Re: Can I customize the ant build script exported by eclipse? [message #334385 is a reply to message #334377] |
Fri, 06 February 2009 14:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Raymond Mising name![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=zqiu%40rim.com) Messages: 59 Registered: July 2009 |
Member |
Andrew,
Thanks for you answer. It is good for me to know this mechanism. However,
it is not exactly what I want. This way, it seems users still need to
create the customBuildCallbacks.xml manually, then, when the build.xml is
executed, it can be called, right?
What I am looking for is does eclipse provides any support to
programmatically create an ANT build script file? When a project is
created, the properties of our resource builder are set, when users click
the export ant buildfiles function, I want it can programmatically create
an ANT task for our resource builder in the build.xml file or the
customBuildCallbacks.xml mentioned in your answer.In short words, I am
more interested in programmatically generating an ANT build file.
Thanks.
FUDForum. Page generated in 0.04207 seconds
