Re: RCP dev - how to handle plugin.jars ? [message #334254 is a reply to message #334248] |
Thu, 29 January 2009 14:43 |
Originally posted by: fakemail.xyz.de
S.Schnabl schrieb:
> Hello,
> i have the following problem. We are developing an rcp application,
> which uses some "common plugins". These common plugins are declared as
> dependency in plugin.xml of the CORE-Plugin of our rcp-application.
> During development (compile time) these works, as long as we have these
> common plugins checked out as source-code in our workspace.
> But now we want to switch to have only the packaged JAR-File of ever
> common plugin in our workspace --> but our core plugins now doesn't find
> these plugins anymore.
> How must we register these Plugin-JARs in our project/-plugin.xml
> settings, so that they will be found from eclipse during development time?
If you don't want plugins for each jar and just want them to be visible
for a single project you can just put the jar file into the root folder
of the plugin.
In the plugin.xml you have to add it under Runtime -> classpath then
and don't foget to add the plugin to be exported in the buil.properties
file.
But maybe I misunderstood your problem..
Christian
FUDForum. Page generated in 0.04034 seconds
