Editors opening very slowly on Linux [message #334486] |
Thu, 12 February 2009 08:33  |
I'm using Eclipse 3.4.1 on Fedora, although colleagues who use Ubuntu have
also seen similar issues. Every time I open a new file, it takes a
perceptibly long time -- several seconds -- to actually open the editor
window. I've tried with an empty .eclipse directory and a fresh workspace
and with both GCJ 1.5 and OpenJDK 1.6, and it always happens.
Oddly, for me this is only on my desktop machine; I have no issue on my
laptop, which is running the same version of Fedora.
Is this a known problem? Where should I look for suggestions?
MEF
Re: Editors opening very slowly on Linux [message #334493 is a reply to message #334491] |
Thu, 12 February 2009 11:24   |
Originally posted by: mickael.istria.openwide.fr
I agree with Igor.
My colleagues and I experimented the same troubles under Ubuntu with gcj
or OpenJDK, and the only solution we found was to switch to the Sun JVM...
Hope that helps
Mickael
Igor Fedorenko a écrit :
> Do you see the same problem with SUN or IBM JDK? I am on Ubuntu and have
> not seen any performance problems running Eclipse using either JDK.
> Igor
>> have also seen similar issues. Every time I open a new file, it takes
>> a perceptibly long time -- several seconds -- to actually open the
>> editor window. I've tried with an empty .eclipse directory and a fresh
>> workspace and with both GCJ 1.5 and OpenJDK 1.6, and it always happens.
>> my laptop, which is running the same version of Fedora.
>> Thanks,
>> MEF
FUDForum. Page generated in 0.02574 seconds
