Home » Eclipse Projects » Eclipse Platform » Using command Framework to add items to pagebooks
Using command Framework to add items to pagebooks [message #334240] Wed, 28 January 2009 10:40 Go to next message
There is one element of the new command framework that I cannot find
covered anywhere. I have experimented with code and have not solved the
problem. This makes me conclude that the answer is so obvious I can't see
it or that this is a bug / shortcoming of the Command Framework.
Using the command framework I have not been able to add, using only
plugin.xml entries, the ability to add /control toolbar menu items to a
specific page of a pagebook view.
For example, consider org.eclipse.ui.views.contentoutline.ContentOutline.
The Eclipse PDE implements, in code, various contributing content outline
pages for the outline view. When no editor is open the outline view has no
toolbar items. Depending on the file opened for edit, the icons in the
Content Outline view toolbar change to suit the file. Can that be done for
a newly contributing page using only command framework entries? I also
want to implement the same behaviour in my own pagebook views.
Is this a bug or a “feature” or am I missing something.
I posted this earlier but it seems to have disappeared - or was never
posted correctly.
Re: Using command Framework to add items to pagebooks [message #334243 is a reply to message #334240] Wed, 28 January 2009 13:13 Go to previous messageGo to next message
It doesn't look possible.
If the page site and page action bars returned a ContributionManager you
could use IMenuService to populateContributionManager(*) (this would
allow your toolbar to pick up plugin.xml contributions) ... but I think
a page site returns a SubToolBarManager, which is not an instance of
ContributionManager.
You can open a bug at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI&short_desc=[Contributions]
PW
Paul Webster
Re: Using command Framework to add items to pagebooks [message #334416 is a reply to message #334243] Sat, 07 February 2009 08:58 Go to previous message
Done
https://bugs.eclipse.org/bugs/show_bug.cgi?id=264036
Previous Topic:Print multiple files at once
Next Topic:How can i get SourceViewer in the TextEditor?
Current Time: Tue Apr 29 01:33:30 EDT 2025
Powered by FUDForum. Page generated in 0.06338 seconds
