Home » Eclipse Projects » Eclipse Platform » Ganymede "Help Contents" generating Error 500
Ganymede "Help Contents" generating Error 500 [message #334371] Thu, 05 February 2009 17:23
Pavel Matsibekker is currently offline Pavel MatsibekkerFriend
In Ganymede, using Dynamic Help works fine but clicking on "Help Contents"
under the Help Menu opens a browser to the URL
http://127.0.0.1:1361/help/index.jsp with the following error.
HTTP ERROR: 500
Internal Server Error
RequestURI=/help/index.jsp
Powered by Jetty://
It seems like the port is open because if I go to the URL
http://127.0.0.1:1361/help/index, I do get an xml file back with
indexcontributions from various packages, so it would seem the server is
up but not seeing the index.jsp file.
I'm having a devil of a time trying to figure out which plugin manages
this or how to control the behavior.
So, what am I doing wrong here?
Previous Topic:Annotations
Next Topic:Run As --> Ant Build... always creates new configuration
Current Time: Fri Nov 08 21:59:18 GMT 2024
Powered by FUDForum. Page generated in 0.02892 seconds
