tried with an empty .eclipse directory and a fresh
>> my laptop, which is running the same version of Fedora.
>> Thanks,
>> MEF
Re: Editors opening very slowly on Linux [message #334505 is a reply to message #334486] |
Fri, 13 February 2009 08:10 |
On Thu, 12 Feb 2009 13:33:13 +0000 (UTC), mefoster@gmail.com (Mary
Ellen Foster) wrote:
>I'm using Eclipse 3.4.1 on Fedora, although colleagues who use Ubuntu have
>window. I've tried with an empty .eclipse directory and a fresh workspace
Please don't use gcj: it's not supported by Eclipse and causes a
significant amount of questions in the "Why does my Eclipse doesn't
start/keeps crashing" section in the newsgroups.
Have a look at http://www.eclipse.org/downloads/moreinfo/jre.php for a
list of supported VMs.
Achim
Achim Lörke
Eclipse-Stammtisch in the Braunschweig, Germany area:
http://www.bredex.de/de/news/events.html
Achim Lörke
FUDForum. Page generated in 0.06377 seconds
