Individual Source Bundle [message #334147] |
Thu, 22 January 2009 07:12 |
Manuel Selva![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=manuel.selva%40st.com) Messages: 189 Registered: July 2009 Location: Grenoble, France |
I am posting this here after posting it in PDE newsgroups without success
Hi there,
I am trying to set up an automated build using PDE headeless build able to
build source for my plugins.
All worked fine previously to 3.4. I am trying now to export my source
plugins as individual bundle but I can't find the right way to do that.
More precisely I have an example feature containing 3 examples plugins:
com.st.example.a
com.st.example.b
com.st.example.c
In my example feature build.properties I added the generation of source
plugin for these 3 plugins. In the feature.xml I included the 3 plugins
and the 3 associated "generated" source plugins.
When running pde headless build with IndividualSourceBundles=true, three
source plugins are generated but in directories and not as jar files. Is
it normal ?
Then when I try to import one of my example plugin as source I reach an
error telling : error in opening zip file. After stepping inside PDE code
it seems PDE is looking for sources inside a jar file and not inside a
directory ... i think this is the source of my problem ...
Any ideas are welcome ... Anyone already using successfully
IndividualSourceBundle ? Should i stay with one source plugin for my 3
plugins ... :o(
Many thanks
Manu
http://manuelselva.wordpress.com/
FUDForum. Page generated in 0.02451 seconds
