Home » Eclipse Projects » Eclipse Platform » Console/UI Same Application
Console/UI Same Application [message #334450] Mon, 09 February 2009 19:51
Originally posted by: adam.example.com
I have an application in which I want to control the presence of any
graphical pieces through command line arguments (Linux). My problem is
that something is still trying to display even in console mode which
causes GTK errors (see below) and a java crash. My plugin only extends
"Plugin" and I am not calling Platform.createAndRunWorkbench unless in
UI mode. Is this possible and there is something I'm missing, or do I
have to have separate UI/Console applications?
thanks,
adam
(kernel:9156): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(kernel:9156): GLib-GObject-CRITICAL **: g_signal_connect_data:
assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
(kernel:9156): Gtk-CRITICAL **: gtk_settings_get_for_screen: assertion
`GDK_IS_SCREEN (screen)' failed
(kernel:9156): Gtk-WARNING **: Screen for GtkWindow not set; you must
always set
a screen for a GtkWindow before using the window
Previous Topic:Cannot allocate memory MacOS 3.3.2 and 3.4.1
Next Topic:Removing highlighting of text
Current Time: Sun Apr 27 02:05:23 EDT 2025
Powered by FUDForum. Page generated in 0.02623 seconds
