Home » Eclipse Projects » Eclipse Platform » .html files always Shift_JIS regardless of preferences or content
.html files always Shift_JIS regardless of preferences or content [message #334193] |
Mon, 26 January 2009 07:36 |
Ed Wright Messages: 11 Registered: July 2009 |
Junior Member |
Eclipse 3.4 on Linux:
If I create a new *empty* .html file, it is always created with a file
encoding of Shift_JIS, "determined from content".
If I copy an existing html snippet (no headers), which has UTF-8
content, for which I have manually set the encoding to UTF-8, to another
location, the encoding is reset to Shift_JIS.
An annoying side note is that when I do reset the encoding type, Eclipse
tells me UTF-8 conflicts with the content type *even if the file is
empty or contains UTF-8 content*.
This is a major headache for me, apart from the need to manually reset
the content type on every such file, in that editing and saving a file
results in permanently corrupted Japanese text.
settings:
env var LANG = ja_JP.utf8
parent folder text file encoding set to UTF-8
preferences:web:html files encoding set to UTF-8
preferences:general:content types:text:html default encoding for all
file associations set to UTF-8
Am I missing something somewhere? Is this a bug? (Ain't no feature in my
book :) )
Ed
Re: .html files always Shift_JIS regardless of preferences or content [message #334196 is a reply to message #334193] |
Mon, 26 January 2009 11:45 |
Ed Merks Messages: 33264 Registered: July 2009 |
Ed,
Comments below.
How do you create it? Are you using WTP's editor or just Eclipse's text
editor (which isn't XML aware)?
> If I copy an existing html snippet (no headers), which has UTF-8 content
Once you're working with text, you're working with characters (or
codepoints) where there is simply no such notion as it being UTF-8 which
is a concept that applies to the manner in which those characters are
encoded as bytes.
I don't get this comment. The characters should be copied into the
editor without affecting the encoding the editor remembers. That's not
the case?
How do you do that?
> Eclipse tells me UTF-8 conflicts with the content type *even if the
> file is empty or contains UTF-8 content*.
An empty file could contain a byte order marker that would be hard to
notice...
> settings:
> my book :) )
It might well be, but if this is a question about WTP's editor, it's
better to ask there on their newsgroup.
> Ed
Ed Merks
Re: .html files always Shift_JIS regardless of preferences or content [message #334198 is a reply to message #334196] |
Mon, 26 January 2009 13:37 |
Junior Member |
Hi Ed,
Also comments below...
Doesn't matter. I can "touch test.html" from the linux command line,
creating a stone empty file; "refresh" in Eclipse; and the file is
marked Shift_JIS. However, generally, I use Eclipse Navigator's New/ File.
> encoded as bytes.
Understood. The main point I wanted to make was that I manually set the
encoding to UTF-8 on the original file, but when I used copy/paste
within Eclipse, the encoding gets changed to Shift_JIS. I would expect a
file copy (within Navigator) to copy properties as well as contents.
> the case?
I'm not copy/pasting file contents from file to file, rather I am
copy/pasting the file itself from directory A to directory B.
The actual contents are correctly/accurately copied. The problem is that
Eclipse now thinks the file is Shift_JIS encoded and will open and edit
and save the file as Shift_JIS unless I manually reset the encoding.
> How do you do that?
In the "Navigator" I right click the file name, select "properties"
which displays "Resource" where the file encoding is set/settable.
> notice...
Could, but doesn't :) - See my first note above.
>> my book :) )
I wouldn't *think* it would be an editor issue as the encoding seems to
be set regardless or what editor I use. However, it *does* seem to be
specific to .html files. (If I repeat the procedure in my first note
above, only touch "test.txt" instead, the file is marked as UTF-8
encoded, as expected.)
Any additional thoughts greatly appreciated. And if you think it is
likely to be an editor issue, I'll repost over there. (Would that be
eclipse.webtools?)
Thanks again.
Ed
Re: .html files always Shift_JIS regardless of preferences or content [message #334204 is a reply to message #334198] |
Mon, 26 January 2009 16:02 |
Ed,
Yes, if it's specific to the WTP editor, I'd ask on eclipse.webtools.
Certainly for XML files, I'd expect the content type to be determined by
the XML header...
Ed Wright wrote:
> Hi Ed,
>>> file encoding of Shift_JIS, "determined from content".
>> text editor (which isn't XML aware)?
> File.
>>> content
>> which is a concept that applies to the manner in which those
>> characters are encoded as bytes.
> the encoding to UTF-8 on the original file, but when I used copy/paste
> a file copy (within Navigator) to copy properties as well as contents.
>> not the case?
> that Eclipse now thinks the file is Shift_JIS encoded and will open
> and edit and save the file as Shift_JIS unless I manually reset the
> encoding.
>> How do you do that?
>> notice...
>>> in my book :) )
> to be set regardless or what editor I use. However, it *does* seem to
> be specific to .html files. (If I repeat the procedure in my first
> note above, only touch "test.txt" instead, the file is marked as UTF-8
> eclipse.webtools?)
> Thanks again.
> Ed
Ed Merks
Current Time: Tue Jan 14 00:04:09 GMT 2025
Powered by FUDForum. Page generated in 0.03373 seconds
